Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Sears garage door remotes
I've installed four garage door openers in a steel building and the range of the remotes is very short. I have to stand directly in front of the doors to open them. My question is; Is there any way to extend the range of the remotes since the steel building is blocking the signal.
    Champion:
  • 244 Answers
Tilt antenna different direction. Call Liftmaster for advice
Posted on Jan 15, 2009
Why wont my gargage remote open the door from the outside
I had to extend the antenna wire on mine due to metal siding when I put a steel door on
Sep 13, 2014 | Sears Craftsman LiftMaster Chamberlain...
The range for the remote openers (4) for mu Liftmaster garage door opener has decreased to the point of having to be within 6 feet of the door to open it. The liftmaster was installed 5 yrs ago. The...
There is an antenna extender kit available for your opener. The part number is 41A3504 and should be available from any good door opener company that handles Liftmaster or Chamberlain. It should come with instructions.
Jul 22, 2011 | Sears Craftsman LiftMaster Chamberlain...
The key pad will close the garage door but it will not open the garage door.
If the keypad is the only remote unit you have that has short range then it is failing. The lack of signal strength prevents the signal from reaching the receiver when the door is closed. A replacement is the only cure.
Nov 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Craftsman remote won't close my garage door
If the remote opens and closes while inside the garage but not outside , there are a few things it could be. Assuming it was working fine before..
1. weak battery in remote.
2. remote itself could be bad. (unless you have more than 1 remote acting the same)
3. Logic board in opener is going bad causing limited range.Is the wire that hangs down from the opener straightened out? That is your remote antenna.Some people have coiled or even cut it off..reducing range.
4. Less likely but this can happen- interference from another electronic device, wireless routers, cell phone, new appliances etc.. can reduce remote range. Any new electronics recently purchased?
Jan 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
Brand new craftsman remotes don't work when garage is closed
Yes, it seems to be a frequency issue.  Craftsman usually guarantees 50 foot range on your remotes.  Contact Craftsman, they will probably work with you to solve the problem.
Dec 31, 2008 | Sears Craftsman LiftMaster Chamberlain...
Lack of range on Garage door remote
There is a short wire hanging down from the back of the opening motor -- pull this down as far as you can and bend it so it is pointing toward the garage door. This wire acts like an antenae.
Dec 30, 2008 | Sears Craftsman LiftMaster Chamberlain...
Programing garage door opener remote
ok crystal,calm down this is an easy one! first locate the smart button on your openers , next you will press and hold down the smart button until you see an indicator light above it shut off, while your holding that button the light will be solid ,Now your ready to program your remotes ,first programm one side by taking each of your four remotes and pressing the smart button on machine then pressing the button on the remote you want to program,by doing that you will notice the lightbulbs on your machine shut off and go back on , This is an indicator that your machine has accepted the code , now do it with the other three remotes , after you,ve programmed all four ,go over to the other machine and repeat the process but this time you have to choose another button on your remotes since you,ve programmed all four remotes to the same button on each remote ,just choose the bottom button on your remotes this time to keep them seperated , hope this helps you and it is as easy as 1-2-3 your owners manual will describe exactly the same ,i know because i,ve installed over 27,000 machines working as an installer for sears, please leave a nice feedback rating if i was able to help you, good luck,Sincerely Glenn Mayer
Mar 12, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
429 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
