Back to:
Tags:
Alpine MRD-M1000 Car Audio Amplifier
What ohm load is best?
By pandamama - usenet poster
is the lowest ohm wire configuration gonna get the best sound out of your amp? ive got a 1 ohm stable amp, is that what i wanna go with?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 30, 2008
Not Rated (0)
lalchan_maha
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
lower the impedance the less current the amp will use
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on what ohm load is best?:
I don't want to Accept this solution
Solution #2
posted on Aug 04, 2008
Not Rated (0)
weslion
Rating: 0%, 0 votes
well no not necessarily. There are many amps on the market these days that will go down to one ohm but reach their max output at 2. In fact most JL Audio amps produce the same output from 4 down to 1 to allow for many different kind of subs and wiring configurations. Get the specific specs on your amp. Thats always the way to go.
Thank You!
Solution #3
posted on Jun 16, 2008
Not Rated (0)
tech48
Rank:Guru Guru
Rating: 92%, 210 votes
The lowest impeadance rating is not always the best way to go if you want your amplifier to last for a long time. I have been repairing amplifiers for over 15 years and have seen many amplifiers that claim to be 1 or 2 ohm stable that are really only stable for a short time. They overheat very quickly. Most amplifiers are mounted in places that get very little ventilation, this is a major cause of them overheating. By connecting your amplifier in a 1 or 2 ohm configuration does not improve the quality of sound, it only increases the power output. Every time you lower the impeadance by half (from 4 ohms to 2 ohms) you double the amount of current being pulled thru the amplifier at whatever volume level you test it at. This may be nice for having a louder system, but it will wear out the components inside the amplifier faster. The only amplifiers I would trust to use at 1 or 2 ohms would be U.S. amps or Phoenix Gold.
Thank You!
Solution #4
posted on Jun 12, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
my friend has an amp that is a 1 ohm load but the way he has it wired its getting an 0.5 load it sounds great but in time his amp will fry
Thank You!
Solution #5
posted on May 24, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
If you want the best sound quality you would usually go with a higher ohm load, but if you are looking for loud, go with the lowest ohm load rating on the amp.
Thank You!
Solution #6
posted on Jan 19, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
the lower the ohm the harder the amp has to work..
Thank You!
Solution #7
posted on Mar 25, 2007
Not Rated (0)
Mitco39
Rank:Wiz Wiz
Rating: 82%, 75 votes
The lower impediance generally gives you a larger THD value... which means more distorion. Look at the specs on the amp.
Thank You!
Solution #8
posted on May 30, 2006
Not Rated (0)
Duke
Rating: 0%, 0 votes
To get the best from your amp, yeah, you want to use the lowest impedance rating that it can handle. you just have to be weary of the wiring and the power that you will be delivering to your speakers/subs at that level?
Thank You!
Can you Help with these Car Amplifiers problems?
Car Amplifiers
you can request for more solutions by requesting solutions...
Car Amplifiers
burned 2 circurt on the power cable side on the top and on...
Car Amplifiers
need help with installing this amp
Car Amplifiers
code for a remote control universal for a pelisys tv
i asked you a question about the mtx 1501d. i'm not...
Loading problems.
Repair Service
Find Car Amplifier Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
