Question about Canon Office Equipment & Supplies
CIR 2200 copier scanner cleaning? How do I do this?
How do I clean the scanner?
  • Canon Expert
  • 1,326 Answers
Is the copier displaying it on the display pannel? If so you need to clean the small piece of glass to the left of the copy board glass. Use windex or rubbing alco, if its dirty you most likely get lines on your copies when using the adf. Also you may need to clean the white roller on the under side of the adf. If you open the adf there is a green knobe toward the front and you can spin it and clean the white roller. That should do it for you. If not you can always turn that warning OFF in your user settings. Good Luck...
Posted on Oct 02, 2008
Minolta dialta di183 copier error code c06 50
C 0650 - Faulty scanner home position sensor.
Remove the glass and clean the home sensor.If the scanner moves smoothly remove foreign matter and other obstacles,clean the scanner rails,clean or change the scanner bushing.Place WD 40 oil on scanner bushings.
Dec 02, 2013 | Minolta DiALTA Di183 Copier
Error code E000202-001
The error code deals with the scanner unit / scanning lamp. Have you just cleaned the optic's???? Was the problem there before you started to work on it? Dos the scanner lamp turn ON? I the lamp dos not come on, you will need to replace the lamp and the lamp regulator PCB at the same time as a set. Very,very important... They need to be changed as a set. If you have a working parts machine, I would use the parts from the parts copier. Good Luck
Jan 27, 2013 | Canon imageRUNNER 2200
What is error 2200 why is scanner making noise?
The 2200 error indicates the scanner has stalled. Please refer to this article on 2200 Error on the Lexmark P4300 Series All-In-One. Hope this helps. Thanks.
Jan 17, 2011 | Lexmark P4350 All-In-One InkJet Printer
Canon ir 3300 error code display e000019-0000
It means that your waste toner box is full.
You can do the next:
On left side of copier, on lower left side you have small cover with screw.With screw driver unscrew it and remove cover. Remowe the waste toner box/container, and clean it, after you removed toner wash it with water and clean the inside and outside of box neck with alcohol to remove the antistatics. Place it back and restart the copier.
Mar 31, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Dear Sir in Canon IR 3300 Error code E00202-0002. What part is folty
the homeposition sensor not go on,the reder contoroler pcb faulty scanner motor faulty,
Nov 24, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Stylus 2200, "print test page" in menu, unclickable.
- System Preferences
- Print & Fax
- Select Epson Stylus Photo 2200
- Open Print Queue
- In the top right corner of the Queue window click the Utility button
- Epson Printer Utility will open where you can check the levels and run cleanings and nozzle checks, etc.
May 07, 2009 | Epson Stylus 2200 InkJet Photo Printer
Epson 2200 ink problems
get it serviced from a proper technician .the ink lekage had dameged the printer head which needs internal cleaning.
Aug 07, 2008 | Epson Stylus 2200 InkJet Photo Printer
SCANNING
Clean the glass surface with Isopropyl Alcohol (IPA). Dont use any other solvent. You can also use a well wrung wet cloth to clean the glass.
S. Mohan
Jul 23, 2008 | Umax Astra 2200 Flatbed Scanner
old marine
old marine
