Question about Hotpoint Washing Machines
How should the drum door be fasened is there an order of how the clips should be put on? 9537
    President:
  • 1,462 Answers
I think you mean the tub front held on with clips.
put into position and fit first clip at top. fit clips at each side then fit a clip at bottom. after that just work your way round
Posted on Oct 02, 2008
Inside the drum one of the tumblers is loose how do you tighten it up?
You can tighten those baffles by getting to outside of drum to thighten the screws that hold them to drum. to get access to outside of drum;
Remove screws from door hinge
remove screws from other side of inside door as they are exaclty opposite the ones for hinges
pull off from panel by putting putty knife/screwdriver in seam between front panel/cabinet just below the sloped part of the top and pop off front panel
in the upper corners of the top/front panel is a clip that looks likea inverted "7" or if ya will a up side down "L" remove screws from the clips and remove the clip
now ya can raise top to get to outside of drum
rotate drum by hand in CLOCKWISE direction to turn drum so ya can get to each baffle
Thanks for using FixYa.com,
Gene
Aug 22, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Replacement of a drum baffle, how to?
inside the door thier is 2 screws that hold the hinge to the front panel remove those and the 2 on the other side gently lift and pull the door off. pull the front panel off and look and find directly below the top a clip that holds down the top to the front panel remove those clips (one on each side) pivot up the top and rotate the drum by hand so that the baffle that needs to be replaced is on the top. replace baffle and reassamble in reverse order
Jul 19, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Is there a way that my 9537 control can be modified to connect to my computer so that my Amateur Radio program (Ham Radio Deluxe) will turn my rotor to the direction of the station I want to contact? Bill...
There is a software program call proximus that will allow you to control your IR receiver with the necessary remote codes for the 9537. it\'s a pain to figure out . but it does work. I use mine with Orbitron satellite tracking software to follow Ham radio satellites.
Jun 08, 2011 | Channel Master (9537) Remote Control
The drum on my wma 40 seems to go tight any ideas why
may have something stuck between the inner and outer drum...... socks tights and womens skimpies very easily slip down at the bottem door seal.... afraid the machine needs a total strip down if this is the case. remove the door and front panels, the drum has a front cover held on by a number of clips..... remove all clips take cover off....find said item and put back together shouldnt take more than an hour.. if it isnt that,.then rear bearing could be shot at,, sorry
cheers
Mar 24, 2011 | Hotpoint WMA40 Front Load Washer
Water Pik Ecoflow w/ hand held is leaving at the swivel point. What do I need to do?
Hello
Rossouw q, plumber
If its leaking at the point u can unscrew it u must ....
Step1, unscrw the head and take out the rubber. go to plumbing shop get a new rubber of that size and thread tape. Step 2, put the rubber in and fasen it up. if that dosent stop the leak put thread tape on the thread CLOCKWISE and fasen it again and bobs ur uncel it should be fixed
Please rate my advice. thanx and pleasure helping u out.
Jun 30, 2010 | Water Pik Waterpik& Ecoflow Fixed Mount...
Need help with installing belt in Maytag Electric dryer
if not able to remove rear panel,you will need to start,like most models,take top cover off and hinge back to wall then remove frt cover including door as a whole assy. lift up drum put new belt on drum ( and position in same area as old belt,it will have marks on drum from where original belt was on drum) then put rest of belt over mtr pulley and then idler pulley, turn drum by hand to align belts and put it back together in reverse order
Jul 28, 2009 | Maytag PYE2300AY Electric Dryer
Put dryer belt on maytag dryer
generic maytag dryer belt replacement
type 1:older models by Maytag with lintscreen under door
  • unplug dryer
  • remove 2 screws from under front panel
  • tilt front panel up from the bottom and unclip top
  • remove door switch wires
  • set front panel aside
  • remove front drum retainer 2 screws each side
type 2:newer models by whirlpool lint screen in top cover
  • unplug dryer
  • remove lint screen
  • remove 2 screws under lint screen
  • with putty knife or other blunt blade
    unclip spring clips at front corners of top panel
  • remove 1 screw each side of front panel 1/2 way from top
  • remopve door switch wires
  • tilt front panel down and unclip
all
  • withdraw drum forward
  • examine drum rollers for wear
    if worn or locked replace in pairs
  • examine felts and nylon glides(if fitted) for wear
    if worn replace
  • examin case floor for tensioner
    (sometimes broken belt ends pull the tensioner out of place its easy to see the slots on the case floor for the 2 feet and spring, looks like a power socket)
  • loop new belt around drum at wear mark of old belt
  • insert drum
  • loop belt around motor pulley
  • pull tensioner to end of travel against spring
  • loop belt around tensioner
  • relax tensioner
  • rotate drum by hand to make sure belt wont jump off
reassemble in reverse order
Oct 29, 2008 | Maytag Dryers
Clothes get caught between drum at front of dryer
the drum has either worn out its felt(front), a fabric bearing, or the roller(rear) bearings, or both, and dropped enough to make a gap. new rollers are3 about $15 /pair, felts between $13 & $90 depending on model.
Generic replacement is simple, and really while you got it apart, do both, the strain of twisting off axis will make the remaining good end fail shortly
The generic steps may not be correct for the actual dryer model.
Felt seal
for most dryers,
Go buy HiTemperature silicone adhesive (tube)
tools required couple pairs locking pliers/visegrips screwdrivers
Unplug dryer
remove the front cover, either
  • couple screws at the bottom and spring clips to pop off with a screw driver OR
  • couple of spring clips to hold the top lid on, then screws top and bottom of both sides
    examine the case to find the exact mounting
unclip cables from door switch
unhook drive belt from tensioner pulley
pull drum forward and out
remove old felt
scrape off old adhesive
put adhesive per instructions (some 2 surfaces some 1) on drum/felt
clip felt in place on drum with visegrip at 1 point
stretch felt around drum, gluing and clipping in place with vicegrips as you go
allow glue to set
Roller bearings
for most dryers,
tools required needle pliers/visegrips screwdrivers
Unplug dryer
remove old rollers:
  • pry triangular circlip from axle post
  • discard circlip
  • remove and discard roller
  • install new roller
  • install new circlip
    ALWAYS replace rollers in pairs
wow took longer to type than it actually takes to do it
Jul 22, 2008 | GE Dryers
Cylinder seal
for most dryers,
Unplug dryer
remove old felt
allow glue to set
Jun 04, 2008 | Maytag Dryers
Hotpoint washing machine WMA66
Thank you gittos73.
It's as gittos says. When you open the door and look inside, at the very top of the door is a white square. This holds the metal clip. If you push the little white dot in the middle of this clamp gently, it gives way and you will see the round metal clip that goes all the way round the door rubber (gasket). Remove this and you can put your fingers round the gasket and pull it toward you.
Then take the lid off the machine and you will see a 6mm nut with a spring behind it and a wire clip similar to the front one, going round the gasket where it attaches to the drum. This has a crosspoint (phillips type) head on it and you can get a small screwdriver into it and undo it all the way. Then slide the gasket off and it will come away.
Fitting it is the reverse but it is a little bit tricky as you have to get the gasket behind the lip to make the seal. Take your time and they will both go round properly.
Aug 03, 2007 | Hotpoint WMA66 Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
