Question about Mitsubishi WS-55511 55" Rear Projection Television
Turning on Internal TV Speakers
I have a WS55511 Mitsubishi Rear Projection TV. I want to turn on the TV Speakers, at present they are set off. When entering the Setup menu for Audio/Video to turn the speakers on, the TV Speakers on / off option is grayed out and not accessible. What is the process for making this option active.
    Genius:
  • 1,148 Answers
Either your model tv ,doesnt have that option,,or its on the back,,check the rear of the tv,,good luck
Posted on Oct 05, 2008
Wd 65738 sound card
what sources do you have connected to the tv?
If you have more than one source, have you tried another source to see if it also has no sound. The TV also has a setting in the audio menu to turn off the internal speakers.
Nov 14, 2013 | Mitsubishi WD-62725 62" Rear Projection...
Where is the reset button located on a mitsubish hb 1080 tv 2000
the WS55511 doesnt have a reset button like the DLP models instad you have to unplug the set from the wall for 5 minutes to reset it.
Oct 25, 2011 | Mitsubishi WS-55511 55" Rear Projection...
We just got a used Mitsubishi WS-55511 55in. Rear projection Television. There is a green light blinking on the front by the power button, and the tv does not come on?
very easy repair caused by failed DM capacitors. You can get the WS55511 DM repair kit from www.tvrepairworld.com which has the upgraded capacitors and the CD with repair instructions which should solve that issue.
Mar 03, 2011 | Mitsubishi WS-55511 55" Rear Projection...
How do we turn off the internal speakers to use a surround sound system on our Mitsubishi HDtv 55" 1080 SERIES TV?
IF it is a Mitsubishi WS-55613 rear projection set---
You with the Mitsubishi remote go into the customer menu and select Audio(it should be a separate item) and look for a setting for speakers--right cursor to it and up or down cursor to change it.
Some models may have this feature in the SETUP part of the menu.
if you have questions or need help let me know--I am here to help people.
If this information helps rate this solution as I do this here for free.
SD TECH
Nov 05, 2009 | Mitsubishi WS-55613 55" Rear Projection...
We have a 52 inch rear projection Mitsubishi not sure of the model number and the picture is starting to go blurry with reds and greens at the bottom of the screen
Here is another similar problem with a Mitsubishi Rear Proj. TV and it has some things to try and an estimate if that is the problem.
"Cost of convergence repair is always around $400"
http://en.allexperts.com/q/TV-VCR-Stereo-1749/Mitsubishi-WS55511-Projection-TV-1.htm
You could also try messing around in the menu for convergence adjustments. Usually it will let you adjust at 8 points on the screen.
Oct 26, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Television is on but no sound everything else is working
Usually when you see a symbol like that, the speakers have been disabled. Is there a menu option for turning off the internal speakers? This option is different than Mute.
Jan 22, 2009 | Mitsubishi WD-52525 52" Rear Projection...
PROJECTION TV COLORS DISTORTED
You can try to enter the menu and go to advanced setting and adjust the convergence. Push audio to go to advanced convergence and do the multipoint convergence to re-align the colors. If this doesn't solve, you may need to do a hardware repair.. all projections of this type will need a convergence IC repair sometime during their lifetime.
Dec 07, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Turn the speakers to ON
No I am not using a hdmi input. This problem exists within the unit itself. I am unable to manually turn on the Televisions internal speakers. they are currently set to off and are not highlighted within the menu to be able to turn them back on. I hope this helps. thank you!
Nov 17, 2008 | Mitsubishi WS-65909 65" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
128 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
