Question about Compaq Presario 5000 PC Desktop
Front cover Removal
How do I remove the front cover?
    Problem Solver:
  • 7 Answers
The colored front piece snaps off. Take a screw driver and carefully pry it. Snaps are at the top, around the drive bays, and at the botton. It would be easier to unscrew the case around the PC first. Make sure you unplug the PC first.
I am assuming you bought a new flashy colored replacement? If you are looking to get inside the PC then you unscrew the 2 screws on the back right, or right and left side, they will look different then the other screws, and slide off the case.
Posted on Oct 02, 2008
Front seal replacement 5.9 cummins
Hi Dale, I'm glad to help! Below is the removal procedure for the front crankshaft seal on your 5.9 cummins engine. Hope this helps and have an awesome day!
REMOVAL
  1. Disconnect both battery negative cables.
  2. Raise vehicle on hoist.
  3. Partially drain engine coolant into container suitable for re-use (Refer to 7 - COOLING - STANDARD PROCEDURE).
  4. Lower vehicle.
  5. Remove radiator upper hose.
  6. Disconnect coolant recovery bottle from radiator filler neck and lift bottle off of fan shroud.
  7. Disconnect windshield washer pump supply hose and electrical connections and lift washer bottle off of fan shroud.
  8. Remove viscous fan/drive assembly. (Refer to 7 - COOLING/ENGINE/RADIATOR FAN - REMOVAL).
  9. Remove cooling fan shroud and fan assembly from the vehicle.
  10. Remove the accessory drive belt (Refer to 7 - COOLING/ACCESSORY DRIVE/DRIVE BELTS - REMOVAL).
  11. Remove the cooling fan support/hub from the front of the engine.
  12. Raise the vehicle on hoist.
  13. Remove the crankshaft damper and speed indicator ring.
  14. Remove power steering pump.
  15. Remove accessory drive belt tensioner.
  16. Remove the gear cover-to-housing bolts and gently pry the cover away from the housing, taking care not to mar the gasket surfaces. Remove crank seal dust shield with cover.
  17. Support the cover on a flat work surface with wooden blocks (Removing Seal from Cover), and using a suitable punch and hammer, drive the old seal out of the cover from the back side of the cover to the front side(Removing Seal from Cover).
Apr 10, 2014 | 2004 Dodge Ram 2500
Tip
Maytag Square-Front (1998) and Sloped-Front (1999) Dryers Front Panel and Top...
Most of the internal components of Maytag Square-Front (1998) and Sloped-Front (1999) Dryers can be accessed with the removal of the front panel and lifting of the top cover. The top cover can only be lifted after the front panel is removed. Make sure that power to the machine is disconnected prior to servicing to avoid the risk of electric shock.
The first step is the removal of the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly. Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top cover is held on each side of the cabinet by hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top cover lip. Open the door then lift the front of the top cover and tilt it toward the rear of the dryer.
The internal components of the dryer can now be accessed. Reinstall the top cover and the front panel in reverse of the removal steps.
This procedure is also applicable to Maytag Neptune Front-Load Washers. The only difference is the dispenser bezel removal.
on Apr 28, 2010 | Maytag Neptune MDE4000 Electric Dryer
Tip
Maytag Neptune Front-Load Washers Front Panel and Top Cover Removal
Most of the internal components of Maytag Neptune Front-Load Washers can be accessed with the removal of the front panel and lifting of the top cover. The top cover can only be lifted after the front panel is removed. Make sure that power to the machine is disconnected prior to servicing to avoid the risk of electric shock.
The first step is the removal of the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly. Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the machine.
Remove the four screws securing the dispenser bezel to the top cover then lift the bezel off. Open the door then lift the front of the top cover and tilt it toward the rear of the machine.
The internal components of the machine can now be accessed. Reinstall the top cover and the front panel in reverse of the removal steps.
This procedure is also applicable to Maytag Square-Front (1998) and Sloped-Front (1999) Dryers (Maytag Neptune Dryers). The only difference is the dispenser bezel removal.
on Apr 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
Do you need to remove oil pan to remove timing chain cover on a 2000 Cavalier 2.2?
no, here is the procedure. Please let me know if you have more questions.
