Question about Infinity 7540A Car Audio Amplifier
Help with my infinity 7540a
I hooked up the amp but the power light just flashes on and off...no other lights light up so i can't figure out what is going on.
  • nrh06002 Oct 21, 2008
    it was hitting a loud note and just cut out. i noticed that the power light blinked off and on and my speakers were moving in and out very slowly in opposite directions. i have a protect light and clip light and power light, and just the power comes on for a second, every five seconds and a bit of sound comes out. help please
  • 631 Answers
It probably has shorted output transistors. Read through the following page to eliminate other possible causes. Let me know if you have any other questions.
Amp in Protect Mode - Troubleshooting
Posted on Oct 02, 2008
Ap 3002 blue light flashing
sounds like you got some wires crossed and not hooked up right, recheck your connections
Jul 02, 2014 | Audiopipe AP3002 Car Amp
Power light flashing
This means it is blown. Whenever the power light flashes on any amp it is blown or something else is wrong with it. Most likely its blown. You can blow am amp by hooking it up to a powerful sub and blaring it, or just overheating it. Hope this helps. This can usually be fixed as well
May 07, 2013 | Pioneer Gm-d8400m 1200w Max, Class D Mono...
HOW MANY LIGHTED HOUSES CAN BE HOOKED UP TO A BACHMANN CONTROLLER
You don't have enough power with a single controller to provide enough power to light all your light houses. You need to figure out the power draw & get a separate power supply.
Dec 14, 2011 | Bachmann Toys
I just bought a hifonics amp the brz2100.1D and when i tryed to hook it up every thing is correct as far as the wireing compared to the manual and the blue lights come on power light is on but its not...
MAKE SURE YOUR GROUND WIRE IS GROUNDED GOOD,,AND IT IS IMPORTENT TO HAVE YOUR REMOTE WIRE HOOKED UP. IT WILL BE A BLUE WIRE,,FIND THE HOT WIRE FOR YOUR TAIL LIGHTS AND HOOK IT THERE THEN WHEN YOU TURN YOUR CAR ON THE AMP WILL ALSO COME ON.THAT SHOULD STOP ALL THE NOISE AND POWER YOU UP.
Jul 15, 2011 | Hifonics BRZ21001D Car Amp
Um the power light will flash then the protl. light will flash its all hooked up right but weird sounds coming out my subs.
Disconnect subs from output of amplifier and then turn on car and radio. Does amp stay on or go into protect? If it stays on then there is something wrong with the subs or how they are wired (series, parallel ) to the box and amp. If it still goes into protect then something internal with amp.
Feb 23, 2010 | Concept Car Audio & Video
I have a pioneer gm-d8400m the amp isnt working
flashing light could mean a few different things. 1- constant power may not be there. check with a test light or multimeter. should read around 12 volts. it would be a good idea to check all the power and ground leads. make sure u have a good ground. 2- bad sub. im assuming sub since its a monoblock amp. you can meter the subs. make sure the total ohm load is no less than 2 ohms. any lower the amp will go into protect mode. 3- bad amp. power supply may be bad. the newer pioneer amps are full of protection circuits. ive been a professional installer for a shop about 8 years and we sell pioneer. hope it helps.
Dec 25, 2009 | Car Audio & Video
I miss placed my manual for my incredible holiday light show, The trees are all pluged in I get a flashing red light in the back but it wont start what am I forgetting to do
Just put mine up & it did the same thing. Unplug power. Have remote handy & paperclip. Find reset hole behind remote. Plug in power, red light will flash, hold reset button in until unit stops flashing. Make sure remote is also powered on. Thats it.
Nov 29, 2009 | Gemmy Toys
Infinity 7540A Car Audio Amplifier Logo
158 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
