Question about Miele Novotronic T1520 Electric Dryer
MIELE T 1520
DOES NOT SPIN BELT OK LOUD NOISE
  • Miele Master
  • 19,396 Answers
I guess you already fixed it, sorry for the last replay,
however, if the belt did not spin that means that either the belt is slipped out, the motor had blown, or there is a problem with the drum bearing. Usually you need a technician to fix this.
Regards.
Posted on Dec 20, 2008
Loud grinding noise meile washing machine drum when spinning?
It can that the spin drum is touching the body if not you can leave it until its broken my machine is doing tht also
Sep 17, 2014 | Miele Washing Machines
Washer not working
The spinner's belt might be loose or broken, that's why it doesn't spin... Open the back part and you'll see inside the belt and the motor that makes the noise.
post me results...
Feb 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Why does Miele w2515 makes loud banging noise when it is about to spin?
See if you can level out the unit. Sound like the case is responding to un-even pressures.
May 23, 2014 | Washing Machines
Loud thumping noise in spin and smell of rubber with smoke when door opened
there are diffrent kinds of front load units some have rotor and stator issues you sound like yours has motor with belt possible bad belt or motor.
or its shaft and bushing is going.
Nov 02, 2012 | Miele Novotronic Premier 500 Front Load...
Loud rattling sound top of engine near or below the alternator when idling, goes away if accelerator is pressed
Hello: Remove the serpentine belt, see if the waterpump pulley wobbles/makes noise when you spin it. If thats not it then start the engine, belt still off see if noise is there also while engine is running see if vthe crankshaft pulley wobbles. Also check the A/C compressor pulley (engine off, belt off) spin it by hand and check for noise and wobble. If all the previous is ok then it could be the balance shaft front bearing and or the timing chain.
Oct 18, 2011 | 1998 Buick LeSabre
Wahser makes loud noise trying to stop spin cycle It seemed to spin ok and agitate but made terrible noise when trying to stop
Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing. but more than likely its the brakes, or the belt itself ,, a solinoid signals the machine to stop which in turn applies brakes just like a car only smaller, when these wear they tend to do the same as a car and squeal , its just an indication your machine is up for some maintenance,
Jul 25, 2011 | Washing Machines
Help - Miele Dryer Model T9800 problem!
The belt is most likely broken. The front drum bearing seal may have worn out and caused this to happen. Call Miele. You'll be better off.
Feb 18, 2010 | Miele T9800 Electric Dryer
When entering spin cycle, making a loud noise. I
Check your belt it may be lose. A lose belt will cause a squealing noise and the machine spin slower or take time to come up to full speed
Oct 09, 2009 | Fisher and Paykel GWL11 Top Load Washer
Runs but does not spin
If it still makes noise, the motor is probably OK and only a belt has failed.
Removing any access panel will probably confirm this.
Look for shredded fragments of a belt and empty pullies.
This shouldn't be an expensive fix.
Aug 27, 2008 | Miele T4423 Dryer
CHANGING THE BELT
Did you check the brush roll, the ends maybe aren't turning freely. May have to replace it, (Part # R98Z6064) I assume you put the correct belt on it (Part #S01Z6000). Are the sides ok where the brush roll sits in?
Mar 04, 2008 | Vacuums
Miele Novotronic T1520 Electric Dryer Logo
256 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