REMOVAL & INSTALLATION
2.2L Engine
  1. Remove the serpentine belt and tensioner.
Although not absolutely necessary, removal of the right front inner fender splash shield will facilitate access to the front cover.
  1. Install a suitable engine support fixture.
  2. Remove the engine mount assembly.
  3. Remove the alternator rear brace, then remove the alternator.
  4. Remove the power steering pump, then position it aside with the lines still attached.
  5. Raise and safely support the vehicle.
  6. Remove the front two oil pan bolts.
  7. Remove the crankshaft pulley.
  8. Unfasten the front cover-to-block bolts and then remove the front cover. If the front cover is difficult to remove, use a plastic mallet to carefully loosen the cover.
Aug 27, 2011 | 2000 Chevrolet Cavalier
Need to put passenger miror on. i need help to show me how to take the door panel off.
Section 01-05: Trim, Interior 1998 Windstar Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 01/22/1999 Trim Panel, Door Front
Removal
  1. Remove door latch cover by prying from top edge and pulling trim free of retaining clips and sliding trim away from latch.
  1. Remove portion of armrest containing door lock switch and window regulator control switch (14529) by pulling straight up.
  1. Remove rear view outside mirror mounting hole cover assembly by prying at top and pulling upward to release double-sided clip.
    Trim Panel
    Item Part Number Description 1 23942 Front Door Trim Panel 2 56908-S58 Screw (1 Req'd), Right Door 56906-S58 Screw (1 Req'd), Left Door 3 18B978 Radio Speaker Grille Name Plate 4 56911-S58 Screw (1 Req'd) 5 17D720 Cover Assembly Rear View Outside Mirror Mounting Hole
  1. Remove screw attaching front door trim panel (23942) to front door (20124) under switch plate.
  1. Remove two screws located at bottom of front door trim panel.
  1. Disconnect the door lock switch (14028) and window regulator control switch electrical connectors.
  1. Remove door window regulator handle if equipped by unsnapping and pivoting away the handle cover from base to expose retaining screw. Remove screw from the door window regulator handle.
  1. Pull front door trim panel from the top to release hooks from front door .
  1. Remove front door trim panel.
Installation
  1. Replace any bent or damaged fasteners.
  1. Follow removal procedure in reverse order.
Body Side
Removal
  1. Remove door handle retaining clip by sliding a shop towel between handle and door trim. With tension on the cloth, pull one end of the cloth so it slides between the handle and the door trim. If handle does not come out, reverse direction.
  1. Unfasten 13 christmas tree fasteners using double-acting spring-loaded trim removal tool and pull body side trim panel from body side door.
  1. Remove forward and rearward mating sections from under window trim.
Installation
  1. Replace all christmas tree fasteners.
  1. For installation of handle, install clip to handle, then push handle onto shaft to snap in place.
Back
Removal
  1. Disconnect rear window defroster wires.
  1. Remove the liftgate window garnish moulding as described.
  1. Remove screws attaching liftgate handle to liftgate and liftgate inside trim panel.
  1. Using Rotunda Windshield and Moulding Trim Removal Kit 107-R0401 or equivalent, pry pushpins retaining liftgate trim from the liftgate.
  1. Remove liftgate trim.
Installation
    Liftgate
2010&c18=modelyear&c35=wsm%2ctrim%20panel%2c%20door%2csww%2c01-05%2cremoval%20and%20installation&s=1366x768&c=32&j=1.3&v=y&k=y&bw=995&bh=405&ct=lan&hp=n&[aqe]
Mar 07, 2011 | 1998 Ford Windstar
How do i change the belt on a model No. DE308 maytag dryer
Hi
To change the belt you'll need to remove the top paenl and then remove the drum and you would be able to see the belt. You can disassemble it by the following procedure--
Drum Removal / Roller / Glide Access--
  • Disconnect power supply to unit.
  • Remove Top Cover and Front Panel,
Top Cover / Door Switch / Front Panel /Gasket Removal-
1. Disconnect power supply to unit.
2. Use a plastic putty knife to depress the locking clip between the Top Cover and Front Panel.
3. Disconnect wiring from the Door Switch.
4. Depress the locking tabs on switch side and remove through the front.
5. Remove two screws, 1 each side, from the back flange of the Front Panel.
6. Tip Front Panel back and remove. Rotate Front Panel to the back side and remove gasket.
Hope this helps...
