Question about Motorola Mobility DRC800 Universal Remote Control
PIP DOESN'T WORK ON MY REMOTE drc800
My tv is a sony and has pip capabilities. I have installed a cable box that uses the above remote but, the remote will not activate the PIP.
  • Anonymous Feb 21, 2009
    I have a DELL LCD which has 2 hdmi plugs, digital, analog and the control has about 18 different inputs. I have PIP on the remote and you can get the squares of different screens but with using Inisight cable you only get a picture on one. When we used an antenna before cable we got PIC the way you should.
I just looked this up myself. It said you have to have two tuners to get PIP. You can have PIP with another source like vcr or DVd with the TV.
That is all the manufacturer said.
Posted on Nov 07, 2008
I'm trying to hook up picture in a picture with my TV using the HD dual tuner DVR DC H 6416 converter box. Is there a place that I can connect a cable to the box that has video out to use individually for...
The TV requires two inputs to use the PIP function. Your setup box Has multiple outputs, but the same picture comes out of all of them. The only way you can use PIP in your TV is to split the signal and connect it to both the set-top box and the TV. However; you will not receive the additional channels that the setup box picks up unless you use 2.
Some set top boxes already have PIP built in. If it does you can view a PIP display even if your TV does not have that feature. Because the cable box has 2 tuners built in they are designed to do two different things at one time. If yours has PIP capability they will proudly and prominently tell you about it in the instruction manual..
Nov 15, 2014 | Televison & Video
How to program ONN (code?) urc with Motorola sat box
If you want the Motorola remote to control the TV or another device, then you should be looking at the instructions for the Motorola satellite box. You'll find a list of codes in the back of the book for the TV brands it supports.
If the code for your particular TV or other device isn't listed then there's a way to use the remote to search its entire code base. This can sometimes provide the answer where a certain TV chassis is sold under several different brands.
The Motorola DRC800 universal remote instructions can be viewed here
Motorola DRC800 User Manual
Sep 21, 2014 | Televison & Video
I have a sony (model KP61V75) a split screen came on (two pictures) and I cannot figure out how to get it back to one screen. Im going crazy!
Some television remote controls have a PIP OFF button, while others only have a PIP button that needs to be pressed repeatedly until the PIP/Twin-View window disappears.
NOTES:
  • Some Sony rear projection televisions have a FLASH FOCUS button that will turn off the PIP/Twin-View feature.
  • Some Sony universal remote controls, if programmed to operate a Sony TV, can disable the PIP/Twin-View feature by pressing the REC or ENT button.
  • If the original TV remote control is not available or is not functioning properly, auto programming the television tuner orperforming a power reset may deactivate the PIP/Twin-View feature.
  • If pressing the appropriate buttons on the TV remote control does not work, then the PIP/Twin-View window might be from a two-tuner cable or satellite set-top box. If this is the case, use the remote control provided with the set-top box to remove the PIP/Twin-View window.
Jan 25, 2011 | Sony Televison & Video
WILL THE SONY RM Y195 CONTROL MY SHARP LC-19DV27 LCD TV???AND IF SO WHAT CODE DO I PUT IN THE REMOTE
According to Sony guide, this remote is not capable of controlling any TV other than Sony although it is capable of controlling multiple other components brands for cable boxes, satellite receivers and more.
Aug 09, 2010 | Sony RM-Y195 Remote Control
Don't have original remote control. Somehow, a window for PIP opened, and I can't get it to turn off. Have a new sony remote RM-V310A, but the PIP button won't activate the remote. Any...
Many TV functions can be controlled from the on-screen menus using buttons on the TV itself. These include all kinds of settings however Sony did not include PIP in these menus. Therefore a valid remote is required to operate PIP. One thing you could try is removing the cable from the secondary input on the TV which provides the signal for the other picture. Without an input signal PIP may be disabled. Also, try buying a universal remote and setting the proper code for your TV. Original remote could be hard to find but remotes.com may have one.
Aug 05, 2010 | Sony KV-27S45 27" TV
Vizio remote
The remotes for the TV and Direct TV box are universal remotes that can operate very basic functions for whatever else they are programmed to control. If you can program the TVs remote to operate the Direct TV box it will basically only control power and channel. Maybe something else, but not much. The same goes for the Direct TV remote. It will control basic functions on the TV; power, channel & volume. Best bet would be to purchase a universal remote that can learn functions from the original or just keep both remotes available by the TV.
PIP (Picture In Picture) - Your television should have the capability because it has two built in tuners. It can show two channels at the same time or show one channel and one video source (whatever is connected to the audio/video inputs). However, because you are using DTV (Direct TV) you are very limited because you are not using the built in tuners on your television. You should be able to see one picture from the DTV channel and one from lets say your DVD player. If your DTV box has two tuners built in then you should have the PIP capabilities from your DTV and not your television. I'm guessing your DTV is a single tuner (one satellite cable to your box). If you want to watch two different channels you'll need to either upgrade your box or attach another box to your television.
Option: you could also connect an antenna to your television this way you can use the PIP function. Obviously you'll only be able to view whatever local stations you can get with the antenna. Depending on where you live you might or might not have a lot of channels to choose from.
Apr 19, 2009 | Vizio L32 32 in. LCD HDTV
Pip pictture doesn t turn off
I had the same problem many times, and I don't have the original remote. Go into your menu options and select Auto-Program. It will run through all your channels, but when it is done, PIP will be off !! I have PIP!
Jun 28, 2008 | Televison & Video
Remote Control Code for Motorola Cable Box
I have a Motorola cable box and used code # 051. Works great. Can't find a code for DIGISTAR tv though. If anyone has one, shoot it to me at deannescollard@hotmail.com.
Feb 22, 2008 | Motorola Mobility DRC800 Universal Remote...
Pip is stuck and i don't even have a pip button on my remote!
The problem was solved by using the TWC cable remote control and selecting "TV" on the top and the press the big blue "Select" button. DO not forget to put the remote back into "CBL" mode. Apparently this is a hidden feature, which works even on TVs, which officially do not support PIP. I works only with the one tuner, video 2 and video 3 but not video 1.
Dec 05, 2007 | Sony KV-32S26 32" TV
Televison & Video Logo
208 people viewed this question
Top Motorola Mobility Televison & Video Experts
Are you a Motorola Mobility Televison and Video Expert? Answer questions, earn points and help others
