Question about Akai LCT3785TA 37 in. LCD HDTV
Tv wont turn on
I have an akai 37 inch hdtv lcd was working fine but started having problems turning it on u could push the power button light would flash but tv not come on thewn we noticed that you could pull power plug wait for standby light to go off and plug it back in and press button it would turn on then 1 day it would not do that then i noticed that i could pull power and plug back in while holding power button and it would come on now nothing but i won the tv in a contest so what iu need to know is where can i get a new power supply or the parts possibly to rebuild the 1 i got i found several domed caps in my turn on portion of my power supply they look suspicious im gonna try and replace them but u know how things are i have a little knowledge of electronics so im not just totaly technotarded lol.thanks for your help if you can.
  • 2 more comments
  • populas Oct 05, 2008
    its me i posted this problem and ive solved it if this happens to u just remove the power supply board and look at the capacitors you'll need to unscrew the heatsink bridge the small 1 there are 2 of them look for domed or cracks in the top of the capacitors replace as needed i had to replac 4 of them if parts are hard to get u can exceed the voltage of the cap by a little but not the uf i got my parts at a local radio shack cost was about $7.00 us and my time wich was less than an hour. the 4 caps that i replaced wer 2@ 10 volts 1000 uf replaced with 2@ 35 volts 1000uf and 2@ 35 volts 220 uf replaced with like caps tv turns on and works fine again.
    replace capacitors in power supply board just the domed or suspicious looking 1's
  • psampson May 04, 2009
    I have an Akai LCT 3785TA LCD flat panel TV. I turned it off one night and next morning it will not turn on when I tried the remote or the switch on the side panel. When I disconnect the power cable and wait for the red light to go off and then reconnect the power cable and use the remote again it operates just fine until I turn it off and try to operate it again. I have to go through the whole process with the power cable again. Any solutions to this prob?
  • phlbartley May 05, 2009
    I bought my akai LCT3785TA a llittle over a year ago. Been working fine no problems. Now today its a black screen. Green power light comes on and then nothing. remote and side bar buttons wont work to turn off. Can not find anyone to fix this.
Posted on Feb 01, 2009
    Problem Solver:
  • 21 Answers
Hi
Please go to ebay and buy your power supply board:
AKAI LCT3785TA POWER SUPPLY BOARD MLT386X
Posted on Dec 31, 2008
My LG 37LG50 TV wont turn on ?
Are you certain the replacement power supply is good? A defective main board or power supply can cause this problem.
May 04, 2013 | LG 37LG50 37 in. LCD HDTV
No power on vizio E371VL
Vizio TV model E371VL turned on ok and had tv show on ch.4.
Turned on the DVD player and put movie dvd in and closed tray.
We have done thhis numerous of times and never had a problem.
This time " HDMI " was showing on top right of black screen,
then " No Signal " came up on screen, then went completely black screen. Called Vizio, they had me power off and unplug set.
Push and Hold power button on TV for 30 sec. to reset.
Replug set and Vizio (lighted) on lower front of set lighted normally dull orange. Pushed power button on remote and when set did not come on, then push main power button on side of TV. Nothing, no White " Vizio " from orange light. Is this a power supply (0500-0412-1020) problem ? Thanks, Sidney (sidneysites@yahoo.com)
Feb 17, 2013 | Vizio E371vl 37 Inch Class Lcd Hdtv
My akai flat screen tv is not turning on. the red light at the bottom of the tv is on and when the tv comes on the red light turns green and in a few seconds the tv comes on, when i press the power button...
i have one of these akai 27 inch with dvd, i had a similar issue i found a power supply at auction and exchanged it and it works fine now, normally with this symptom your power supply is fualty. if the light goes green and you have no picture then you know other boards are fualty
Jun 04, 2010 | Akai LCT3285TA 32 in. LCD Television
37 INCH LCD MAGNAVOX TV WILL NOT TURN ON. MUST BE
This problems,very common in LCD tv,after the tv was in used about a year or two.The new technalogy LCD tv don't handle heat very well,not like the old CRT Tube Tvs.The power supply board tend to have bad capacitors componnents leakage,that bulges up it top or puff up gases escape,that why it take times or couples pushes to the power botton to turn the tv on.U know basic electronic's,and have soldering tools and solders?Take the tv aparts,check for these bad capacitors,that bulges,puff up in the power supply board and replaced them,than ur power will work normal again.Or tries Websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Apr 29, 2010 | Philips Magnavox 51MP392H Rear Projection...
Delay light is flashing on tv, but wont turn on. Not sure if problem is tv or remote? Dont see light on remote when push in buttons?
The problem with the unit is power supply part number,MLT166A.If you can not find one you can try to fix yours.First you have to take out power supply,Replace 3 electrolytic caps EC18,EC19,EC20 all are 1000mf at 16 volt.Then find Z3 on same board,it is a 27 volt zener diode 1 watt,part number 1N4750A.Put board back in then unit should work.
Oct 03, 2009 | Akai LCT3701AD 37 in. LCD Television
There is NO SOUND from the LC3760N 37 inches TV after I turn it on. I tried these buttons: increase volume button, decrease volume button, and the mute button. The TV was working last nigth; I don't know...
The problem was caused by a loose conexion. One of the cables that goes from the DirecTV box to the TV was loose. The problem was FIXED by pushing the cables to make sure there was a good conexion.
Jun 10, 2009 | HP LC3760N 37 in. LCD HDTV
I have Akai 37" LCT TV. When I turn it on, no picture is getting displayed.
I NEED A INSTRUCTION MAUAL FOR THIS Akai LCT3701AD 37 inch Flat Panel LCD HDTV with Built-In DVD Player, ATSC Tuner and HDMI THANKS BLUE
Dec 17, 2008 | Akai LCT3701AD 37 in. LCD Television
Akai tv
The power supply most likely failed on your LCD.
How old is your LCD?
Jul 26, 2008 | Akai LCT3201TD 32 in. LCD Television
Philips 17PF9936/37 17'' Flat HDTV slow to start working
mi tv turns on but only in color blue,next tv turn off red light apear one time and second time flash twice,whit mi remote control power on tv turs on ,then whit mi remote control send change chanes or any other funcion the tv turns off,letme now if you solve yor problem ,and i apreciate if you have some tips for me,thank.
Jan 09, 2008 | Philips Epic 17PF9936-37 17" Flat Panel...
Akai LCT3785TA 37 in. LCD HDTV Logo
517 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