Daniel
Sep 20, 2010 | Maytag Dryers
Need a diagram for installing a drivers side electric power mirror on a 1995 mercury villager van
here's 1996, all I have. Please rate.
Mirror, Power — Outside Rear View NOTE: This procedure applies to both RH and LH power outside rear view mirrors.
Removal
  1. Remove the front door trim panel (23942). Refer to Section 01-05 for the removal procedure.
  1. Remove the two outside rear view mirror inside mounting hole cover screws and the outside rear view mirror mounting hole cover (17K709) from the front door (20124).
  1. Remove the wire clip.
  1. Disconnect the power outside rear view mirror electrical connector.
  1. Remove the three power outside rear view mirror bolts and the power outside rear view mirror.
Installation
To install, reverse the removal procedure. Tighten the three power outside rear view mirror bolts to 3-4 Nm (27-35 lb-in). Glass, Outside Mirror
Removal and Installation
Refer to the glass replacement procedures in Manual Mirror for power outside rear view mirror glass (17K707) Trim Cover
Removal
  1. Remove the front door trim panel. Refer to Section 01-05 for the removal procedure.
  1. Remove the two outside rear view mirror inside mounting hole cover screws.
    Remove the outside rear view mirror mounting hole cover.
Installation
To install, reverse the removal procedure. Mirror Control
Removal
  1. Use a small flat-blade screwdriver to pry the power outside rear view mirror control switch from the instrument panel (04320).
May 13, 2010 | 1995 Mercury Villager
How to remove the front panel of a maytag neptune gas dryer
Removal of the front panel requires the removal of the top cover and the console. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Remove the 2 screws attaching the top cover to the rear of the dryer then slide it rearward to clear the screw head from the top cover flange and lift the cover off the dryer cabinet.
Remove the screws securing the heater PCB board and disconnect the black and white wiring harness connectors from the board.
Remove the four screws attaching the console to the washer cabinet and rotate the console down to remove it from the dryer.
Remove the four screws attaching the top of the front panel to the cabinet and the two screws at the bottom of the door opening.
Pull the front panel forward and disconnect the interior light wiring harness then lift the front panel off the tabs across the bottom and move it away from the dryer.
Reinstall the front panel, the console, and the top cover in reverse of the removal steps.
Apr 21, 2010 | Maytag Neptune MDG5500AW Gas Dryer
How you take off the front bumber
have 96, 95 similar
Section 01-19: Bumpers 1996 Villager Workshop Manual
REMOVAL AND INSTALLATION Bumper and Bumper Cover Front
Removal
  1. Raise and support the vehicle.
  1. Remove the RH and LH front wheel (1007).
  1. Remove the RH and LH front fender splash shield screws. Remove the RH and LH front fender splash shields (16102).
  1. Remove the four front fender brace screws.
  1. Remove the two front fender brace nuts.
  1. Remove the two plastic screws.
  1. Remove the seven clip buttons located under the front bumper cover (17D957).
  1. Remove the RH and LH front turn signal lamps (13369). Refer to Section 17-01 for the removal procedure.
  1. Remove the four front bumper cover brace bolts.
  1. Remove the front bumper cover from the vehicle.
  1. Remove the two front turn signal lamp wire harnesses from the front bumper (17757).
  2. Remove the eight front bumper bolts.
  1. Remove the front bumper from the vehicle.
Mar 02, 2010 | 1995 Mercury Villager
How do I remove front cover of Fujitsu indoor unit
THE INTAKE GRILLE REMOVAL
(1) Open the intake grille.
(2) Pull down the knob.
(3) Lift the intake grille upward, until the axle at the top of the intake
grille is removed.
THE FRONT PANEL REMOVAL
(1) Remove intake grille (Reference the intake grille removal.)
(2) Remove four screws.
(3) The thumb is hung on the lower part as shown in the figure,
and it pulls to the front, pushing [-] mark , and bottom hooks
(two position) is removed from wall hook bracket.
(4) The front panel bottom is pulled to the front, and bottom hooks
is removed indoor unit.
(5) The front panel is pulled to the front, raising the upper surface,
and a front panel is removed.
Feb 23, 2010 | Fujitsu 18R1 Air Conditioner
Compaq Presario 5000 PC Desktop Logo
417 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
