Question about HP Deskjet 6940 InkJet Printer
Streaky print i just installed my new hp deskjet 6940 with brand new printer ink. i tried printing in color (approximately 6 pages) and still, the words comes out gray and streaky.
  • HP Expert
  • 141 Answers
Defective carriage. machine is brokeded (pronounced BROKE-DEAD). part unavailable, cannot be fixed, if machine is still under warranty then either take it back where you bought it or contact HP for replacement.
Posted on Oct 02, 2008
How do I print in color from Dell vostro 220 to HP Deskjet 6940 printer
1. Check if the printer has colored ink.
2. Check the settings. Make sure that the colored ink is activated.
3. Update the driver for your printer. Scan your computer with RadarSync.
Let me know if you have any questions.
David
Apr 08, 2013 | Dell Vostro 220 Desktop Computer
HP 6940 won't print black-new cartridge installed-prints color but no black
In all likelihood your print head has become clogged at the black ink outlet. Be aware that printheads can BURN OUT if you keep trying to print and there's insufficient ink reaching the printhead. The ink flow is relied upon to prevent overheating of the tiny resistors at the printhead. Best bet is to remove the cartridges from the printhead and then remove the printhead and try to clean it in warm water. You will find many youtube videos on suggestions for cleaning the printheads on HP printers. Do a google search for your model. If all else fails you can order replacement printheads for the part that has failed. They are not cheap so price compare. Oftentimes they will cost nearly as much as a new printer!
May 16, 2012 | HP 6940 InkJet Printer
HP Deskjet 6940 Series Printer: I'm on my second brand new color cartridge for this printer. The printer simply doesn't recognize that the cartridge is installed. Sometimes the color cartridge...
if you are not buying NEW OEM cartridges they will never work properly. and once installed if they are oem they will not work the second try either .
Nov 16, 2017 | HP Deskjet 6940 InkJet Printer
My hp deskjet 6940 inkjet printer doesn't show me level of ink in cartridge
Print a diagnostic page If the steps above have not helped, print and evaluate a diagnostic page to see if the cartridges or the printer is causing the problem.
  1. Make sure the printer is on and loaded with unused, plain, white paper.
  2. Press and hold the Power button and then press the Cancel button. Release both buttons. The diagnostic page prints. Figure 1: Power and Cancel buttonsc00584735.gif 1 - Cancel button 2 - Power button
Step 4: Note which cartridges printed which areas of the diagnostic page You must identify which cartridge printed which part of the diagnostic page, so that if you find defects on the page, you will know which cartridge is the problem. However, you can install different combinations of print cartridges in your printer, and different cartridge combinations print different diagnostic page patterns. Your diagnostic page may not look exactly like the picture below, but the right and left cartridges will print in the same areas of the page no matter which cartridges are installed. Figure 2: Diagnostic page layout (the patterns in each area may look slightly different on your page)c00584715.gif 1 - Printed by the right cartridge 2 - Printed by the left cartridge NOTE: If you are printing in reserve mode (one cartridge is missing), the missing cartridge's area of the diagnostic page will be blank. Step 5: Check ink levels NOTE: If you have installed a refilled or remanufactured ink cartridge, or a cartridge that has been used in another product, the ink level indicator is inaccurate or unavailable. Look in the middle of the diagnostic page. The bars with "E" (for "empty") and "F" (for "full") at each end show the ink levels in the cartridges. As ink is used, the solid color changes to a faded color. Figure 3: Left (tri-color) cartridge almost full - right cartridge emptyc00235259.gif Figure 4: Both left and right cartridges almost fullc00235260.gif
Feb 22, 2011 | HP Deskjet 6940 InkJet Printer
Just changed my black ink cartridge and it won't print. color still prints fine
Ink cartridge has a plastic seal protector that has to be removes prior to installation in compartment. Ascertain that the seals are removed from color ink cartridge. Also, ensure that the device is firmly straped in place to achieve print.
Feb 03, 2011 | HP Deskjet 6940 InkJet Printer
I am engaged in a colored printing project on my HP Deskjet 6940, and am having trouble with the quality. I am using 8.5" X 11" paper, (inkjet/laser brochure-flyer paper, 96bright, 45lb). The project...
This could be a problem with the paper your using. Try another brand of paper that is recommended only for the inkjet printer. Paper that is meant for Laser does not always work will with inkjet printers as it is made to handle toner and not ink.
Some paper I suggest is the HP Brochure paper C7020AC 48lbs which is recommended for your printer by Hewlett Packard. If not available try and see if you can get something similar that is only for inkjet printers. 8.5 x 11 in, 48 lb, 100 sheets C7020AC
Jun 04, 2010 | HP Deskjet 6940 InkJet Printer
Im having HP Deskjet 6943, I have install black and colour catridge. I print test page its coming ok. But when i try to print colour in MS Word, Excel, Powerpoint i not getting colour, what could be the...
please printer driver setting .. give a print ...select your printer and go to printing preference then go to color tab check for any setting like print in color in gray and print in color ....... select print print in color ......and try ....
Dec 29, 2009 | HP Deskjet 6940 InkJet Printer
New tri color ink cartridge will not print red
Probably bad, there's actually no way to check ink levels.
Jan 22, 2009 | HP DeskJet 960c InkJet Printer
HP Deskjet 6940 not printing after replacing ink cartridge
My HP Deskjet 6940 is not printing. The color (left) low ink light is dark and the black (right) low ink light is flashing. I replaced the black ink cartridge with a new one but the low ink light continues to flash. No tears/rips in the circuit strip and all the copper leads appear to be connected
Sep 29, 2008 | HP Deskjet 6940 InkJet Printer
HP Deskjet 6940 printer - printing but no ink transferred to page itself
I have the same issue, but with a HP DJ 3550, I´ve heard about the data execution protection (DEP) migth help when changing the options, but still have to try it
Jul 14, 2008 | HP Deskjet 6940 InkJet Printer
HP Deskjet 6940 InkJet Printer Logo
148 people viewed this question
Ben Johnson
