Question about Toshiba 51H84 51" Rear Projection HDTV-Ready Television
Image Distorted The center of the screen has a good picture, but the ends are blurred and have double images. The image also seems to be bowed in at the top and bottom center.
  • eglimos Oct 02, 2008
    Yes, the model number is 51H84.
    I may attempt the repair, based in part on the dificulty of the procedure, so any instructions would be greatly appreciated.
    If I find that the repair is beyond my skill level, do you have a ball park estimate on what a professional would carge to do the repairs?
    Thanks again.
    Yes it is a 51H84
  • 4,234 Answers
This is a classic convergence problem. Please confirm that your model is 51H84 and whether or not you intend to repair this yourself. You will need to know how to solder. If you wish to attempt the repair, confirm the model and update this and I'll provide you with details and instructions.
Dan
Posted on Oct 02, 2008
  • ABRsvcs Oct 02, 2008
    If you can solder, try resoldering the pins on the convergence IC (STK394-250). This will be a large black pack attached to a heatsink. If the resoldering fails to resolve the problem, replace the IC. This should be available for under $20 on the web. If you would rather have a service shop repair it, expect a parts cost in the $40 range plus the local labor rate (Estimated: $300 or so).
    Dan
The picture is showing a double image and is distored.
The problem you are refering to is more than likely a convergence problem. The convergence circuit in your tv is controlled by an IC (integrated circuit) stk392-110 and it makes the 3 colors (red, blue, green) line up/converge together to create a clear picture. You'll know when this part needs to be replaced because the picture you see is 3d looking and possibly bowed on the top or bottom or on the sides in any or all 3 colors.
Jan 24, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Projection screen bowed?
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 23, 2009 | Akai PT4298HD Rear Projection Television
My Toshuiba 46RV530U tv has developed an image
Sounds like you need to try reseating the lvds cables on the t-con board.This board is located at the top of the set in the center.You will have to remove the metal shield covering the board.Then you will see to flat cables connected to the board,one for each side of the screen.carefully unlock the connectors and remove and replace the cables.If this does not work you will need a new t-con board.I'm not sure about this particular model but sometimes the t-con board is only available as part of the lcd panel assembly.Good luck!
Oct 15, 2009 | Toshiba REGZA 46RV530U LCD TV
Color seems off possible bowing of the image at top and bottom
that's right my friend, you have a convergence problem, you need to replace the stk's and it is possible that you have some burned resistors. if can't do it yourself  you are looking $250.00 repair
good luck
Jun 07, 2009 | Samsung PCL5415RB 54" Rear Projection...
Picture Image Becomes Blury When Recording
i had the same problem i just gave the camera a good smack and it was all good. lol
Apr 19, 2009 | Sony Handycam DCR-TRV38 Mini DV Digital...
Philips 46-inch Rear Projection with bowed image?? slight distortion
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jul 02, 2008 | Philips 46PP9302 46" Rear Projection...
Pinkish screen and green blurred picture
Sounds like the image sensor is malfunctioning (common symptoms: distorted images with purple or green cast, completely dark images, flickering lines across the screen.)
Oct 26, 2007 | Kodak EasyShare C643 Digital Camera
In camera mode, screen shows a blend of image and digital spectrum analyzer bars blurring the image
the ony way is to get the CCD replaced with a new one. Contact NIKON for free replacement as this comes under manufacturing defect.
Aug 16, 2006 | Nikon Coolpix 5700 Digital Camera
Edges of Picture & Text Sloping
This mis probably a cold solder connection in the horizontal circuitry called the pincussion. Theres a couple of coils and resistors that overheat from time to time and the solder connections get loose. Not really for a handiman has this tv has hi vboltage inside even when turned off. Shouldnt cost an arm ans a leg to fix if the repair shop knows what they Are doing. Good Luck
Jun 26, 2006 | Akai CFT2490 24" TV
Toshiba 51H84 51" Rear Projection HDTV-Ready Television Logo
403 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
