Question about Smith Corona Wordsmith 200 Typewriter
Typewriter margin settings
Is there a basic way to set up margin settings? I have a test Friday and don't know what type of typewriter; I will be testing on.
    Scholar:
  • 183 Answers
Well this is a little late for your test, but, for future reference - in general for electronic machines you need to position the printhead where you want the margin set then hit the appropriate mar. set key.
to move the printhead past where the mar. is set you need to hit the 'mar rel' key and use the spacebar or backspace key to position the printhead. some machines don't have a "mar rel" key and on these machines just using the space and back sp. keys will do it.
Posted on Nov 03, 2008
Keypad seemed to be locked after typing one alphabet. What's wrong? pls help
The R. margin may be set all the way to the left, Type until it locks, press but don,t hold the margin release key, space to desired location, press the R. margin key.
DickyO
Jul 06, 2015 | Nakajima AE-800 Typewriter
Unable to set right margen
The typewriter will type thru the right margin it simply beeps when you get near it
Jan 01, 2015 | IBM Lexmark Personal Wheelwriter 2...
How do I increase the margins on the typewriter
To set a margin beyond the left or right margin, move the carrier (or cursor) to that margin, press the Margin Release key, then proceed to move the carrier (or cursor) to the desired position. Then, press the Left or Right margin key to set the new margin. A beep will sound indicating the new margin has been set. When you set a new left or right margin, the previous margin is automatically cleared.
Alternatively, you can type beyond the right margin by pressing the Margin Release key and then continue typing when the carrier (or cursor) stops at the right margin. To type beyond the left margin, press the Margin Release key and then the Backspace key to move the carrier (or cursor) to the position where you want to start typing.
Remember to always use genuine Swintec ribbons and lift-off tapes for your Swintec 7040, which can be found at Swintec Typewriter Supplies .
Aug 19, 2014 | Swintec 7040 Typewriter
Cannot set left margin instructions on clearing display before setting margins
Go to the L. margin , press but don't hold the MAR REL key, backspace or space to the desired location, press L. MAR key.
DickyO
Jul 13, 2011 | Royal Satellite 80 Typewriter
I have an SX-4000 Electronic Typewriter and use it from time to time BUT I do not know how to reset the margins....basically expand them beyond the norm. Please help - I did do the ALT and then the 4 or 5...
Try this procedure to set and adjust the margin:---- Use the "Space" and "Backspace" keys to set the margins by positioning the carrier where you want each margin. Press the "Alt" key along with the "L Mar" or "R Mar" key, depending on which margin you are setting, left or right.Press ALT with L Mar key to adjust margin on left side.Press ALT with R Mar key to adjust margin on right side. ----------------- For more help.Click this link below and check page number 11:---- http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_SX4000_EN_219.PDF ------------
This should help.Thanks.Helpmech.
Jan 05, 2011 | Brother SX-4000 Typewriter
How do I reset the margins on a Nakajima typewriter model AE-740
If you want to set the machine back to factory settings do the following... switch the machine OFF.
While holding down the Margin Release key switch the power back ON. The machine will begin typing a pre-programmed test page....let it run for 5 seconds...switch the machine back OFF.
Give it 5 seconds and switch it back On and settings will be back to factory settings...be aware this will clear all memory of any docs or info you had in memory.
Oct 28, 2010 | Nakajima AE-740 Typewriter
Tab Release
You can reset all functions to original settings by doing this simple self test.
1. Turn typewriter off
2. Hold down the margin release key.
3. While holding down margin release key, turn on typewriter.
4. release margin release key
typewriter will now begin to type on it's own.
5. Turn typewriter off and then on again
all settings will now be cleared.
Feb 02, 2009 | Swintec 7040 Typewriter
Setting right margain
some typewriters just have a beep to let you know the right margin is coming. the keyboard might not lock up when it gets to the right margin. you might be able to type right through it. also you may be setting it too close to the left margin.
Nov 29, 2007 | Brother EM-530 Typewriter
Help with Typewriter
hold down the code key and press the margin release, to set margin, just hold code release margin, space over to where you want it and then press Margin set, left or right.
Jun 05, 2007 | Brother GX-6750 Typewriter
Smith Corona Wordsmith 200 Typewriter Logo
123 people viewed this question
Top Smith Corona Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Jim Goldsmith
Jim Goldsmith
Are you a Smith Corona Office Equipment and Supply Expert? Answer questions, earn points and help others
