Question about Microsoft Windows Vista Ultimate Edition
Cannot remove nero software..
Hi guys.
i want to know if ccleaner is the same as nero tool cleaner..if yes hw do u use it to remove my unremovable nero software.
thanks
    Sergeant:
    Champion:
  • 317 Answers
Not at all, CCleaner does a LOT of stuff, Nero only does some software and patches, personally I use CCleaner.
Posted on Oct 02, 2008
How to clear recently closed
I recommend the free CCleaner. You can download the latest version at Filehippo. Note: If you have any of the following programs, uncheck them on the Cleaner Applications tab: Superantispyware, Malwarebytes, Windows Defender, MS Management Console.
Do the following, once every 3 months, on each Account...
1. Start CCleaner.
2. Cleaner - Click "Analyze", then, once the progress bar is 100%, click "Run Cleaner"
3. Registry - Click "Scan for Issues", then, once the progress bar is 100%, click "Fix selected issues" (Yes, Save, Fix All Selected Issues, OK, Close) - (Repeat step 3. until no more issues are found)
Jun 26, 2014 | Computers & Internet
How do I delete IOLO from my comput
Hi John Morgan,
Install Ccleaner in your system, After Installation, Open Ccleaner and follow these steps:-
1.Go To The Tools Section
2.Search the IOLO in that list
3.Double Click It to Uninstall From Your System.
Or Use JRT Tool To Unistalled & Remove all adware & toolbars From Your System.
Thanks & Regards
Bheshaj Taksali
Jan 10, 2014 | Ahead Software Nero 6.0 (60045) for PC
Cn u guy's help me hw cn i download my nokia ovi
Welcome to Fixya. I hope you may download it from below link
http://europe.nokia.com/apps-maps-and-more/nokia-life-tools/main
Let me know if it worked. Thanks for joining us.
Have a nice day.
Apr 08, 2012 | Yahoo Computers & Internet
I've used several different kinds of softare, nero, windows, real player and none of the cd's I burn will play in a stereo. The dvd's I burn using the same burners work just fine. they are cddvdw...
Hi Serinity,
    • Download and install CCleaner (free) from Piriform
    • Run the cleaner to remove old un-needed temp files
    • Select the StartUp tab and look for any programs that you know you installed but no longer use or need, and disable them. Caution, do not disable any system files unless you absolutely know what they do and that you do not need them.
    • Run the Registry cleaner, when asked if you want to backup the registry, select YES, and save to a file you will remember just in case. I have used this program hundreds of time on many different system and it has never caused a problem, but you want to be safe, backup the Registry.
    • If asked about a particular file that it wants to clean, select "yes to all"
    • Reboot
Windows should reinstall the drive when the computer boots back up.
If this does not resolve your problem, try the following.
If you take all these step and you still can not burn a CD, chances are your CD burner componet needs to be replaced. Good Luck.
  • If this helps resolve your issue, would you please rate the solution
Dec 28, 2010 | Computers & Internet
How can i remove the fatal error in my nero 10
hello welcome to fixya,first uninstall your nero from control panel->remove programs
and then install nero 10 again from the cd you have or setup file you have and everything will be fine
Jul 24, 2010 | Ahead Software Nero Express 6.0 (NERO6OEM)...
Trying to uninstall nero 9 trial version
CCleaner is a Good Program which removes usless codes from computers and does other things
Aug 15, 2009 | Computers & Internet
I'm Trying To Delete The Program Nero 9 and it Saids This Program Requires The File Advrcntr4.dll,Which Was Not Found On This System
HI,
First download and install revo uninstaller from this website:
www.revouninstaller.com
next after you install it you will see Nero 9 in that and just click on it and then click on Uninstall at the top click next the applications uninstaller will begin then you need to uninstall it.If it says that it cannot be uninstalled or says that dll was not found cancel it and then on revo uninstall again click on next it will scan for registry files then you need to check all bolded registry items and then click on delete.Make sure you only tick bolded items dont remove then ones which are not bolded this will crash your pc.
After you are done with that then it will scan for left orver files and you need to click on slect all and then click on delete.Thats all you will be able to reinstall Nero;
Aug 02, 2009 | HP Pavilion a6400f Desktop PC -...
My software just stopped woring, i double click to open it and nothing happens.
Which Nero versions that you used? If you have CCleaner, simply run CCleaner after uninstall any software like Nero for the best results, it will cleans all your PC activities or Windows System. Try to run registry cleaner before installing Nero. Then, download and run "Nero General Clean Tool", it helps you to thoroughly clean all the files that other versions of Nero have left on your computer. When you make a new Nero installation on your computer, you may see messages about incompatibility or possible inconsistencies with the Windows registry since earlier Nero versions have left disconnected files, which I think cause this type of problem. Then you try to install it again and lets see. Try these, it may can help you to solve your problem.
May 15, 2009 | Ahead Software Nero 7 Essentials Suite...
Re-nero 6 buffer does not start.
Hi, there thanks for the email reply with offer of premium service, i have managed to solve this problem now and would share the experience with this forrum. Here is how it goes. I got this solution from another forrum which i tried and worked. 1. download utility-tools cleaner from Nero web and erase the old nero 6 with this cleaner, 2.then re-boot pc, 3,after this re-install Nero 6 and bingo it worked wonderfull. it takes 11 min, for Dvd and 8 min for cdr burning, which is just about normal.
My advice to my friends on this forrum is in addition to above process is to avoid buffer fluctuation is to clean the system before burning, ie use ccleaner for rubbish files then advanced windows care 2,registery cleaner, both programs are free for home use, Or similiar programes, another point to remember is to close down all unneccesary programms running in the background to have more ram to speed up burning process. I hope this would be helpfull to any of my friends on this forrum if you have similiar problem with Nero 6 burning.
Good Luck
Shamsher.
Sep 29, 2008 | Ahead Software 8 Ultra Windows
Unable to uninstall Nero-
Vista is very picky - and you have to have at least version 7.5.9.0, or newer (but, with my vista 7.5.9.0 worked). Since you have nero-7 you can download the latest and use your key from your current nero-7 cd.
Mar 30, 2008 | Ahead Software Nero 6.0 (60045) for PC
Microsoft Windows Vista Ultimate Edition Logo
59 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
