GE profile Harmony washer
I have had some problem with grit / dirt clogging up our screen to the point that every 4 weeks or so the cold water pressure diminshes significantly enough that I have to take the hose off and clean the clogged screen. Sounds like a lot but it doesn't take much debri to cause the screen problem. The last time I damaged the screen to the point of no return and put the hose on sans damaged screen. It worked fine. I thought that might be a solution Now a week later the cold water will not stop running into the washer at a constant flow with washer off. Any ideas what I messed up or what to replace. Think the fine sand like dirt got into something down the line?
  • 5,911 Answers
The water inlet valve (also known as a mixing valve) is more than likely your culprit. If the water continues to run into the washer, the only thing that controls the water flow (besides the tap) is the inlet valve. If you live in an area that has hard water, or if you use well water, rust or sediment can be a common problem. If any has gotten beyond the sediment screens, dirt or debris may be preventing the small diaphragm inside the valve solenoid from closing properly. This will cause the valve to leak by. I would recommend you replace the valve since the screens are damaged. For future reference, clean with a cotton swab dipped in distilled vinegar. It does a good job at getting rid of deposits. If you post back with your COMPLETE model number, I can provide you with a part number and step-by-step instructions on how to replace it. In addtition, if you you're getting a lot of sediment, I may also recommend that you install an in line filter somewhere before the supply lines that lead to your washer. A whole house filter is a wise choice for this. This will prevent you from having frequent fill problems. I hope you find this information helpful.
Posted on Oct 02, 2008
Hello, I'm having problems with my dryer. I have a GE Profile Harmony Dryer and its not drying like it should, I have to run the cycle 4 or 5 times for it to get hot and dry the clothes... It also has...
The first thing to do is ensure that the outlet air vent is not clogged with lint, socks, or other obstructions. It may be clogged at a point outside the dryer, so you might have to move the dryer out of the way, then use a flashlight and mirror to look into the vent.
If it is not clogged, then the problem is likely the heating element or heat sensor.
Jul 13, 2011 | GE Profile Harmony DPGT750EC Electric...
My Profile Harmony wont fill. I have done the start up test and when it gets to checking water system it wont go any further. I have unpluged it and checked hoses and screens but it wont fill. Now what?...
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Jun 16, 2011 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Do the profile washers have a inlet filter for cold water.Hot water comes in fine.Cold very slow
check the cold water hose the screen in the hose to the cold water,selenoid may be clogged or have hard water deposets,just clean out see if this helps
Jul 03, 2010 | GE Profile WPRE6100G Top Load Washer
I have a GE Harmony top loader washer all digital. My washer will not drain throught the drain hose. I have to lower the hose to the floor for the water to come out any ideas
Your pump might have something in it. I got a shoestring out of one the other day. Remove the front panel and inspect the pump.c8963d3.jpgbottom right of the photo is that clogged pump, The top does not pop up. The front panel comes off.
Mar 17, 2010 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
Error message only prior to the rinse cycle,not filling correctl
The cold water solenoid valve seems to have failed on you. They're easy to replace and can be purchased at any appliance parts company
Jun 15, 2009 | GE Dryers
GE Profile Harmony
1 press power ( to wake up washer)
2 press Home ( it may already show HOME)
3 press HELP
4 press and hold MY CYCLES and BACK (for 3 to 5 seconds)
the service mode diagnostics screen will come up
it will show what errors are recorded..( if more button is displayed then also go to next list)
be sure to write them down exit will clear the codes and run a test
Let me know what the errors are I can help..
Mar 16, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Ge Profile Harmony Washer doesn't drain properly.
It sound like you have a blocked pump. Remove the pump from the machine and check where do you have this clogged, inside the pump or in one of the pipes connected to it. Good luck!
Aug 16, 2007 | GE WPGT9360EPL Top Load Washer
Washing Machines Logo
130 people viewed this question
Top Washing Machines Experts
