Question about HP Photosmart 2610 All-In-One InkJet Printer
Printing on textured or paper other than plain
For some odd reason my printer is not printing on this kind of paper, i was able to do it previously so i dont know what is going on. it goes through the printer like its printing, but nothing is there
  • mskat127 Oct 02, 2008
    its just resume paper, it goes through the printer and then its blank
  • steve shroder May 11, 2010
    can you print on other types of media?
  • HP Expert
  • 141 Answers
Change the ink, then if it doesn't print then it's the carriage or formatter. if the machine is under warranty then either take it back where you bought it or contact HP for replacement. if not under warranty then throw it away and buy another because the part s are unavailable. Good Luck!
Posted on Oct 02, 2008
Hp color Laserjet printer 5550 printing very slow
Please check your paper tray adjustments and verify that the paper type for the tray is set to any type or plain (assuming you are printing on plain paper). In general, if the machine has reason to believe that there is a custom size or special type of media, it prints at half speed.
Feb 26, 2016 | HP LaserJet 5550 Printer
Colour photos will print fine on plain paper but when you select 6x4 and HP premium paper the output is very odd, for instance the black penguins in Windows sample folder come out with turquise blue backs....
It is not at all unusual for colors to appear different when printing on differing paper types. Your problem would appear to be an over saturation effect which alters the purity of the color tones. I'd suggest that you refer to information found under the heading "Change the saturation, brightness, or color tone" found on page 58 of the online user manual for your printer which is found at the following link:
Jan 20, 2018 | HP Photosmart C5380 All-In-One Laser...
When printing it will not print from tray 2 it wants to print from tray 1 and is asking for labels. Then causing users to have to press the green check twice to change the option to print from tray 2. How...
Ok remove tray 2, and in back its got a little clicking adjustable lever that you need to move so it lines up with letter 8.5 x 11...this worked for me
Nov 27, 2009 | HP LaserJet 4700 Printer
The color streaks on the pages
There are several possibilities...
1.The Type setting is wrong for the type of paper or specialty media you are using. Change Paper Type to match the paper or specialty media you are using.
2.The Texture setting is wrong for the type of paper or specialty media you are using. Change Paper Texture from Normal to Smooth or Rough.
3. The Weight setting is wrong for the type of paper or specialty media you are using. Change Paper Weight from Plain to CardStock (or other appropriate weight).
4. The fuser is worn or defective. Replace the fuser.
Oct 14, 2009 | Lexmark C760 Laser Printer
Prints aren't plain, it have some texture like crayon
its problem of toner
its of good quality
and also check proper supply of toner into develper assembly
trying to add some extra ink directly in developer assembly
if problem solve
cartridge motor running
and supplying toner proeprly
May 24, 2009 | Xerox DocuColor 12 Color Copier
Someone has sent a print job from a computer to the copier with an odd paper size specified. Go to Job status, under "print" highlight the first job in the que and delete it. (if the job was sent more than once you will have to repeat. ) Check the document and print settings of the offending document.
Dec 05, 2008 | Sharp AR-5316 Advanced Digital Imager...
I need your help please.
Make sure you are using the paper that come under the specifications of the printer (102 x 153 mm (4 x 6 inches) for a Photo Paper). Though you are using the correct paper and you are getting the same message, then just set the paper type as "Plain" and try to print from the photo paper. It works in most of the cases
gud luck
Oct 24, 2008 | HP PSC 1315 All-In-One InkJet Printer
Ricoh Aficio cl3500N
the extra page comes from the page setup..
the jamming comes from odd paper textures, or not 'riffling' the paper before placing it inside the tray
check your user manual for more on both of these issues.
May 01, 2008 | Ricoh Aficio CL3500N Laser Printer
Printing jammed on thicker paper
See the manual. It looks as if 120g/m2 is the heaviest paper it can use:
"Set Type to correspond to the paper loaded in the tray from
which you want to print. This will let you get the best quality
printout. If not, print quality may not be acheived as you want.
Thin: Less than 19 lb (70 g/m2) thin paper.
Thick: 24 lb to 32 lb (90~120 g/m2) thick paper.
Cotton: 20 lb to 24 lb (75~90 g/m2) cotton paper such as Gilbert
25 % and Gilbert 100 %.
Plain Paper: Normal plain paper. Select this type if your printer is
monochrome and printing on the 16 lb (60 g/m2) cotton paper.
Recycled: 20 lb to 24 lb (75~90 g/m2) recycled paper.
Color Paper: 20 lb to 24 lb (75~90 g/m2) color-backgrounded
Nov 22, 2007 | Samsung CLP 300 Laser Printer
Won't print on normal paper
Refer to my previous post about manual under head cleaning and follow the routine through. This will most likely get you going as sounds like classic blocked nozzles.
Jul 01, 2007 | Canon i860 InkJet Photo Printer
HP Photosmart 2610 All-In-One InkJet Printer Logo
Ben Johnson
