Model ew1273. Why does the machine always have drainage problems?
When I wash my clothes, there is a loud noise before the machine starts. If I don't hear the sound, the machine wont drain water out of the machine? How can I fix this? I have tried calling maintenance numerous times and they always tell me I have the wrong setting which isn't the case. help!
Re: model ew1273. Why does the machine always have...
Possible that the drain valve is locked or clogged and so does not open up on the cycle. it is best to check the voltage on the drain pump while it is on the drain cycle to confirm the case as you will need assistance with a multimeter. Also if you are able to clean the pump it will be useful to confirm in case the pump is clogged.
This issue could be caused by a number of things. It is possible that the clothes are not properly balanced in the wash drum, causing them to wrap around the agitator. It could also be a problem with the agitator itself, or with the transmission.
The bearing in the drum has failed and it's always noiier as it spins faster as there is more debris being thrown around inside the hardened steel casing of the bearing. Bad news is that's a write off. Uneconomical repair. It will tear its self apart shortly, probably leaking grease into the wash and leaving black marks everywhere, oor the drive belt will come off, or the drum will impact the front gasket and fill the drum with smoke. Any way you look at it, it's almost certainly going to destroy a load of washing. Throw it away now before it wrecks your washing
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary. If there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Please do accept this solution and revert for further assistance.
