Question about Pioneer DJM-600 Silver Professional DJ Mixer with Auto Beat Cou Home Equalizer
Hi,wken i switch on my panasonic mixer grinder ,fire is coming it looks ike something is burning inside .Could u please let me know what happened?
  • 3 Answers
The fire comes from the mixer grinder, if the motor is drawing too much current. Please take the unit to the nearest service center.
Posted on Feb 08, 2010
  • 515 Answers
What is a Panasonic Mixer Grinder?
What model?
If there is fire, and it smells like burning, DO NOT DO ANYTHING BUT POWER OFF and UNPLUG THE UNIT. You'll need professional help at this point. Something is obviously burnt inside.
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Posted on Dec 18, 2008
The switch doesn't work on my grinder. got new one but terminals are different. is there a schematic for min0022 or 40744 grinder?
Best you contact the manufacturer so you do not burn out the motor by mistakenly attaching to the wrong posts.
Mar 14, 2014 | Vollrath 40744 22 Meat Grinder 1.5 HP 110V...
I got new Preethi Eco Plus 110V Mixer grinder from India to US in April 2011,now almost 10 months back. Last four five times of my regular using it, it had overload problems which on resetting would be...
The problem is not an easy one to fix, the red you can see is the motor windings betting hot due to an increase in internal resistance, There are only 2 solutions.
1. Get a local motor rewinder to strip the motor down and re-wire the motor.
2. Buy a new one.
Sorry i can't give you better news.
Mar 05, 2012 | Blenders
Hi, the motor went slower and slower and now has stopped. We were using the meat grinder and we have only used this machine 9 times in the past two years. We are very upset customers and have 15 pounds...
If you remove the meat grinder, does the mixer still work? It could be that the meat grinder is jammed.
You might have also blown a breaker. Have you tried plugging a lamp or something else into the outlet to make sure it's still working?
Oct 18, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
I brought an MX-AC300 PANASONIC mixer grinder from india to usa.its not's not start even once.can any one help me out on this .i used voltage coverter also.
did u check it( i mean whether it was working) in india if not look in to the warranty period and find out what u can do.. i have bought the same mixer and i'm going to take it to finland in a couple of months.. at present in india its working fine.. and one more qn is it the first time that it's not working.. or it stopped working.. coz too much of rotating might even harmed the mixer.. remember for this mixer it should not go more than 3 min..
Mar 29, 2010 | Food Mixers
The attachment for grinding meat on the front wont work ? mixing arm in bowl works fine ! why wont it engage?
Firstly I would check it is fully engaged. If it is, remove the food grinder and look into the hole. You should be able to see a square hole inside. Turn on the mixer, the square hole should spin, if it does not, one of the gears inside the head has most likely broken. To repair this you will need to take the head apart.
The other possibility is that I misread your problem and that the grinder is turning, but the meat wont go through the plates at the end. This is a common issue which happens if the blade is not put in the end of the grinder. The blade is shaped like a cross and cuts the meat when it reaches the end of the screw.
Jan 25, 2010 | KitchenAid K45SS Classic Stand Mixer
What is the red switch for on Kenwood Chef A901?
If the attachments that you are talking about are the dough hook and the whip, then the red lever is not used to put them in or take them out. The red lever releases the plastic housing on the end of the mixer, which then exposes the mounting hole for the major attachments such as the grinder, sausage maker, etc. You push the red plastic lever, then gently pull off the plastic end of the mixer. It should come off with absolutely no force. Then insert your food grinder or other attachment with the red lever held back. Once the cog on the grinder is aligned with the fitting inside the hole, release the red lever so that the recessed hole on the grinder will become engaged. The Kitchenaid classic stand mixer and the Viking stand mixer have essentially the same set up.
Jul 19, 2009 | Kenwood KM800 Major Classic Stand Mixer
The pasta/meat grinder attachment stops turning
Its a 325 watt mixer. If you grind or mix dough often you may consider getting something stronger or turn it off every ten minutes or so and let it cool down. We burned a 325 and got the 575 watt "600" series and no problems ever since. I know these things are expensive. The 325 is more mixer than grinder. The attachements fit ANY size mixer but some are not recommended for use in all mixers.
If its quiting see my posts on "doesn't run at sitr" and "Removing the motor cover" To get inside and clean those contacts.
Feb 08, 2009 | KitchenAid KSM150PS Artisan Series Stand...
MX-AC300 Mixer Grinder Got from India 2 months back Not working.Tried Reset Button too.
There is a great guy on Gerrard street in Toronto, who can fix mixer grinders and has parts also like breaker/reset switch etc.
The store is called Appliances 220, Ph # 416-778-9908.
Hope this helps.
Sep 24, 2008 | Food Mixers
Panasonic SDR-H18
You also have to plug it into the power source. They put it together with the charger. Get the charger and you will see that you can plug the AC adaptor cable in the other end. This allows you to power up when you are using the USB.
Dec 12, 2007 | Panasonic Palmcorder SDR-H18 Camcorder
543 people viewed this question
Top Pioneer Audio Players & Recorders Experts
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
