Question about Brother Multi-Function Center MFC-3360c All-In-One InkJet Printer
Printer Cartridge problem
Replaced printer cartridge. Printer keeps telling me that there is no cartridge installed. Tried several times. I notice several other people at this site have had the same problem, but see no solution given.
  • 1 more comment
  • Anonymous Oct 09, 2008
    same problem
  • terrih90899 Nov 12, 2008
    I have the same problem
  • kikis_831 Nov 24, 2008
    i just got this printer didn't get a manual but it tells me to install yellow
I'm having the same problem. I called Brothers 3 times. I had use generic cartridges the first time I replaced them and they seemed to work fine for 4 months, then in the middle of printing it stopped on the 2nd page and said empty black so I replaced it and it starting sauying no cartridge, low yellow, low magnt and low cyna. I keep replacements on hand so I replaced them all (generic type) Still didn't work The first tech person said to buy a geniune Brothers black, I did and still didn't work. I called that night and the 2nd tech said I needed to replace them all with geniuine Brothers colors. I did, still the same error no cartridge then ibk black empty. The 3rd tech said I needed to take it into the nearest service center that covers warrenty repairs. The tech said it it is mechanical then it will be covered under my warrenty if not I must pay for it. I called the repair center they are out of town at a seminar until next Monday. I have a feeling I've wasted all this $$ on two sets of ink cartridges and will end up paying to have my MFC 3360C repaired. Which probably will cost more than I paid for it. This sucks. Sorry to sound so negative. Frustration does that. :O(
Posted on Nov 22, 2008
Call Brother on 02 8875 6000. They talked us through checking the ink management. We never use colour but they dry up. One of our colours had dried up which meant that the Multi Function Centre kept telling us that no cartridge had been installed, even though we had just put in a new black cartridge. The machine only told us originally that the black was empty (which is the one we replaced), but when going through the ink management with the Brother technician it showed that the blue also needed replacing. This apparently is what was causing the error message. So I'm off to buy a new blue cartridge - hopefully this works. So give Brother a call on the above number.
Posted on Nov 10, 2008
No, I haven't solved the problem. That's why I hoped that someone else had, and might be willing to share.
Posted on Oct 02, 2008
I just installed a new black ink cartridge for the Lexmark X125, but now the message reads ADD CARTRIDGE. I have tried re-installing it several times. I have also wiped the metal connectors. I have...
Check if the new cartridge installed is compatible with the printer. If it is compactible then make sure that you properly position the cartridge of the printer. It will surely works perfectly. If you encounter any problem during the process contact me on greatengineerid@hotmail.com or call +234-8023821869
Cheers.
Engr. Adewumi I.O
Sep 05, 2011 | Office Equipment & Supplies
Re: The printer will not recognize the installing of a new color cartridge.
after installing a new cartridge you need to open the program for your printer tray and reset your cartridges so that the printer and pc reconize the cartridge is full
Sep 19, 2007 | Dell 942 All-In-One InkJet Printer
Our copier (model x5650) stopped while receiving several pages , and displayed FAX IN MEMORY COLOR AND BLACK INK CARTRIDGE NEEDS REPLACED. I installed a new black cartridge , however the display...
YOU NEED TO LET THE PRINTER RE-ALIGN ITSELF AFTER INSTALLING PRINT CARTRIDGES, THE PRINTER SHOULD HAVE PAPER IN IT TO DO THIS, THE TEST PAGE PRINTED WILL THEN NEED TO BE PLACED IN THE PRINTER ON THE GLASS, PRESS SCAN, THIS SHOULS RESET YOUR PRINTER.
HOPE THIS HELPS!
MARTIE
Aug 24, 2011 | Lexmark C533DN InkJet Printer
The magenta isn't printing correctly, and the printer keeps telling me to remove tape from the magenta cartridge. There isn't any tape on it. I've tried resetting it several times.
Its sounds as though the printer isnt picking up the cartridges properly, try removing it and cleaning the contacts on both the cartridge and the printer
May 05, 2011 | Dell 3130cn Color Laser Printer
Replaced black ink cartridge and printer keeps asking to replace
The message that persists in saying to "replace black cartridge" could be due to a defective cartridge chip. The chip maintains counts and tells the printer when a new cartridge is installed. If you cartridge is remanufactured, they may have neglected to install a new chip.
Regarding the new fuser not working, I'll have to get back to you on that.
Oct 15, 2009 | HP LaserJet 4600dn Color Printer
Error messages but I can't find the errors
ona brand new machine you get a starter cartridge, you will need to put in a new cartridge
Feb 01, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-3360C cyan ink cartridge replace ment
On the front of the cartridge there is a sight tube for the ink, the fax shines a light through this tube to detect the ink.
I wraped a piece of paper around the tube to block the light beam on all the cartridges.
I dont need a processer to tell me if the machine is out of ink, I can work thay out when it stops printing!!
Now tell me you are out of ink you peice of electronic ****.
Jun 27, 2008 | Brother Multi-Function Center MFC-3360c...
Brother Multi-Function Center  MFC-3360c All-In-One InkJet Printer Logo
182 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
