Question about JVC AV-27530 27" TV
TV JVC 27530 C
Hellow .
Excusme my english is not good,
I have a problem whit one jvc tv not Power.
I found the IC 901 ( REF: G 5624A) Bad, The Diode D907.
and The 78L05 (ic 704 ) i replaced them but i do not get power.
Please any ones has a Electronic Diagraman or tell me what can i do.
Thank you.
Cesar Alvarez
tecnicesar2@gmail.com
tecnicesar2@yahoo.com
  • Cesar Alvarez Oct 18, 2008
    Ok.
    i could not get Help , but i found the problem .
    Is necessary change the ( 7805 ) IC 704, and the transistor Q 58 ( this tr sen de signal to Ry 901.
    Whit this te Tv is power on , Sound Ok, But display only yellow not picture.
    Any body Know what the problem is.
    Thank You
  • 104 Answers
Download the instructions manual from here:
http://resources.jvc.com/Resources/00/00/95/YA050Bien.pdf
looks like the power supply is still not repaired.Check internal fuse also
Posted on Oct 02, 2008
Tv has no picture
try adjust screen in flyback, if you see a white line in bottom, the vertical ic have cold solder or is bad.
Apr 28, 2010 | JVC AV-27530 27" TV
My JVC 27" can not be turned on or off with the remote or the on an off button. Any ideas?
try all in one remote/it can be the infrared on tv not picking up signal/point remote does light flash on tv ?
Dec 23, 2009 | JVC AV-27530 27" TV
My jvc tv has good sound but nothing showing
if when you turn the set on the display does not light up at all there is a good chance the display has gone, if you ring jvc they should be able to giv you a price of a new dsplay i will warn you it wont be cheap.
Mar 08, 2009 | JVC AV-27530 27" TV
Why is the color red is gone
this is because of the color control circuit for the red , its most likely an IC that controls red has failed or even a bad resistor , capacitor , ect .. in that circuit will need replacing
Mar 06, 2009 | JVC AV-27530 27" TV
How do I get the dialogue removed from my TV screen?
Hi and welcome to FixYa,
Offhand, it would appear that the 'Closed Caption' has been enabled in your TV. This can de disabled in the MENU/Settings. A more detailed procedure would be available in the owner's manual or pls post back to confirm if your TV is a JVC AV-27530.
Good luck and thank you for using FixYa.
Feb 20, 2009 | JVC AV-27530 27" TV
Tv shutting off timer light blinking
The problem you describe is not really related to a timer function being set. The unit is in shutdown and the light is blinkng to let you know there is a problem.
There are several possible causes. the most common is a failure in the vertical deflection circuit due to a bad vertical IC and possibly a capacitor, zener diode and resistor.
Feb 19, 2009 | JVC AV-27530 27" TV
TV Value
under $100.00
Aug 04, 2008 | JVC AV-27530 27" TV
JVC AV-27530 27"
WHEN YOU TURN THE SET OFF,SOUND LEAVES BUT PICTURE STAYS ON--SOUNDS LIKE THE MAIN POWER RELAY IS STUCK-NEEDS TECH TO REPLACE BUT SHOULD BE A CHEAP JOB!!
Dec 03, 2007 | JVC AV-27530 27" TV
Tv turns to stand by at least 3/4 times/hour.Then you have to turn it off and on before it works again.
it might be due to remote also like weak battry,buttonloose,loose contact. if it is ok then check for loose contact in system control ic ckt.pr print loose. as you say tv works ok so failure of components is rear. good luck.
Sep 27, 2007 | JVC AV-27530 27" TV
JVC i art 32" flat screen
Ur video ic inverter board is dead.
U need a new one.
May 13, 2007 | JVC AV-27530 27" TV
JVC AV-27530 27" TV Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
