Question about Acer Aspire 5315 Notebook
Physics a cup of coffee is sitting on a table in an airplane that is flying at a constant altitude and a constant velocity. the coefficient of static friction between the cup and the table is 0.30. suddenly, the plane accelerates, its altitude remaining constant. what is the maximum acceleration that the plane can have without the cup sliding backward on the table?
  • Anonymous Mar 15, 2014
    Directions amounts of coffee per cup WEst Bed 12-42 Cup pARTY pERK
  • 660 Answers
I think you should do your own homework... :)
Posted on Oct 01, 2008
Need a bullet drop chart for a 1917 eddystone 30 06 with a 26 in barrel using hornady 150gr round.
Results are really only needed for caliber, load (in grains) and round in weight and style.
    [PDF]Standard Ballistics Chart - Hornady
    www.hornady.com/assets/files/ballistics/2015-Standard-Ballistics.pdf Velocity(fps). Energy(ft/lb). Trajectory Tables(inches). CARTRIDGE. BULLET. ITEM #. MUZ 100 yd 200 ..... Bullet. LRN . . . . . Lead Round Nose ..... 0. -6.4 -18.8 -38.3. AW 30-06 Springfield. 150 gr. InterLock® SP. 8108. 2910. 2637. 2381. 2139.
    [PDF]HMC 07704 Ballistics Charts as PDFs - Hornady
    www.hornady.com/images/ballistics/ballistics_charts.pdf Velocity (fps) / Energy (ft/lb). Trajectory Tables. CARTRIDGE. BULLET. ITEM # ..... LM 30-06 Sprg. 150 gr. SST LM InterLock. 8519. 3100/3200. 2867/2736. 2645/ ...
    [PDF]Hornady ballistics charts
    www.hornady.com/assets/files/ballistics/ballistics_charts.pdf Trajectory Tables. CARTRIDGE. BULLET. ITEM # HITS #. MUZZLE. 100 yds. 200 yds ..... C 30-06 Sprg. 150 gr. SST InterLock. 8109. 911. 2910/2820. 2686/2403.
    [PDF]Trajectory Tables - Hornady
    www.hornady.com/assets/files/ballistics/2013-Standard-Ballistics.pdf Velocity(fps). Energy(ft/lb). Trajectory Tables(inches). CARTRIDGE. BULLET ...... 30-06 Sprg. 150 gr. InterLock SP. 8110. 2910. 2637. 2381. 2139. 1911. 1700.
    30-06 Ballistics Chart & Coefficient GunData.org
    gundata.org/blog/post/30-06-ballistics-chart/ Jul 11, 2012 - ... 1000 yard 30-06 ballistic charting of a Remington 30-06 Springfield 165 Grain AccuTip Boat Tail with a BC (Ballistic Coeficient) of .447 that was created using our free ballistic trajectory calculator. ... 150, -1.1424, 2499, 2288, 0.17 ... 600 Round Glock Magazine · 10mm vs 40 Summary and Ballistics · How ...
    30-06 Springfield / Hunting & Ballistics:
    www.gunnersden.com/index.htm.30-06springfield-ballistics-hunting.html External ballistics pertains to bullet velocity, energy and trajectory down-range. ... Below are several hunting ballistics sight-in charts for 30-06 Springfield ammunition that ... Ammunition manufacturer: Hornady. ... Bullet weight: 150 Grains.
    30-06 Springfield:
    www.gunnersden.com/index.htm.30-06springfield.html 30-06 Springfield Cartridge, Rifles, Reloading And Ballistics Information. ... Ammunition: Hornady 150 grain SST bullet. Bullet diameter: .308 inch. Bullet
Jan 19, 2016 | Optics
How do I set up my new 10 cup Bunn velocity brewer to brew only 4 cups?
To do that it is a good idea to put water for four cups and four coffee spoons of coffee. Kolbrun
Oct 04, 2014 | Bunn NHB Coffee Maker
How to calculate coefficient of variation on TI-36XPro
As given in part three of the question, divide the standard deviation by the average then multiply by 100.
Sep 20, 2014 | Texas Instruments TEXTI36XPRO TEXAS...
Hi all im using Canon SX260 HS which have gps and altitude feature. Im having problem where the altitude reading is not accurate. Any idea why is this happening or anything i can do to make it right. Using...
I think this has to do with the limitations of the GPS device build in your Canon. The device is not build to fly in a plane. You are moving to fast. I'm convinced if you are on a mountain the device will have no problem displaying the correct altitude. And when in a plane, the small antenna inside will have trouble finding good signals. Look what the Canon does, while you are still on the ground. See if it finds enough satellites in a short time. Check if the airplanes body works as a shield.
May 13, 2014 | GPS
Hi, Using this Cuisinart Conical grinder is awful. The static makes the coffee stick to everything and makes it difficult when you are using this. Any suggestions would be greatly appreciated.
The only thing I've found that will work for this problem, which I certainly agree creates a mess, is to let the grinds sit for just a few minutes before opening the receiving cup. Especially in winter, this will give the static charge a chance to dissipate. A few minutes won't kill your coffee's taste, but it sure will lessen your cleanup!
Sep 14, 2013 | Cuisinart Conical Burr Coffee Grinder
Need to make about 15 cups of coffee, how much coffee and water I need?
Equal amount of water per cup = 15..
About 2 heaping table spoons per cup = 30 tbl spoons.
I also add ground cinnamon right on the coffee grinds
before starting coffee maker
Sep 30, 2012 | Coffee Makers & Espresso Machines
How to solve matices as in finding the values to
I assume you want to solve a linear system of three equations i three unknowns (x,y,z).
  1. Turn calculator ON.
  2. If you do not see icons, press [MENU] key.
  3. Use arrows to move focus to [EQUA] and press [EXE]
  4. In new screen select F1: Simultaneous
  5. Select the numbewr of unknows (in your case 3): Press [F2:3]
  6. A table opens: it has 3 rows and 4 columns
  7. Enter the coefficients in first equation on first line (a1, b1,c1) and the constant term d1.
  8. Enter the other coefficients and the constant terms at the right places, pressing [EXE] after each entry.
  9. When finished coefficients and constant terms, press [F1:Solv]
  10. The solution vector (X,Y,Z) is displayed on next screen.
  11. Note: if the coefficients are integers, it is possible that the solution vector will be displayed as mixed fractions (exact solutions),
  12. If not, the solution vector will be in decimal format.
Mar 02, 2010 | Casio FX-9750GPlus Calculator
I recently bought an Avanti Art Deco 10 cup espresso machine and am disappointed that I cannot make HOT coffee with it. What can you suggest?
When the water boils in the bottom chamber the steam creates pressure and pushes the water through the grounds and into the top chamber. It's hard to imagine that the water going through the grounds is not close to boiling temperature unless you are using the coffee maker at high altitude where the temperature of boiling water would be lower.
Oct 26, 2009 | Avanti Art Deco 4-Cup Espresso Machine
Acer Aspire 5315 Notebook Logo
140 people viewed this question
Brian Sullivan
Brian Sullivan
