Question about T-Mobile Samsung T429 Pay-As-You-Go Cell Phone - Blue
Cell phone will not hold a charge
I have a samsung t429. It doesn't hold a charge and I have replaced the battery already a few weeks back. Can you help me out what the problem could be? Thanks
5 Suggested Answers
zafarbabu
  • 12 Answers
SOURCE: cell phone charging
u have to try it once connect ur phone thu a cable and selet phone mode or pcsuit to see if its chargung ur cell or not
Posted on Feb 07, 2008
Bajanguru
  • 7752 Answers
SOURCE: cell phone won't charge/or hold a charge
you are not to keep a phone charging that long...only charge a mobile when the battery is completely dead that is the only way that you will have a good battery for a long time.
what you should do is try a new battery with the work and see if that helps other then that you will need to have the phone usb port service or checked.
Posted on Jun 23, 2008
  • 34 Answers
SOURCE: Samsung T429
K got it for you here is the site
http://www.phonedog.com/cell-phone-research/samsung-sgh-t429_user-manual.aspx
just click the download button and you got it. Good Luck!
Posted on Jun 30, 2008
SOURCE: unlocking code
First, insert a foreign SIM, then
Make Full Eprom Reset *2767*3855#
After Rebooting Mobile (it's automatic)
enter...
*7465625*638*00000000*00000000# (to change NCK code to 00000000)
then enter...
#7465625*638*00000000# (to permanently unlock the phone)
check the lock status...
*#7465625#
Posted on Oct 14, 2008
SOURCE: Samsung SGH-t429
I accidently locked my boyfriends sgh-t429 Samsung and i need to unlock it quick!
Posted on Nov 05, 2008
I have just bought replacement battery for my samsung c3050 which is not keeping its charge very long. The battery supplier advises to put phone in standby mode. What is this please?
the 3050 dosn't have a standby mode only an idle witch is the mode when you turn it on but dont access any af the features or web/calls you will probably find if you completly charge and discharge the phone a few times the battery will hold a better charge if not i'd send it back and ask for a refund as the battery is likely faulty
Sep 14, 2014 | Samsung C3050 Cell Phone
Need a unlock code for a samsung SGH T401G cell phone. (net10)
You can get samsung sgh-t429 unlock code from many source. First from your network provider, call them and request that unlock code but you must have a good standing account with them at least for 6 month. They also take charge from you for that unlock code. Second, you can buy samsung unlock code from third party sites. Good luck!
Apr 19, 2011 | Samsung SGH-T429 Cellular Phone
Lost back panel of phone where can I buy a new one
Parts for these phones, speciifically the back cover, are available right now on several sites including Amazon and Ebay. Here are a few links for you.
http://www.amazon.com/Samsung-Blast-T-Mobile-Battery-Cover/dp/B0012U4512
http://rover.ebay.com/rover/1/711-67261-24966-0/2?ipn=psmain&icep_vectorid=263602&kwid=1&mtid=691&crlp=1_263602&icep_item_id=270541987679&itemid=270541987679
 Hope these help!
Mar 20, 2010 | T-Mobile Samsung T429 Pay-As-You-Go Cell...
Samsung sgh m600 wont charge and does not hold a charge
try these steps..
1. try borrowing the same charger from a friend and use it to your phone.
2. try using your charger to a friend's phone.
if any of the two above won't work, go to your nearest service center they will tell you and help you fix your problem.
Feb 20, 2010 | T-Mobile Samsung T429 Pay-As-You-Go Cell...
Samsung SGH-T429 ERROR: 41000001
keep holding end when u turn it on
Sep 21, 2009 | Samsung SGH-T429 Cellular Phone
Need help with samsung t429 - unresponsive. no keys work
Hi. You can get tech assistance straight from Samsung by going to:
http://www.samsung.com/ContactUs/ContactUs.htm
Aug 03, 2009 | Samsung SGH-T429 Cellular Phone
SGH-T429 screen stays blank or dark
Friend, the problem is your LCD it maybe broken if it is then you need to replace it, and if not the flex connector is disconnected try to press tighten the LCD connector slot.to solve your problem
Jul 07, 2009 | Samsung SGH-T429 Cellular Phone
SGH-T429 freezes after period of time
the problem can be solved with a software flash.
Jun 16, 2009 | Samsung SGH-T429 Cellular Phone
My samsung tmobile comes on but then immediately says goodby.
make sure that it does not have water damage?! you can tell if you took the back cover where the battery does and see if you see and sticker that has red ink on it.
Most cellphone company put a water activated stick that will change color when it reacts with water?! and it will void your warranty
Dec 23, 2008 | T-Mobile Samsung T429 Pay-As-You-Go Cell...
Battery not holding charge
THAT IS AN ERROR ON YOUR BATTERY METER YOU NEED TO DO A HARD RESET AND IT WILL CORRECT THIS PROBLEM...*2767*3855#
Oct 28, 2007 | Samsung SGH-D900 Cellular Phone
T-Mobile Samsung T429 Pay-As-You-Go Cell Phone - Blue Logo
96 people viewed this question
Top T-Mobile Cell Phones Experts
Thomas Perkins
Thomas Perkins
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
