Back to:
Tags:
Samsung 997DF  19 in.CRT Conventional Monitor
Need Data Sheet for M52327SP I.C.
By Pasty - usenet poster
Monitor is a 15 Inch MAG Inovisions. This chip is a Mitsubishi M52327SP Triple Video Amplifier I.C. I suspect.
It is on the the board mounted to the CRT Socket. Video cable comes directly into this board.
If I had the Diagram of this chip I could better make out the rest of the circuitry on this board. Problem is one color is intermittant both thermally sensitive and vibration sensitive.
Cannot find any loose connections, no bad solder joints, all connectors/connections are good.
Maybe there is a cracked trace but I've looked Very, Very hard and I don't see it. I don't have a microscope, just high power magnifier.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Dec 28, 2007
Not Rated (0)
cfh1
Rank:Apprentice Apprentice
Rating: 100%, 1 votes
After a search of my usual websites for
obsolete part datasheets I found the sheet you want at the
following url:
http://datasheet4u.com/html/M/5/2/M52327SP_MitsubishiElectric.pdf.html
this will be the complete 17 page sheet from mitsubishi.
enjoy
Chuck
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Need Data Sheet for M52327SP I.C.:
I don't want to Accept this solution
Solution #2
posted on May 30, 2006
Not Rated (0)
herself
Rating: 0%, 0 votes
Hi check the crimps on the PCB end of the video cable this used to be a common fault, I used to solder the crimps to the cable until I had replacement crimps and a tool.
Thank You!
Can you Help with these Monitors problems?
Monitors
i have done this before connected me laptop to my moniter...
Monitors
I am trying follow the steps below, I can't turn the...
Samsung 997DF (Black, Silver) 19 in.CRT...
Hi CompuG, I tried the site you suggested, but my computer...
how meny test in power transformer
I got nice silicon graphics monitor but i dont know how to...
Loading problems.
Repair Service
Find Monitor Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
