Question about Samsung HLR5067WX 50" Rear Projection HDTV
Turning of and on continually!!
I'm having the same sort of problems with my Samsung 50" HLR5067WX/XAA. I bought this tv on ebay refurbished (bad move I know, never again). It worked fine for a little bit. Then I had the whole red/blue color swap and it would turn itself off then on, then off then on, etc...over and over until I had to finally unplug it to turn it off. The green light on the front would keep blinking and making noises. SO...I contacted a repair guy, seemed ok. He picked up my tv and I believe replaced the lamp and digital board. after $570. I got my tv back. It worked ok for the couple of minutes he was there. Then it started turning itself off and on again. I think the color were ok but it was hard to tell since it didnt stay on very long. Frustrated the repair guy came back.He replaced the color wheel. After $200 my tv was back. It seemed to work for longer, picture fine for almost 45min!! Then it did the same old thing turning itself off and on. It has been about 5 months since I last had it non-repaired. I'm frustrated and the repair guy only has a 90 day warranty. Are these problems common? What should I do? Please Help!!!
    Top Expert:
  • Samsung Master
  • 43,901 Answers
The power supply is failing
Posted on Mar 04, 2017
5 Suggested Answers
video-tek
  • 150 Answers
SOURCE: My Samsung 50" DLP HDTV keeps humming when the DLP lamp comes on.
Hi, you have one of two problems, either the color wheel is going or one of the cooling fans are going, the color wheels are a very common problem in samsung dlp`s, sorry I can`t nail it to a specific part but I`d bet it`s the color wheel as they are notorious for failing in samsungs, video-tek
Posted on Mar 26, 2009
  • 3 Answers
SOURCE: Green Plaid then Vertical Lines, Failure of hard controls, Analog Board?
You are absolutely correct, When anyone complains of vertical lines or bars, the next step is to see if it happens on only digital inputs ( digital board ) , only analog inputs ( analog board ) , or both ( DMD board ) .
Analog board can be purchased at www.partstore.com ,
Posted on May 24, 2009
localwonder
  • 6784 Answers
SOURCE: Samsung DLP seems to turn itself off
HI, this is a weak power board that is causing this shutdown. there is a faulty IC on the board that is unable to correctly distribute the necessary power throughout the set at this time.
Simply replacing the power board will fix this issue. This is not a do it your self so, we recommend a professional service tech for this repair.
Posted on Jun 07, 2009
Slinteriors
  • 8617 Answers
SOURCE: samsung HLR5067WX/XAA DLP picture freezes and
The analog board is usually at fault when that happens with that model.
Posted on Oct 06, 2011
Samsung 50" plasma HPS5033X/XAA shut off and will
HGi:
This model is nortorious for Y-sustain board failure, replace the Y-sustain board and you should be good to go. The Y-sustain board is the one while standing with back off the set is the board on the left side of the television.
Jul 05, 2011 | Samsung HP-T5044 50 in. Plasma TV
My wife bought a 46"
Take the tv aparts.Check the power supply board first for dying capacitors parts,check all over the power supply board for dying capacitors,it all bulges up or puffing up on it tops,than it is ur tv power supply board problems.That the board,where the power a/c cord plug into it.If no bulging or puffing up dying capacitors.Than problems ur tv have are the dead 2 long boards call the LCD inverter boards.These 2 long LCD inverter boards are in the left and right both sides of the tv.These 2 long LCD inverter boards,job it to help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a those 2 refurbishes long LCD inverter boards for the replacement or the refurbish power supply board for the replacement.
Feb 06, 2011 | Samsung Televison & Video
Flickering screen, loud buzzing sound, self boot down.
Color wheel bad. Makes rumbling sound. Bad bearings. Has to spin about 10,000 RPMs and sync to DLP chip. Here: https://www.encompassparts.com/webwiz/wwiz.asp?wwizmstr=WEB.SEE&partnumber=5933777&smodel=HLR5067WX/XAA
May 01, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
My Samsung 50'' DLP msg "Check Fan No. 3"
You can attempt to remove the back cover, but there is a very delicate mirror in the back. I'd just move it away from the wall, used compressed air to clean out the fans, and put everything back together. Just make sure you don't damage the color wheel or light engine.
Feb 04, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
My samsung tv hlr5067wx/xaa screen turns black, sounds is fine. if i turn it off for awhile i can get picture for a few minutes, but it goes back to black screen
I suspect the lamp is failing on your TV. The lamp replacement code is listed on the side of the TV on a sticker that is orange and white. It will start with BP96-. The lamp code is crucial on these older Samsung DLP's because they used quite a few different styles. Please take a few moments to rate my answer. Thank you...
Nov 19, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
I just bought a used HCN4226wx/xaa, the green and
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 15, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
SAMSUNG TV WONT TURN ON JUST CLICKS
I just fixed this very same problem. The capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Sep 24, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Mar 17, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung HLR5067WX 50" Rear Projection HDTV Logo
59 people viewed this question
Jerry Greenberg
Jerry Greenberg
