Question about Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune TL FAV6800AWW Overflows
I have a Maytag Netptune TL washing machine. It recently has started to overflow. My husband took it apart (shudder) but cannot see anything wrong. Any suggestions/advice?
  • crazidaisy65 Jan 15, 2009
    I have had this misterious overflow problem. It was happening for"no" reason with the previous washing machine so because I had another I looked that one p. Now its doing it too. It doesnt do it all the time. I have stood by and watched it and it it wont do it while Im there. I have made the loads smaller and I have decreaed the soap. I am lost now for what to do or why it is happening. Its driving me CRAZY and the flood on the floor is awful. HELP!!!
There is a semi clear part deep inside the machine bottom. If you shine a bright flashlight through it towards yourself, you may find you'll be able to see a coin stuck in the drain line. I had to catch all the water I could with a shallow pan when I took it apart then used the wet/dry vac to clean up the rest. It was not easy to get my children's (and probably my) loose change back, nor was it monetarily rewarding but it did save having to call a repair man.
Posted on Dec 30, 2008
  • 1jape Sep 25, 2011
    I had a quarter make it all the way past the part that is suppose to catch it and find the impeller blade of the pump. Eventually it ground down the blades and stopped draining. The thing that led it to me was listening and I could hear a small "tink" some times when it started and stopped trying to draing.
  • 283 Answers
Check the pump, pressure switch and related hose for small obsctructions. For reasons unknown they moved the pressure switch location to above the pump. Maytag Neptune TL FAV6800AWW Overflows - d60f89f.jpg
Posted on Oct 02, 2008
My maytag washer mavt236aww will not turn on
Check to be sure the lid switch was hooked back up. It is easy to overlook.
Nov 10, 2012 | Maytag Washing Machines
Maytag Neptune TL washer overfilling
yes i would agree the water valve is defective as if unplugged it should close,but also sounds like a pressure sensor or pressure hose problem that is also defective too due to the fact that it should at least start the wash cycle even though the water doesn't stop filling,so also it could be the central control unit,pressure switch or pressure hose
May 07, 2012 | Maytag Neptune FAV6800AW Top Load Washer
I have that moldy/mildew smell in my Neptune TL. I called about three years ago and they told me to run cascade through it. Now it is back and worse than ever and nothing seemed to help. My husband took...
yes there was a huge class action against maytag they are building rubbish we have machines here that are 4 months old and maytag wont cover there warrentys .. and they were the best washers you could ever buy till they were bought out by china. but they settled in 2004 but there are still many going on here is a link to get you strated.
good luck with it next time buy lg. how do we know there good? we have fixed 2487 washers this yr alone and only 4 of them were lg they are great machines.
http://www.consumeraffairs.com/news04/2005/maytag_lawsuit.html
Aug 03, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My maytag neptune TL when it gets down to 12 minutes left it starts flashing dc and wont finish the cycle, what is wrong?
You could have a Clutch malfunction if the machine is a FAV6800A or FAV9800A. If that is you r machine type see this post. Clutch Fix
Post back of you have questions.....Rich
Apr 23, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune do code - makes buzing noise when start button pushed - then stops & do code shows - door will not open - also codes pf & po show up
My husband read the book - took the soap dispenser off & did something with a little cord - washer works fine now.
Dec 27, 2009 | Maytag Neptune Washer
Maytag Neptune TL clutch problems- Class Action Lawsuit??
I sounds like this is a common problem with the Maytag Neptune TL after about 3-5 years. Mine finally went out yesterday after several months of bearings getting louder all of the time. It looks like the bearings and the controller are gone. What happened to washing machines that last 15 - 20 years?
Dec 07, 2009 | Maytag Washing Machines
Neptune tl washer
You will need to replace your timer control.
John
Sep 28, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer doesn't cut off water
The problem is the water inlet valve . The part which the hoses from the wall , connect to . Without the model number , I cannot tell you how to access the valve .
Sep 16, 2009 | Maytag Washing Machines
Neptune TL Console Issues
You were apparently sent the wrong part; the serial# is important when ordering these parts. You need to repl the failed part- which I assume is the membrane switch, not the actual machine control. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Nov 30, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Hoover washing machine HF7160E
I am a recently retired appliance engineer of 20 years, and this at first sounds like motor carbons, the belt needs to be placed on from the bottom motor pulley first the onto the drum pulley last, not easy to describe in words, anyway start with the carbons, then if they ok there is a module (main PCB circuit board) normally on Hoover washes located top of machine inside front right corner in a plastic casing, look for burn marks. work safe with electrics, always unplug first
Sep 09, 2007 | Hoover HF7 160E Front Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
1,036 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
