Question about Sigma 18-200mm f/3.5-6.3 for Nikon
Dust inside my sigma lens
I bought a sigma 18 - 200mm dc lens for nikon almost half year ago and found there is dust inside the lens. My warranty will valid untill April 21 2009. Do you think it should be covered by warranty? I have three Nikon compatibale lens and non of them has dust inside. I mean it is not possible to cause this problem by normal use, am I right?
  • wj_xin Oct 03, 2008
    Thank you very much commedic, I contact sigma and also send a pic of the lens with dust inside to them. they ask me to send the lens to their service center. Yes, I am using the lens on my nikon d50 digital camera.
  • Anonymous Mar 26, 2014
    it is stuck up at 80, the lock will not go back to 18 so it seems impossible to use, please help
  • 667 Answers
Zoom lenses are kind of like a tire pump. They will draw air in (and out) when zoomed. The longer the throw of the zoom, the more air moved. You can try Sigma, they may cover it, but...
A small amount of dust should have no effect on the quality of your images, but I would be concerned about it being transferred to your camera's image sensor over time. ( I assume you are using the lens on a digital body )
Posted on Oct 02, 2008
D5100 won't power on with Sigma macro lens atttached
This is not a solution but the same kind of problem.
I just bought a Nikon D5100 and found that my Sigma 105mm macro has a problem. The camera will not power up, but if I turn it on, untwist the lens and then twist it back in, the camera powers up. If I leave it for a few seconds, it powers down again. Provided I keep taking photos, it works, but this is not acceptable because it can take several seconds to get a focus on a close-up, and by time I get the focus, the camera powers down again.
I never had any problems with this lens on my Nikon D80. I also use several lenses, all of which work well with both cameras. It's only the Sigma that has the problem. And I did clean the contacts with a proper contact cleaning solution and a swab, but still no joy. My lenses are made by Tamron, Pro Optic, Nikon and Sigma, and the only problem lens is the Sigma.
Feb 29, 2012 | Nikon D5100 Digital Camera
Is the sigma 18-200mm DC f3.5-6.3 compatable with nikon d50?
Assuming you get one with a Nikon mount, yes. Sigma makes their lenses with a variety of mounts to fit different makes of cameras. A lens with a Canon mount, for example, will not fit on a Nikon. A lens with a Nikon mount is fully compatible with the D50.
Mar 22, 2011 | Sigma 18-200mm f3.5-6.3 DC Lens Minolta...
How to dismantle the lens front element. My reason is to clean the dust inside. Thanks.
I strongly recommend you do not try this unless you are trained in camera/lens repairs and have the correct tools and solutions. Too many things that can go wrong, not the least of which is introducing more dust into the lens than you manage to clean off. Also, most lenses have a lesser or greater amount of sealant which may potentially be ruined. Lens elements are carefully aligned, and any misalignment on re-assembly will negatively affect focus in any lens, more so in a zoom. If the dust is affecting your photos, I suggest you have a local Sigma authorized camera repair shop clean it. And, most will have a limited warranty of 30 or 90 days. I speak from experience ... ::--))
Oct 07, 2010 | Sigma 18200mm f3563 DC OS for Canon
Focus ring will not move below 5 feet. Can't focus on things closer than that - AF or MF.
There's nothing you can do yourself to fix it, the lens should focus down to 0.4m (15").
The lens comes with an automatic one year manufacturer's warranty, which extends by another three years if you registered the warranty so I suggest that you return the lens to Sigma for repair.
Note that any evidence of misuse or unauthorised repair attempts automatically invalidate the warranty.
Mar 14, 2010 | Sigma 30mm f/1.4 EX DC HSM for Sigma
Fitting a Sigma Lenset to Nikon D40
You have to make sure you bought the sigma lens with a NIKON mount. Sigma makes a Sigma mount as well as a Canon mount, of course neither of those mounts will work with your camera. Also you must also make sure your lens is the Sigma 70-300 HSM (/Hyper Sonic Motor) or it will not AF on the D40. I just bought this lens from Abes of Maine and I love it on my D40.
May 27, 2009 | Nikon D40 Body Only Digital Camera
Matching 2 brands
Simga makes lenses to fit several different makes of camera bodies including Canon and Nikon. I'm assuming your Sigma lens has a Nikon mount, if so there are some adapters, but they may not work like you want - not all functions may work properly thru the adapter. For best results you should return or sell the lens and get one with the Canon mount.
Dec 26, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Sigma 70-300 F4-5.6 APO DG MACRO for Nikon AFD Focusing problem
had this lens for my Pentax and used it for more than 10 years without trouble.
Have you got the lock on? should be a little button on the side.
Has it been dropped, maybe damage to the threads inside.
If its still under warranty then take it to the place you bought it from with all its paper work and get it checked out.
Apr 07, 2017 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
135-400mm lens on nikon d40
Unfortunately, this lens is not supported by the D40 due to Nikon's unfortunate decision to leave out the autofocus motor from this camera.  This is why I tell folks not to waste their money on the D40 - access to the many, many, many lenses that Nikon has made over the years, many of which are available used for a substantial savings, is lost on this camera.  The only Nikon lenses that work are AF-S lenses, and some third party lenses that have their own internal motors.  I got a list of Sigma lenses that are compatible with the D40 for you:
The list of compatible Sigma lenses for the Nikon D40 as of the current date is as follows:
  • 10-20mm F4-5.6 EX DC
  • 12-24mm F4.5-5.6
  • 17-35mm F2.8-4 DG
  • 50-500mm F4-6.3 DG
  • APO 50-150mm F2.8 EX DC HSM
  • 70-200mm F2.8 DG MACRO
  • 80-400mm F4.5-5.6
  • 100-300mm F4 DG
  • 120-300mm F2.8 DG
  • 300-800mm F5.6 DG
  • 14mm F2.8 EX
  • 30mm F1.4 EX DC HSM
  • 150mm F2.8 EX DG
  • 180mm F3.5 EX DG
  • 300mm EX DG
  • 500mm EX DG
  • 800mm f5.6 EX DG
from here:  http://www.imaging-resource.com/NEWS/1177682545.html
Sorry for the bad news.  The cheaper thing at this point may be to sell the D40 and get a D80.  I personally have a D70S, but that is no longer made.
Dec 06, 2007 | Sigma Zoom Tele 135-400mm f/4.5-5.6 APO...
Sigma 55-200mm F4-5.6 DC
The D40 will only AF with lenses that have their own focusing motor (Nikon AF-S and Sigma HSM). This lens will not focus.
Aug 10, 2007 | Sigma 55-200mm f4-5.6 DC Lens
Sigma 18-200mm f/3.5-6.3 for Nikon Logo
636 people viewed this question
Top Sigma Cameras Experts
M_Butkus
Steve
Are you a Sigma Camera Expert? Answer questions, earn points and help others
