Question about GE Monogram ZISS420NRSS 42" Built-In Side-By-Side Refrigerator (ZIS-S420NRSS, ZIS S420NRSS)
Refrigerator is not cooling well nor freezing well
Cleaned the coils best I could and it got better, but refrigerator is definitely struggling to stay cool and freezer struggling to stay cold. Once we open the fridge in the AM, it will not cool back down to 37 and 0 degrees. What the devil is going on?
  • 943 Answers
Hi. did you check the freezer fan motor, or for frost build up in freezer
Posted on Oct 02, 2008
Amana ASD2620HRB Side-by-Side freezer running, but not freezing. What could cause this?
What is running? The important motor is the compressor - the one that works with the refrigerant to supply cooling. If it is not running you can check the start relay/capacitor. If they are good, make sure that electricity is reaching the motor windings. If the thermostat stays open, the compressor will not be activated.
If compressor is running and if there is ice buildup on the evaporator behind the back panel, then the self defrost mechanism is not working - could be you have an open heater coil. If you completely defrost the refrig for a day and then plug back in, if it works fine, then it is definitely ice buildup which serves as an insulator and prevents cold air from reaching the refrigerator portion.
Aug 03, 2017 | Amana Refrigerators
Why doesn't my Frigidaire FRT21TNG freeze or cool fresh section?
Good Afternoon Friend,
I understand that your Frigidaire refrigerator, model# FRT21TNG, is not freezing or cooling. I also see that the coils are not freezing, the drain line and everything cleaned, and that the capacitor was replaced. From this point, I suggest contacting your local authorized technician. They will be able to diagnose your appliance and determine why it will not cool as it should. Hope this is helpful.
-Best Regards-
WP
Jun 20, 2014 | Frigidaire FRS3R5EMB Side by Side...
Freezer coil keeps freezing up,defrost coil not staying on long enough.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 02, 2011 | KitchenAid Refrigerators
Freezer keeps freezing up. But the fridge doesn't stay cool.
the reason the fridge doesnt stay cool is because the freezer keeps icing up, try defrosting the freezer and try cleaning the condensor coils and this may help.
Mar 15, 2011 | Refrigerators
48" ge monogram refrigerator not staying cold
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
sfjfg
Aug 16, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
Ge refrigerator not making ice but once a week I dont know why it worked great and then it stops then a week later its fine again???????????????????????????????????????????????
I think your re fridge is getting to hot it will only make ice if it can freeze it, if its not staying cold enough it will cease making ice, with the weather we have been having hot one week hotter the next rain and get cool well 89deg beats 109 your refridge may be struggling to keep its cool pardon the pun. I don't think there is anything wrong with it but it is hard on the pump when it gets that hot try putting a standard box fan blowing at the coils so that it helps move some of that hot air away from it this should help some.
best wishes okcfirewall
Jul 24, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a KitchenAid Supra refrigerator, KSRS25F, it is now 8 years old. Yesterday it lost ability to freeze and cool. Both fans are working fine, no frost on coils, and cleaned bottom coils. Is this the...
Yes this would be the compressor and they run with a technician roughly 600 dollars. There are two things that will cause a Refrigerator not to cool or freeze, the coils being clogged or the compressor is shot. In this case the compressor is gone. Better to just get a new frig
Feb 09, 2009 | Refrigerators
Kenmore fridge not cooling
is the compressor really hot? If so you are low on frion.
Nov 18, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Not Cooling or freezing.
you need to clean the evaporator coil under bottom off refrigerator. and check in the back of refrigerato to see if fan is runing. I not you need a replace it sam
Sep 25, 2007 | Frigidaire FRS23R4A Side by Side...
GE Monogram ZISS420NRSS 42" Built-In Side-By-Side Refrigerator (ZIS-S420NRSS, ZIS S420NRSS) Logo
284 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
