We use DVD-RW disks to record TV shows. After 3-4 uses the disks stop working. We always re-format prior to re-recording. The literature indicates that the disks can be re-recorded 1000 times. Why do we get only 4-6 times?
I asked someone who wouldn't charge me to answer it.
Posted on Oct 02, 2008
My Philips DVD Recorder does not accept a DVD disc shows no disk. The DVD disc does not revolve. A CD disc revolves but shows junknown
Could be that you are using the wrong type of DVD ? There are two formats DVD+R, DVD+RW etc and DVD-R, DVD-RW etc. Some machines are capable of using either, others can use one of the two formats.
My other suggestion is that some machines are picky about which manufacturer's DVDs they will use.
if you have an error code this might be useful
Dvd recorder won record on DVD RW disc
Some possibly relevant answers here which suggest my answers above
Nov 06, 2015 | Philips Televison & Video
Can't make dvd's from my recordings
The recorder supports these formats
There shouldn't be a problem with the speed, maybe a compatibility issue with brands.
Also it might be your lens is dirty have you tryed a cd/dvd lens cleaner disk? dry/wet?
May 17, 2008 | Lite On LVW-5045 DVD Recorder
Having trouble recording TV broadcast to DVD?
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then stop with a copyright error message during some commercial. I rarely got a complete show. Very frustrating!
Solution: Buy some DVD-RAM disks and this machine will become totally reliable. They are hard to find and a little more expensive than +RW or -RW. Because of the copyright programming on this machine only DVD-RAM disks will work in VR (Video Recorder) mode.
on Apr 29, 2009 | LG RC897T DVD Recorder/VCR Combo
When I record programmes to DVD they always seem to be in 4:3 format even if they are broadcast in 16:9. I have all settings on TV/Satellite/DVD set to 16:9 but the recorded DVD is still 4:3 format. Is...
16:9 recording is availbe on this unit.
Following are the available media to use for recording:
  • DVD-R/RW/+R/+RW; DVD+R Dual layer
I would try a different type of media.
Found this tidbit - *Not all options available for all disc formats.
May 03, 2011 | Sony RDR-VX420 DVD Recorder/VCR
I have dubbed vcr tape to a Sony DVD-RW disc and tried playing it back through a toshiba player and it keeps coming up Bad Disk. My PC won't even recognise it. When started dubbing the screen displayed 1hr...
Did you say you used a DVD-RW disc to transfer a videotape onto? The reason your PC won't recognise that disc is because the data format on it is a different language to what PCs understand - plus an unfinalised DVD-RW won't play in other DVD players - it is usually an incompatible format.
(DVD+RW discs with titles/top menus created in video mode CAN be played on a PC DVD drive or a normal DVD player as can finalised DVD-R discs (DVD-R discs MUST be recorded and finalised in the same recorder for compatible playback). DVD-RW discs can only be viewed on the unit they were written/recorded on.
The other reason for the 'remaining space' on the disc you describe showing less than 120 minutes is due to a title recently being recorded or erased - unless you format it - the 120 minute / 4.7GB DVD-RW will not show full available space. Erasing titles on re-writable DVDs does not increase space. The same rule applies to unfinalised +R / -R discs (you cannot re-format these to get the space back once recorded - they are 'once only' writables)
I recommend you invest in some DVD-R discs and re-copy your VHS tape to that - then if you are satisfied with the result, title etc., finalise the DVD-R - it will play on any DVD player or PC with DVD support (or it should). These discs are relatively inexpensive to buy just about anywhere.
Final note: do NOT finalise the DVD-RW you recorded (I hope you haven't already done this) - simply format/erase it - re-use it for something else or keep it until you need it.
You can use any brand of DVD, just take note of the format before recording/playing.
Mar 21, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Trying to write to blank disk first time (Memorex CD-RW). Get message: Record failed: wrong format for re-write Spectroniq SDR-205 DVD Recorder
Some DVD recorders cannot write CD-RW - only DVD-RW (+ and -) as well as DVD-R (+ and -) (this depends on the brand/model). This unit probably does not support CD recording. Try using DVD-RW instead for this machine - see if it records that (do not finalise even if unit prompts you to with an on-screen message prior to ejecting disc).
There are DVD players and recorders which can play CD-RW (mp3, jpegs etc.) but I don't know of any which record this format (a PC CD/DVD-ROM drive can do this though).
Mar 09, 2011 | Televison & Video
Lg dvd rw recording problems
You might like to know that this recorder works well with DVD+R, DVD-R and DVD-RW but is known to not work well with DVD+RW. This is likely to be the main cause of your problem if you experience these problems and find it happens mostly with DVD+RW.
If the problem occurs across all formats a DVD cleaning disk should help the problem.
Hope this helps. Please do rate my answer. Thanks.
Jul 26, 2009 | LG Televison & Video
Just bought, set up to record with TV and used a Memorex DVD+R
you can then only use the dvd-r cd's and not the dvd-rw disc
Nov 26, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Dvd/vcr recorder stops recording
I found this web page. I think something similar is happeneing to me. It is on analog channels when it hits some commercials.
Nov 02, 2008 | LG DR787T DVD Recorder
Failure to record
I had the same problem on my Philips 3400. Changing media worked. Try RW media if R does not work.
Dec 01, 2007 | Philips DVDR3390/37 DVD Recorder
Televison & Video Logo
Top Televison & Video Experts
