Question about Health & Beauty
Changing user settings on Conair WW67T scale
I want to change the height and age on a user setting. I have followed the instructions, but once the user settings are set, it will not allow me to change them.
  • 2 more comments
  • tleonard15 Feb 01, 2009
    Can't seem to change the settings
  • Anonymous Mar 12, 2009
    same here, no reset func?
  • Anonymous Mar 27, 2009
    I have the same problem with the WW33A  model
  • brutus25 Apr 10, 2009
    Thank you mrrealer.
    That is how I set my original settings last year but now that I am a year older, I wanted to change the age setting. The up & down arrows work to identify the user but I have pressed "set" and the arrows a hundred different times and they won't change a thing anymore with age or height.
1. Tap the scale
2. Wait for "0.0" display
3. Set
4. Use the up arrow then stop on the user you desire
5. Set
6 Using the up/down keys enter Height
7 Set
8 Using the up/down keys enter Age
9 Set
10 pick the little man or woman
11. Press SET - the scales will redisplay your profile settings for verification.
12. Wait Until the Display Goes Blank.
13. Tap the Scale.
14. Press USER, select desired profile, P-01 is the default.
15. Wait for "0.0" display
16. Step onto the scales and wait for all measurements to display
Posted on Jul 28, 2009
1. Tap the scale
2. Weight until it displays "OOOO"
3. Set
5. Hit set
6 Using the up/down keys plug in height
7 hit set
8 plug in age
9 hit set
11 hit set
12 wait
That should do it!
Posted on Feb 17, 2009
1. Tap the scale
3. Set
5. Hit set
7 hit set
8 plug in age
9 hit set
11 hit set
12 wait
That should do it!
Posted on May 06, 2009
How do I reset a user's height and age on Health o meter BFM884DQ1-60?
you have to hold down select and the number you want to reset. select erase and put in your own settings. Good luck
Jul 28, 2012 | Healthometer Health o meter Body Fat...
I have a Health O Meter HDM560. I need to reset the #1 and #2 users and start over, can you help me there is nothing in the manual about it I can find.
Current Instruction Manual for the HDM560 can be found here:
http://www.healthometer.com/Manuals/MANUALS/HDM560-05_43_41816518.PDF
For resetting it would be similar to the initial setting process. FOLLOW these steps:
Lift display cover. Push "SET" button at bottom of pad. User "1" and "2" will appear.
User "1" will start blinking. Press the "USER" button to choose user "1" or "2". Once selected, press "SET" button to lock in information.
Both "HEIGHT" and "AGE" will appear on the screen. The "HEIGHT" will start blinking. Press the "UP" or "DOWN" arrows to find the correct height.
After entering height, press the "AGE" button. Use the "UP" and "DOWN" arrows to enter correct age and press "SET".
Both "MALE" and "FEMALE" images will be displayed. Press the "GENDER" button until the correct MALE/FEMALE image blinks and then press "SET". This will lock in the information.
Your correct information including User, Height, Age, and Gender will be displayed. Now you are ready to calculate weight.
Tap your person "USER" number (1 or 2) in center of scale with your toe. Your personal profile will appear. Wait until "000" appears. Stand on scale so bare feet are positioned over silver pad surface. "000" will blink your weight for approximately 3 seconds. "BF" will flash and body fat percentage will appear. The scale will turn off automatically in a few seconds.
May 21, 2011 | Health-O-Meter Health & Beauty
Hi. I just bought the Conair WW67WC Glass Scale... I'm following the instructions, but it won't let me set the user data. The booklet says that the height and age will flash, allowing me to change it,...
OK~Just bought the WW67WC glass Body Comp scale and its ****! that all I can say after trying to set the height, age etc etc I seem to have the same problems as everyone else. I will be returning it and buying a TANITA scale!
Thanks alot CONAIR for a ****** product.
Nov 07, 2010 | Conair Health & Beauty
I have a GoWalking by Sportline scale and right now it is set to kg but i need to set it to lbs how would i do that. i lost the manual pls help
Press I/O button to turn on.
While "1-10" is flashing, press "i" button once.
Use up/down arrows to choose a 'user number' from one to ten, then press "i" button.
Press up/down arrows to chose between male(bottom) and female(top) icons, then press "i" button.
Use up/down arrows to specify your height in cm. (inches x 2.54) Press "i" button.
Use up/down arrows to specify age, then press "i" button.
"1-10" will flash again. Using up/down arrows select the user number you've programmed and wait for your height and gender to display, followed by "0 lb." You can now use the "i" button to toggle lb/kg or step on the scale for your weight and body fat %.
