Question about Sony KP-57WV600 57" Rear Projection HDTV-Ready Television
Sony 57"kp-20fm12 hi scan 1080i rear prjection
When the tv is turned on the picture and sound come on for about 5 to 7 seconds the it turns off and the ready light will flash . Any ideas on a simple fix? Thank's Tim
  • kumpenhour Oct 30, 2008
    MIne turns on green, then goes off. Bliks 5 times repeatedly. Could it be I overadjusted the RGB levels?
  • VetteAdv Dec 17, 2008
    Our TV blinks 10 times. We have to try to turn it on numerous times before it will go on.
  • 2,071 Answers
That blinks and flashing have a diagnostic code. I have a list of the problems that might have occurred indicated by the number of blinks or flash. Tim just post the number of flash or blink,so i give you diagnostic code meaning...
Hope it may help you;
Regards,
VOTIT
Posted on Oct 02, 2008
Sony KP-57WS500 57 in. Rear Projection Television -
The red CRT needs replacement. You can get the Red CRT from www.tvrepairworld.com they can also assist with installation information
Apr 16, 2012 | Sony KP-57WS500 57" Rear Projection...
Tv comes on for 10 seconds then fades to a green tint then turns completely green for a few seconds than turns off
Symptom shows tv got problem with green picture tube that need to be replaced.
Rear projection tv has 3 picture tubes, red-green-blue to make color picture.
Since its an old model so spare parts would hardly be available and local tv repair shop will help you to arrange required part, if they can.
Thanks.
Apr 16, 2010 | Sony KP-57HW40 57" Rear Projection...
Cannot change aspect ratio of picture when ratio button is pressed on remote. Batteries in remote are good. Everything else on remote works. Sony KP-57HW40
If you are connected to a HD cable or satellite box, the aspect ratio is set by that box. If it is set for 1080i 16:9 wide screen mode then your TV is locked at that ratio. This is good considering you have a Hi-Scan 1080i television in the Sony KP57HW40. Please take a moment to rate my answer. Thanks...
Nov 24, 2009 | Sony KP-57HW40 57" Rear Projection...
Standby flashes 9 times. Can't turn off TV. No picture. No sound.
Press on sony remote in this order "display - 5 - volume dn. - power" to see self diagnostics. But to fix it you'll need a tv repairman to fix the Zero Cross Detect circuit.
Oct 12, 2009 | Sony KP-57WS520 57" Rear Projection...
Sony Color Rear Video Projector - KP 57hw40 / Mfg. February 2002
i have the same problem picture is blue/green with blue and green arched horizontal lines
no picture at all only sound then tv shuts off after 5-10 seconds and then a bright blue flash in the center of the screen
have tried adjusting the voltage screws didnt do anything
Jul 13, 2008 | Sony KP-57HW40 57" Rear Projection...
Sony KP 57WV600
how many times does it blink?
Mar 26, 2008 | Sony KP-57WV600 57" Rear Projection...
Green screen...
Probable bad green CRT..........usually about 600.00....T.
Aug 04, 2007 | Sony KP-57HW40 57" Rear Projection...
Sony prjection tv 5 years old hardly used eithier
has the set been knocked or had a bang in any way, these rear projection tvs are very tempermentle to slight knocks, as you can knock the crts out of line, also the crts have a cooling gel that is located on the top of them, these after a while cloud up causing a very poor picture, if this is the case, then they will have to be replaced, just have a quick look at them you will be able to see if its the gel problem, look directly down on the crts (MAKE SURE THE SET IS TURNED OFF THOUGH), hope this is of some assistance.
Jun 02, 2007 | Sony KP-57WV600 57" Rear Projection...
Sony KP-57WV600 57" Rear Projection HDTV-Ready Television Logo
94 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
