Question about Whirlpool Washing Machines
I have a whirlpool duet washer that I just purchased and trying to do a load tonight and it's giving me an error message 'F20'. Can you tell me what this means and how to fix it? Thank you.
  • 5,911 Answers
"F20" is a Water Inlet problem. This means you either have insufficient water pressure, the taps are turned off (not trying to insult your intelligence), the water inlet hoses are kinked, or the water inlet valve may be clogged with sediment. You need a minimum of 10-25 psi of water pressure in order for the washer to work correctly. Also, if you live in an area that has hard water, or if you use well water, you may have rust or sediment clogged in the inlet valve. However, if you just purchased the washer, I would tend to doubt that it is clogged already. It takes some time for this to happen. It still may be worth your effort just to double check your installation, check the hoses for kinks and the sediment screens for clogs. Just turn off the water at the taps and disconnect the hoses from the back of the washer. The sediment screens are inside the inlet valve on the back of the washer. The inlet vlave is also controlled by electronic solenoids. I would normally recommend that you check to make sure the electrical connections are plugged in correctly and then instruct you to do resistance checks to make sure the solenoids are good. However, once again, if you just purchased the appliance you have a one year limited warranty that comes from the manufacturer. If you open the appliance or attempt any repairs on your own, this may void your warranty. NOTE: The warranty does NOT cover installation, however. That's why I strongly suggest you doublecheck your installation. If this isn't a simple matter of installation, I would recommend you honor your warranty and save yourself from having to pay for repairs. I hope you find this information helpful. Let me know if I can assist you any further.
Posted on Oct 02, 2008
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
What is the F20 code on the whirlpool duet front load washer?
Whirlpool WasherDuet Repair F20 Error Code - YouTube
www.youtube.com/watch?v=kYuRQNbR9Nc
  • By Mike Murphy ·
  • 110,010 views ·
  • Added May 11, 2011
How to Fix A Whirlpool Washer Model:Duet that gives you an F20 Error Code.
Mar 08, 2015 | Whirlpool Duet GHW9150P Front Load Washer
Washer stops during cycle with an error F20
Hi
Please check this link to get error F 20 resolved:-
http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-sport-error-code-f20-washer-repair-troubleshooting/
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I am having trouble with my washer. It is showing the F28 error code and then when I get that fixed, it shows the F20 error code. Can you please tell me what to do to get it running again. Thanks
F20 I believe is low water flow. On the intake fitting on the back of the machine where the hot and cold hose hook up there is a fine screen inside the fitting on the machine. My cold water screen was clogged from stuff in old pipes. Cleaned it and no more e F20
Feb 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer model number WFW9400VE error code F20 keeps coming up. Is there a way to reset?
F20 No water detected entering machine, Defective flow meter, clogged water valve inlet screens.
Duet sport service manual
Jan 07, 2011 | Whirlpool Duet WFW9400VE Front Load Washer...
What does the F20 message mean??????
Well the error F20 on display means (Water Inlet Problem, no water or insufficient water supply)
Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power.
You can please check the following -
Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked?
Are water inlet hoses frozen?
Post comments for further help or information..........
Good Luck!!
May 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I'd like to know what the F20 message means on the Duet washer. I do not have a manual. Also, how do I get rid of it. Could it be an unbalanced load? Thank you for your assistance. Marilyn...
"F20" error code is a No Water Detected error. It is an indication that you either have no water coming into the washer, or very little water at all due to low pressure. If the pressure switch has not tripped after 6 minutes, the error code is displayed. This can be a potential problem with the following:
May 17, 2010 | Whirlpool GHW9400 Duet Washer
I am getting an F20 error message or SUD. I have
http://www.wikihow.com/Fix-a-Whirlpool-Duet-Washer-F-20-Problem
Jan 22, 2010 | Whirlpool GHW9300 Duet Washer
What does the F20 flashing code mean on whirlpool duet washer
I believe F20 may point towards a control unit failure.
You could try disconnecting it from the mains supply for a minute and plug it back in.
Hope this helps
Oct 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
70 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
