Question about Black & Decker Garden
Motor blew out
Hi,  While vacuuming leaves with the Black and Decker Leaf Hog, a stick must have gotten sucked in, and gotten into the grinding device. This "blew" the motor? Is there anything to be done?
SOURCE: black and decker leaf hog on off switch schematic
Take out all the screws. Gently remove half of the case. Put a shim in behind the plastic pivot that rocks the switch. I rolled up a 1/2" by 3" piede of duct tape and jammed into the back of the oval socket for the rocker. This pushes the rocker against the switch hard enough so that it rocks the switch properly. Snap the case into place and test the switch before you put the screws back in to make sure it is now working properly.
Posted on Sep 27, 2009
rwvanlue
  • 486 Answers
SOURCE: Where can I get a new replacement bag for my Black
http://www.blackanddecker.com/CustomerCenter/parts.aspx
this link should help you with anything you need.
Posted on Nov 12, 2009
SOURCE: how do i change black and decker leaf blower to
you have to remove the plate that covers the fan bla des intake than witch hoses some covers are spring loaded and just flip up
Posted on Apr 22, 2010
  • 2926 Answers
SOURCE: I have a black and
Your leaf blower does not have a reset button unfortunately. The motor is a double insulated design and does not have any serviceable parts, the motor heads are replaced as a complete unit. There is one thing you can check. Since the wash cloth placed a huge strain on the motor, which in turn, increased the ampere in the circuit, it may have tripped a circuit breaker in your house fuse panel, causing no power to the outlet you were using.
Posted on Nov 07, 2010
SOURCE: My motor brushes at end
Try Platt Electrical supply - 800-257-5288 (Platt.com) BLACK & DECKER #89754-01 REPLACEMENT BRUSH. It seems the entire motor head was manufactured by DeWalt and is now obsolete. I don't know if these brushes will fit, but someone there may help.
Good Luck!
Posted on Aug 31, 2011
My motor brushes at end of life for a Black and Decker electric leaf blower. Where can I get them? Black and Decker leaf hog, model BV400 type 4, Cinderson 90510850 motor. Black and Decker site no help...
Good Luck!
Aug 31, 2011 | Black & Decker Leaf Hog 12-AMP Electric...
How to do I convert it from blower to vacuum..it just stopped sucking and the blowing is not strong
My LEAF HOG works fine on blowing - but when I switch to vacuum it wor't
start. What's the difference from going to Vacuum from Blower???
Dec 03, 2010 | Black & Decker & Leaf Hog Blower / Vacuum
I can not get the Leaf Hog to swtich from vacumn to blower. Any suggestions?
it does not "switch"
The air intake becomes the vacuum with an attachment. The "blower tube" is then the vacuum exhaust.
the motor does not change directions.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 27, 2010 | Black & Decker Leaf Hog Blower Bv4000
Black and Decker leaf hog, worked fine last use.
I posted this solution on another similar thread, but it may pertain here.
I have this unit. Mine stopped working today after being warm on the handle the last few uses. I opened the unit up (torx 15) and smelled, then found that a fused wire coming off the motor had burned/melted/separated at a plastic plug right inside the handle. I'm not sure if it had anything to do with it, but in this same compartment of the handle there was an anti-theft strip floating around. I called BandD and they said the BV4000 type ONE has been recalled. http://www.cpsc.gov/cpscpub/prerel/prhtml07/07005.html
Jun 10, 2009 | Black & Decker Leaf Hog 12-AMP Electric...
LeafHog bag tear
Found the bag on a replacement parts site:
http://www.ereplacementparts.com/black-and-decker-bv2500-type-high-performance-blower-vac-parts-c-4167_9502_9507.html
Feb 09, 2009 | Black & Decker Leaf Hog 12-AMP Electric...
Zipper is really stuck
sometimes dirt and debree can get stuck in there, try saturating it with a strong penetrating oil like PB Blaster, available at your local auto parts store, and let it soak in for about an hour and use a pair of pliers to get a good grip.
Nov 23, 2008 | Black & Decker Leaf Hog 12-AMP Electric...
B & D leaf hog (blower/vac)
Check an see if a branch or something got caught in the blower an won't let it turn, if it hums that could be the problem
Nov 11, 2008 | Black & Decker Leaf Hog 12-AMP Electric...
Garden Logo
62 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
