I had a paper jam Pushed on the on/off button.Ipulled out the paper and on/off button is flashing but the printer does not shut off
I did exactly what the washingmachine repairman told me to do .Pull the plug on the printer shut off the computer than turn everything back on and voila :PROBLEM SOLVED!! Thanks again Klaas W
Posted on Oct 02, 2008
Is there anyone who can help with this?
just follow the set of procedures HP recommends for clearing a paper jam, and it should work again. They have some documentation and videos online, here is one of them
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00441807&lc=en&cc=us&dlc=en&product=441125
Jul 31, 2012 | HP Office Equipment & Supplies
My HP officejet pro all in one 8500 wireless keeps flashing "clear paper jam then push ok"..... I have pushed ok, it will run its course and then flash the same message. I have tried turning it...
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Mar 28, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Paper jam
It is possible that you have not removed all of the paper in the printer. Try to open the printer and see if there are any paper or paper residue inside.
Jan 12, 2010 | Computers & Internet
Epson Stylus RX500
Turn printer off.
Hold down the Stop, B&W, and the Color buttons.
Press the ON button.
The LCD screen should flash 3 times.
Release the Stop, B&W and Color buttons
Press the Color button again.
Then turn the printer off and back on.
Sep 17, 2008 | Epson Stylus RX500 All-In-One InkJet...
My printer is flashing "shutting down" and the on button is flashing. I had to correct a paper jam, after that, it will not do anything.
what is the printer model? also, check where you removed the jam from, and make sure any jam sensor flags are not out of place...
Jul 11, 2008 | HP Office Equipment & Supplies
Printer Jam Message
hp officejet 4100 all-in-one
Feb 25, 2008 | Office Equipment & Supplies
Canon PIXMA MP160 showing paper jam, but none
hi
just recently had these problems
symptoms:
LED flashing E3 code and alarm light was solid. But dissapeared when opened the coved and came back on when closed the cover.
Also the when the cover was open the inks did not slide out to the left and stayed to the right side.
There was no paper jam, but error said paper jam.
Solution:
1. I took a thick piece of paper, from like a paper folder ones, thick enough to go in the printer and not curl up when pushed..
2. turned off the printer and turned it back on.
3, while printer was turning on,and makings sound as it does normally when turning on, I pushed through the piece of paper and the rotors stoped for a millisecond.
4.the rotors started again and pushed out the paper by it self with out my force.
5. I let the printer get started. and then turned it off and then on.
6. this solved all of my problems.
this was the first problem ever with this printer in 3 years.,preety good printer.
good luck...
Feb 24, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon s520
The number of orange flashes between green flashes indicates the type of error, as outlined below. Check the cause and take the appropriate action. Two flashes: Out of paper, paper jam or paper feed error Replace the paper correctly and press the RESUME/CANCEL button. If paper has jammed in the printer, clear the jam and press the RESUME/CANCEL button. Three flashes: Paper jam If paper has jammed in the printer, clear the jam, replace the paper in the printer correctly and press the RESUME/CANCEL button. Four flashes: Empty ink tank One of the ink tanks is empty. Replace it. If all of the above won't help, unplug the printer from the power cable, wait a while, and plug in. If that didn't fix you, I guess it's time to get in touch with canon, or a repair lab you trust. Good luck
May 16, 2006 | Canon S520 InkJet Photo Printer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
