Question about Olevia LT37HVS 37 in. LCD HDTV
No picture My olevia 747 has no picture ... power is on ... BTW I am one of the designers of the HQV chip
  • clamper1797 Oct 02, 2008
    Fixed it ... bad (intermittent) power cord
  • 2,071 Answers
LCD TV TroubleshootingThe defective LCD TV may have the following common symptoms:
Symptom: No picture on screen but LCD TV still has sound.
Solutions: The problem is cause by defective inverter. Replacing ivnerter will solve hte problem. Symptom: Screen flash on and off between 1/2 to a few seconds, but power indicate light stays on and TV still has sound.
Solutions: The problem is cause by defective inverter. Symptom: Blue Screen but no picture
Solutions: The problem is cause by defective Main Board(AD Board). In some cases, this problem may cause by the defective Screen Controller board. Thsi board is mounting on teh back of LCD TV Scree. Symptom: Power light stays on but no display and sound
Solutions: The problem is cause by defective Main Board(AD Board) or Power supply board. Symptom: No Power or Power indicate light does not lits
Solutions: The problem could cause either by defective Power supply board or defective Main Board(AD Board). Symptom: Screen is half dim and half bright
Solutions: The problem is cause by defective LCD Panel.It needs to be replace.
This is a power supply problem. Try to check the fuses ,fusable resistor ,capacitor and transistor in power supply board.
Hope it may help you;
Regards,
VOTIT
Posted on Oct 02, 2008
My tv sound keep s going out
Check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Jun 12, 2015 | Olevia Televison & Video
My olevia 747 B11 not power, a blue led is just hanging
From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
May 19, 2015 | Olevia Televison & Video
I have an Olevia 226-s11 that shows the Olevia screen when powered on but no picture thereafter. Sound works, but no picture.
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Jan 12, 2015 | Olevia Televison & Video
I have an Olevia Model #: 747-B11 P/N: FM1-047000E-S00 S/N: VLCD 79140278 Unit comes on gives you the Olevia screen than you get "NO SIGNAL" at the left bottom corner. Cannot switch SOURCE...
Hi Hernould,
First of all thank you for posting your question here at Fixya.com.
My first advice is to do system reset by unplugging the unit from the outlet(AC source) for at least 1 hour to refresh it and back to factory settings.
If the symptoms remain the same after the system reset, this is an indication that there's a faulty board inside. The symptoms you've described indicated that the T-con board, inverter board, power supply board, backlight of your unit is working but there's a problem on the mainboard that's why it display the words "No Signal" and unresponsive to remote control and front panel button key.
The mainboard has a lot of circuitry that has each functions. Suspected faulty circuitry on the mainboard are the Microcomputer, AV circuitry, I/O circuitry, EEPROM. Click it HERE for the mainboard replacement.
But before you replace the mainboard I would advice you to inspect the electrolytic capacitor on the power supply board feeding the mainboard. If one of the supply voltage is gone to malfunction, the circuitry on the mainboard will be disable. Check the encircled capacitor.
Most of the faulty electrolytic capacitor has a physical indication of fault like bulged/dome at the top and can be easily identify through visual inspection. See sample picture below of faulty capacitor with dome at the top.
Also, don't forget to check if your unit is under warranty period before an attempt to open the back cover, avail it because the manufacturer will fix it for free.
Please let me know if you need further assistance.
Rating and feedback are highly appreciated.
Have a nice day!
Good luck and take care!
Kind Regards,
Mjsazon
Dec 09, 2011 | Olevia LT37HVS 37 in. LCD HDTV
Blue power light is on but no picture......olevia 537
I have a Syntax Olevia 532-b12 and ironically, the blue light is on when power is off (and turns off when the power is on...) I assume it's the same for the 537H
Feb 23, 2011 | Syntax Olevia 537H Television
My 42 inch olevia 242fhd-t11 tv just shut off and will not come back on.. The blue led light will not come on either... Also was having intermittent sound issues for the last couple of days prior to it not...
I just repaired this identical problem on the same model TV. You have a bad power supply (also known as an SMPS). The board is model FSP271-4F02, and is about $75. Unlike the main board for this TV, you can find the power board relatively easily. Try shopjimmy, for example. Replacing the board isn't too difficult if you have a reasonable mechanical ability, have some tools, and are careful.
Jun 12, 2010 | Olevia LT42HVi 42 in. LCD Television
I have sound but no picture on an Olevia 237V
If you get no picture on all inputs (TV, DVD, ETC.) then the problem can be in the backlight inverter board or the power supply that supplys the power to the inverter board.
Nov 01, 2009 | Olevia 237T 37 in. LCD TV
My pwoer supply blew up as well part number HGP 180-p240JIFE
Ladies and Gentlemen,
Relative to Olevia TV Power Supply Problems Solution provided by: kb8tez Matt, the problem he had was Electrolytic Capacitor CS21. Upon careful examination of the Power Supply Circuit Board I find that CS21 is in parallel with CS22. Simply replacing BOTH Capacitors makes for a more permanent fix. Radio Shack P/N 272-1032 1000UF 35V Capacitors @ $1.59 each plus tax makes a very inexpensive repair. Apparently the same power supply circuit board is common to many different Olevia Models.
Fastest Robe
Aug 25, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Have sound but no picture
power supply or main board ( possibly missing clock signal)
Mar 26, 2008 | Olevia LT32HVM 32 in. LCD Television
Olevia 747 won't come on
I had the same problem with a 437. It just shut off one day and I could never turn it back on again. I called Syntax Brillian and they told me the mother board was probably shot. They sent me a new TV and took the damaged one back.
Feb 26, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Olevia LT37HVS 37 in. LCD HDTV Logo
618 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
