Question about SanDisk Sansa E280 MP3 Player
E280 I loaded 7gb of music on my sansa e280. When I turned it on it went into the refresh databases mode and it will not finish because it goes into a screen with vertical lines and stays there. You turn it back on and it goes thru the same process. I tried the hold in record switch trick but it gives me an exception error(no disk). I finally got it to format thru windows but I still heep getting exception processing message 0xc0000013. Can yoiu give any help?? Tom
  • 758 Answers
Please visit this forum and follow the steps there...
http://www.anythingbutipod.com/forum/showthread.php?t=11233
I hope that help..
Please rate accordingly
Thank you
Computerrep
Posted on Oct 03, 2008
Stucked at Refresh database
When the Sansa reads "refreshing database," what it is doing is going through all the songs you've loaded on to it, pulling out the "tag" information (Artist, Album, Song Title, Genre) so it can add this information to its own database which it uses to display the songs to you in its menus.
If it gets stuck during this process, usually it's because of a corrupt song file, or a song file in a format it doesn't understand.
Note that the e280 is only able to play MP3 and WMA audio formats. If you've loaded a different type of audio file onto your Sansa, you'll need to remove them.
If the songs you've recently loaded have all been MP3 and/or WMA, you may have loaded a corrupted file onto your Sansa. Try removing the songs you recently added, and see if the problem goes away.
Feb 27, 2010 | SanDisk Sansa E280 MP3 Player
My e280 is frosen on Refresh Database. What do I
Mine did that, and I had to reformat. I believe this is how I did it (note, mine is not a Rhapsody type, that one is different in many respects):http://www.sansacommunity.com/forum/thread/11221/How-to-format-an-e200/
Jun 08, 2009 | SanDisk Sansa E280 MP3 Player
Refresh Database
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Thank you
Computerrep
Dec 22, 2008 | SanDisk Sansa E280 MP3 Player
Sansa e280 goes to glitch screen after trying to refresh database
if the bar in the middle of the window has stripes its normal and it will keep doing it no-mater wat you do
Oct 26, 2008 | SanDisk Sansa E280 MP3 Player
Sana e280 frozen screen reads Refresh Database
put the player in recovery mode by placing the hold slide button at the top of the player so that the red showes, held down the record button while turning on the player. upon connecting the USB cable the unit will go into the recover mode. Go to my computer and look for the drive which states "16MB Format" and copy the firmware files into it. Disconecting the cable after the files are copied will cause the player to reload the firmware. The player will restart and then shut off because of the Hold button position. Slide the Hold button back into normal mode and push the menu button to restart. The unit will power up and display the language settings. I went to the settings menu and changed the player USB setting to USC. I then placed the player in recovery mode again and went to the MY Computer again and set window to show hidden files. This allowes windows to see the database drive. I then ran chkdsk on the database drive which found a lot of crossed linked files. This then allowed me to delete all the files in the database. Upon comming out of the recovery mode the unit restarted normaly.
You can get the firmware at this site. http://mp3support.sandisk.com/firmware/e200/e200v101.02.18a.zip
Oct 11, 2008 | SanDisk Sansa E280 MP3 Player
Bad Tracks
For the bad tracks go Under Settings, look for Mode or USB Mode. Put the unit in MSC (if that's available) or Rhapsody.
Connect it to the computer. See what driveletter it is :F: Sansa E280...G: Sansa E280... whatever it is.
Click Start/Run and type in chkdsk F:/f (or G: or whatever the letter is) . That will check and may fix the bad files.
I hope that helps
Please rate accordiingly
Thank you
Computerrep
Jun 18, 2008 | SanDisk Sansa E280 MP3 Player
Sansa e280
Each time I start my Sansa e280, it goes into REFRESH DATABASE mode which takes up to 8 min to complete. Once the R.B. is comleted, the player works OK. How can I disable this operation?
May 30, 2008 | SanDisk Sansa E280 MP3 Player
Refreshing database
perform recovery mode on the player and connect the player to thec omputer. when it is connected and the player is detected as a removable disk drive namely 16MB Format. Create a file inside the drive named sansa.fmt and that would format the player and remove any corrup files that you may have transferred to the player.Recovery mode is Hold Switched Enabled+Record Button+Menu button.
Dec 12, 2007 | SanDisk Sansa E280 MP3 Player
Sansa e280 froze
It is probably because you have folders inside of folders inside of folder... i just had the same problem and copied all the songs in a folder into the main folder IE
dont do this
sansa>music>artist>album>music file
do it like this
sansa>music>artist>file
Dec 04, 2007 | SanDisk Sansa E280 MP3 Player
Very weird...
'Refresh Database' doesn't mean everything is erased. It only means it's writing the progress that you made, onto the computer. It stays on 'Refresh Database' for about maybe 5-10 minutes. It refreshes its database every time you disconnect your MP3 player from the computer. What it does when you disconnect it from the computer is it saves any unsaved changes made to it and overwrites the memory or data.
Oct 28, 2007 | SanDisk Sansa E280 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
79 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
