Question about Black & Decker 5700 Powershot Forward Action Stapler
Got it loaded now it won't shoot
Staples are prescribed size, was working prior to purchasing new staples. Got it loaded and now it doesn't work. help
    Problem Solver:
  • 17 Answers
I have a similar staple gun and I figured out I was loading it wrong. If you are loading it where the spring is, like I did, it won't work. there should be another area close to that spring opening that you put the new staples in.
Posted on Oct 14, 2008
Help please! I have a Paper Pro high capacity stapler that will not staple. I can open it up and put staples inside, but no staple will come out when pushed down. Oddly enough, if I put ONE staple inside...
are you using the correct size of staple?? (thickness wise) secondly check the spring is pushing as it should, also a fix to get it working is as you put the staple stack into the stapler, seperate them and see if will staple. other than that it's defective and you should purchase a new one.
Oct 30, 2013 | Staples PaperPro 1200: Heavy Duty Stapler
Arrow jt27 staple gun won't load or staple
Everyone here is assuming that you have fully operational gun. I have a business where we use these guns. I can tell you now that 3 out of 5 of the Arrow JT-27 just don't work. The staples won't advance. After looking at the information online, it is probably due to a weak spring. The best solution is to go with a different brand of stapler. This one is just not worth the trouble.
Jan 16, 2013 | Tools & Hardware - Others
Staples are loaded and won't shoot
check for a jammed staple near the end. This often happens and prevents the staple from feeding all the way
Sep 17, 2011 | Garden
How do you load staples in ET501? I pinch the back of the loader together but it won't pull out.
Try pinching it and pushing it down at the same time. If that doesn't work then there is likely a jam.
Jul 02, 2011 | Heavy Duty Arrow Et501 Electric...
Our nintendo system works just fine but when trying to play the Super Scope Six game, it doesn't seem to want to work. We can get it to the shoot screen, but it won't get through the test screen....
The superscope uses an infared sensor as well as light detection to work
Chances are that some form of interference is going on so try moving your sensor
You could als ojust have a bad super scope and It's dying out
Thank you for your time Good luck and I hope this helps
Jun 08, 2011 | Video Game Consoles & Games
Just purchased t27 arrow staple gun but can't load staples. I have removed spring loader from rear and unsuccessfully trying to load staples from rear. Wrong method? Wrong size staples?
That stapler takes a jt21 staple. some fill from the bottom when the plunger is in the drawn back position and some fill from the rear with plunger removed. If the plunger is attached, then it fills from the bottom. Hope this helps:)
Aug 24, 2010 | Arrow Fastener T27 Light Duty Household...
Brand new gun seems to be in good working order,
If nothing is jammed the the hammer that hits it is probably not hitting could be bent,you can try cleaning and putting about 1/2 load in it .if not shouting then it isn't in good order / if new way not return should be warranty/defect
Mar 20, 2010 | Air Tools & Compressors
Problem loading gun..Where do we put in the staples and change the dial to accomodate it? fred
The staples should load in through the end of the hammer stapler. The end is spring loaded to push the staples forward, so push the end - usually a crome square - into the handle end then move that part up approximately 1/4 inch and pull back. The spring mechanism should slide out so you can add new staples. These staplers take a specific size of staple and a certain number to allow you to put the spring mechanism back into the stapler. If you do not know the correct size for your stapler someone at your local hardware store can help you find the correct size and they will probably even show you how to load it. Good luck!
Jul 07, 2009 | Ace Hardware Ace Heavy Duty Staple Gun...
Black & Decker 5700 Powershot Forward Action Stapler Logo
1,171 people viewed this question
Top Black & Decker Tools & Hardware - Others Experts
Jim Goldsmith
Jim Goldsmith
Gil Shultz
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
