I have a g zone type v it will come on only when plugged in, it happened all of a sudden. i f it is plugged in it only takes a few minutes to reach full charge but if you unplug it it goes dead. can you help?
Ditto my g zone type V . It won't hold a charge. I have to plug it in to use it. Chris U.Ditto my g zone type V . It won't hold a charge. I have to plug it in to use it. Chris U.
You can't post conmments that contain an email address.
ok do you get any warning fron the check engine light? does it die suddenly or little by little? when it happens does it statrt right away? need some info to give you an answer or something to follow.give me all the symptoms.
My guess would be two of the plug wires are on the wrong plugs. The original problem could be a faulty fuel pump relay or the check valve in the fuel pump.
The charge adapter maybe faulty. If your cell phone is a few months old, then it would be still under warranty. Take it back to the place where you purchased it and have it repaired or replaced under warranty.
My wife and I have the same phone and after three years of flawless service, my wife's phone overheated and the battery died. I swapped her battery with mine .... same thing. I swapped phones with her and it happened again with my phone! Why? My wife was leaving the phone turned on and storing it in a metal file cabinet. It was continually trying to make a connection and ran the battery down so fast that the phone heated up. She stopped doing that and the phone is fine again.
I hate to be the bearer of bad news but the only thing i would say try is taking the battery out for about 30 seconds. putting it back in and trying again. if it does not turn on then i'm afraid the phone will not come back. It's a somewhat rare problem but does happen.
Unfortunately all information is gone unless you had downloaded backup assistant.
take the battery out then try again. If the battery isn't totally dead try turning the phone on and then plugging it in. It's happened to me before and sometimes it takes a few tries to get it to work but it should come on eventually.
the problem is the contact points in the phone input are worn and possibly the contact points in the charge output are also worn, there's no way to fix it without replacing the charger input and/or getting a new charger. hate to say but might just need to replace the phone
Chances are that your battery has fried. But before you buy a new one try leaving the battery out of the phone overnight. Then put it back in the phone and plug the charger in. Even if nothing seems to be happening leave it plugged in for a few hours. Sometimes, it takes a bit of time till the charging begins (I have seen this happen on rare occasions). Worth trying before you buy a bew battery.
