Question about Dell Inspiron 1200 Notebook
Inspiron 1200 Dead Screen
I have a Dell Inspiron 1200 when you power the computer on the screen will come on for a few seconds then go black again. I can see some faint shadows in the screen and it appears the computer never full boots up. An external connected monitor doesn't work either.
  • 2 more comments
  • aaronpfeifer Oct 02, 2008
    I reconnected the external monitor and pressed FN and F8 and got the external monitor to function like it should. Same thing out of the laptop screen on for a few seconds then back out again. I replaced the inverter for the backlight and it responded the same. Do entire screens go bad like this or do you think the problem could still lie in the motherboard?
    What tells the backlight to turn on and off? The problem is with the backlight, is there way to monitor the signal that tells the backlight to turn on? If I loose that signal the video is still there you just can see because there is no backlight. I also made sure that the button that switches the screen off when you close the screen isn't stuck down. Any additional thoughts?
  • aaronpfeifer Oct 04, 2008
    I opened the the laptop up and found a heatsink that is attached to the motherboard with soldered on standoffs was popped up and not fully contacting the chip. One of the soldered on standoffs had come off the board. This heatsink is for a chip that sits below the cpu, it has LCD etched into the heatsink. Is this a chip for the video for the computer? It didn't look like there was any way to replace this chip and could this be the root cause of my problems?
  • Anonymous Mar 18, 2014
    The monitor will not go to a full screen. How do I fix this?
  • 169 Answers
At first glance, I'd say "bad video/motherboard" ...however, when you hook up an external monitor, you also need to first switch into "external LCD" mode. On the Dell laptop, hit FN and F8 I believe to switch between LCD and external. It will go through several modes...LCD only, external only, neither, and both. Keep switching until you see something on the external.
If you never see output on the external, you've got a video/motherboard problem. If under warranty, contact Dell and place a support call.
If not under warranty, you're looking at anywhere from $200-$400 for a new motherboard, plus labor for someone to install it.
Hope this helps - remember to rate :)
- A+ certified technician
- 8 years as IT/manager of a 100% Dell-supplied company, with over 1,500 Dell volume annually
- Dell Level II certified technician
Posted on Oct 02, 2008
  • Scott Merrill
    Scott Merrill Oct 02, 2008
    If the external works (EVER) and the LCD does or does not, your problem is *not* your motheboard. If it was the board, the external would not work either...that's why I had you try those steps. LCD's go bad all the time ..they're very sensitive, yet durable creatures.
    In your situation, I usually give clients the options to just save some $$$ and use the laptop with the external screen - most of them never take the "mobile" off their desk anyway. However, if you actually do use it as a mobile computer, then you need to invest in a replacement LCD.
    Glad I could help - don't forget to rate me :)
  • Scott Merrill
    That's an interesting point ....usually, though, if the motherboard isn't supplying enough juice to power the backlight, you'll have other problems too (such as intermittent video on other sources) or other power problems. My first guess is still the LCD - it doesn't take much for them to go out it could be a loose or pinched wire coming from the LCD to the output "card" (usually wedged between the machine itself and the LCD, sitting in the "hinge" area - that plastic piece that's at the bottom of the LCD).
    It's possible you could remove the LCD and check for loose wires. That could be all it is. If not, it's the LCD.
Dell inspiron one 2305 black screeen with one flashing light
Dell Inspiron One 2305 (all-in-one) that will not power on. ... to reboot, I saw a faint white flashing light and heard a faint clicking noise. .... but I still have the black screen and my 2305 model remains essentially "dead".
Apr 18, 2014 | Dell Inspiron One 2305 Desktop Computer...
I have a Dell Inspiron 1200. The standby option
Go to the power option and select Laptop power schemes. Restart the computer that should fix the issue.
Jul 06, 2010 | Dell Inspiron 1200 Notebook
Problem with dell 1200 inspiron power
what kind of problem?
i have a 110l completely dead..(the same board as a 2200 or 1200)
i am still searching for a solution to..
May 13, 2010 | Dell Inspiron 1200 Notebook
My dell inspiron laptop 1000 screen turns dark every few seconds. if I close the computer half way and open it,it stay bright for a few seconds and turns dark again
This is your back light on your lcd display, To prove that have a flash light handy when it goes dark point the flash light at the screen and you should see the screen and that would mean right there you got a back light going out or the inverter that powers it is going bad. Etherway if this is not your area of work you need to tech it to a computer tech local to have it repaired.
Thanks for being considerate with your ratings and feedback today.
May 04, 2010 | Dell Inspiron 1525 Notebook
I've got a Dell Inspiron 1525. When I power on the unit, the LCD shows the Dell startup screen, then a whinning noise and the screen goes black. Sometime shortly there after the Windows screen appears but...
This sounds more like a hardware issue. Now you say that the external display output is working fine. It could possibly be a problem with the lcd display itself shorting out. If there was a problem with the video hardware then I do not think you would be able to get the external display working either. The whinning noise could be coming from the lcd inverter.
Dec 14, 2009 | Dell Inspiron 1525 Notebook
ok well if that is all it dose then you are going to have to restore the computer back to factory settings and then try it but befor you do that have you tryed starting up in safe mode that might work.
please rate my help to you.
thank you.
Apr 21, 2009 | Dell Inspiron 1200 Notebook
My Dell Inspiron 1000 Laptop would not power up.
possible power supply are motherboard possible bad pin on board
Mar 28, 2009 | Dell Inspiron 1000 Notebook
Dell inspiron 1200 screen code
The model number is Inspiron 1200. Maybe you mean service tag or a serial number. all i know is it's different on every dell computer. =)
Oct 04, 2008 | Dell Inspiron 1200 Notebook
Dell Inspiron 1200 no POST
There are two memory slots on this model, but there is no "Onboard" memory. Without the memory that you removed, your laptop will not post. It sounds like a dead motherboard issue to me, especially since you have pretty much torn it down to barebones. Rarely, this can also be caused by the processor but it is less likely. Unfortunately, since you cannot keep it running, there isn't much chance of diagnostics. I hope this helped.
Apr 20, 2008 | Dell Inspiron 1200 14.1 XGA LCD...
Dell inspiron laptop screen issue
First, are you sure you have the correct power supply?
Also, the lcd inverter could be going bad, consequently needing more power than it can get off the battery.
Hope this helps,
Good luck
Oct 19, 2007 | Dell Inspiron 710m Notebook
Open Questions:
See all Dell Inspiron 1200 Notebook Questions
Dell Inspiron 1200 Notebook Logo
378 people viewed this question
Alun Cox