Next time you turn the scale on, just use the up/down arrows to pick your user number then wait for the 0 display.
Jul 07, 2010 | Health & Beauty
My bathroom scales ww35cha stopped working, i replaced the battery and now the scales turn on, but do not display a weight when u step on. Instead the weight shows '0'
you have 4 button on this model
1 tap the scale to start, it show 0.0
2 tap set to set person and height, age ...( use set, up, down buttons )
done
when start use
1 tap scale to start , show 0.0 again
2 tap user again and again to choose your user
3 wait after it show your height, age, then it show 0.0 step on the scale and you're done.
i've been through becuase my friend lost his instruction manual.
Now it wook
Have Fun
duccotam@yahoo.com.au
Nov 16, 2009 | Conair Weight Watchers WW35 Body Fat Glass...
No instructions. how do i set it up and what does
P zero to P 9 is just a user number to set it up... Instructions for set up are:
  • Turn it on.
  • Select user number using up and down buttons (P0 is fine).
  • Hit the Set button.
  • Choose gender using up and down buttons.
  • Enter your age using up and down buttons.
  • Enter your height (goes in 1/2 inch increments) using up and down buttons.
  • Hit the Set button. (Info is now saved.)
  • When scale changes to 0.0, you can step on, and get your weight.
  • It will blink and change weight possibly for a second or two. When it stops, it shows your weight.
  • Stay standing still on the scale after your weight, and it will gon to show your bodyfat percentage, then your body water percentage.
  • When finished, you can step off, and it will turn off.
Oct 17, 2009 | Taylor 5757 Digital Glass Body Fat Scale
How do I set the High hr and the low hr by the chart?
To change any of the settings, press 'set' until 'settings' is displayed, press 'ok', now you can either set the heart rate manually in 'limit set' (press 'ok' to change the settings and press 'set' to change)
or input your personal data to let it choose heart rate settings itself in 'user set' where you input weight, height, age and *** (sadly yes please is not one of the options ;¬) )
if you go to www.polar.fi the user manual is on there if you need more clarification.
Hope that helps,
Andy
Sep 18, 2009 | Polar F4 Heart Rate Monitor Watch
SCALE SETTINGS
To change the height/weight/age, hold the user # you want to change it for and the set/save button at the same time for a few seconds.
I am #2, so I hold the 2 button and set/save. Then you can use scroll to change the numbers/options, and set when you have properly set the digit.
First it does height, then age, then gender, then if you want a goal, and then what that goal is.
Apr 09, 2009 | Health-O-Meter Health o Meter BFM588DQ-81...
Watchers WW-87 Body Fat Glass Scale
Hi
At this web site bottom left hand corner there is an instruction manual
http://www.conair.com/weight-watchers-glass-digital-scale-p-667-2_60_38.html
Sep 01, 2008 | Conair Weight Watchers WW-87 Body Fat...
Conair scale ww36gd err reading
I have a WW36DG digital scale and most of the instructions are the same, so far as I can see. When you tap on the scale, 888.888 appears. It is just seting itself. If you step on the scale before it reads 00.0 it wil give you a Err signal. If you stepped on the scale after it read 00.0, and an Err signal appears, either your battery is very low or it is malfunctioning. it does have a 10 year warranty on it. For the person wanting to set the scale, here are the directions. Good luck.
Customizing Your
Weight Watchers® Body Fat Monitor
1. Tap center of scale platform with foot to activate digital display (display will
flash).
2. Wait for "0.0" to appear in display window.
3. You are now ready to input your personal data. Firmly press the SET button
located below the display.
Enter User Number
• P-01 will flash in display window
• Press UP or DOWN arrows to select your individual user
number (Ten user numbers available: P-01 through P-10)
• When selected user number appears in display, press SET
button to save user number
• The scale is now ready for you to enter your height
Set Height
• "Ht" (height) will flash in display window
• Press UP or DOWN arrows to scroll to your height measurement
• Press SET button to save height
• The scale is now ready for you to enter your age
Set Age
• "Age" will flash in display window
• Press UP or DOWN arrows to scroll to your age
• Press SET button to save age
• The scale is now ready for you to enter your gender
Set Gender
• The gender icons will flash in display window
• Press UP or DOWN arrows to select male or female icon
• Press SET button to save gender
• The scale is now ready for you to weigh yourself and to
determine percentage of body fat
Nov 25, 2007 | Conair TAD1216PWT Digital Answering...
Health & Beauty Logo
4,615 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
