Question about Philips Magnavox 20MS233S 20" TV
Remote no longer works
After a nearby lightning strike (which took out a variety of other stuff) the remote no longer works on my set. It's not the remote itself as I also have my Dish remote set up to control the TV and it doesn't work either. It sounds like it might be a power supply problem with the remote receiver and I do have the skills to work on it but I'd like some guidance before I dig in.
  • Bruce Ferry Oct 13, 2008
    So much for this site being useful. It's a front for a money grab.
    Genius:
  • Philips Master
  • 1,689 Answers
In side of the TV set there is a remote receiver module. In some models of sets, there is no module. They use descrete components on the main circuit board. The fault could be in the remote receiver section. In some models of TV sets there are some remote amplifiation circuits along the way to the uPC controler. There could be a fault along this path.
The service tech would troubleshoot this by verifying the voltage supply to the remote receiver circuits. Then he would shoot an IR remote signal to the receiver, and then follow the data flow from the output of the IR reciever circuits along its signal path to the uPC controler. This way, he should be able to see with the scope where the data signal is failing.
Jerry G.
Posted on Jan 10, 2009
Liftmaster 3265M. Two units. Why does neither work since lightning storm?
Chamberlain Liftmaster garage door opener problems ...
? 3:10
https://www.youtube.com/watch?v=Zq_CxeTXoSM
Jul 2, 2013 - Uploaded by Mike McCarron
Might have taken a lightening strike, knocked out GFCI that was on the circuit that garage door opener was on. When I ... And sometimes after it happens it takes 30 or so seconds before the opener will work again. ... The keypad unit worked well butneither the homelink or the remote units worked.
Garage Door Openers - Lightning Strike - Forum - Bob Vila
www.bobvila.com/posts/30883-garage-door-openers-lightning-strike?...
Aug 6, 2005 - The house did not lose power and I do not believe the house was actually hit. ... the light comes on on the unit (as expected), but neither door opens or ... Afterplugging it back in, try opening the door with the hardwired button first - if it still doesn'twork, chances are your opener's taken some damage but not ...
I Have A Liftmaster Garage Door Opener Unit. The Remote Work ...
www.diyforums.net/i-have-a-liftmaster-garage-door-opener-unit.-the-re.
Jan 01, 2016 | Building Materials
Set was hit by lightning and since then remote does not work, set has been repaired up to that point.Model#42PFL770/F7
A lightning strike will damage a lot of components - the ICs for the remote reception in the set are probably fried
Sep 29, 2014 | Philips TV Tuner Video Capture PCI Card -...
Why does my generator start constantly?
if a lightning strike was anyplace close (30 yds) it's a safe bet your gonna have to replace the control board in generator also Id have a qualifyed tech ck out your auto transfer switch ,I bet he''ll find that you fried your coils on your switch too , do that before changing control board cus if ya hook up a new one to a bad coil ya just bought two of them
May 24, 2014 | Kohler Electrical Supplies
Will a nearby lightning strike cause a power board failure?
It could happen yes it would depend where the strike entered the TV. Not all lighting strikes hit on the electrical lines, on a TV they can come through the cable, as well as a antenna if you have one hooked up.
May 10, 2014 | Samsung UN32EH4003F
Fan doesn't work after nearby lightning strike
Your issue is most likely a faulty speed control, which presumably was destroyed by a power surge. The part is integral to the remote receiver in the fan housing. You can purchase spare parts for this fan through Home Depot (Hampton Bay) Service at 800-654-0688.
The fan unit itself is manufactured by AirCool 800-896-4908
Unfortunately the Brookdale fans with a Rhine 7058 series controller have a separate circuit wire for each speed. Rewiring this to use a conventional fan receiver that uses a single wire to control each speed is not easily achieved. Your best bet is to order a new remote receiver of the proper type.
Jun 04, 2010 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
03 Kia Sorento,both keyless remotes quit working.
Perplexing ... OK do the remotes work elsewhere from I'm assuming your driveway ... or do they work nowhere? (I was going on an radio interference theory here) As I've experienced this in close proximity (like 100 feet) from high power TV towers.
otherwise it sounds as they have all lost code simultaneously which has lottery jackpot odds ... Did you have a lightning strike nearby with both vehicles present? If these are OEM systems they may have to be re-activated (coded to your vehicle) at the dealer unless there are instructions on how to do this in the owners manual ...
May 12, 2009 | 2005 Kia Sorento
30HF85 TV with CT-877 remote, which doesn't work.
I had the same problem with my remote...over time it slowly stopped working. (sorry for poor terminology) I noticed that one of the battery terminals was corroded and that the metal connecting the battery to the board was completely gone. I simply swapped this out with one from another remote and now its working fine. Seems the only issue is that the battery was not connected.
I hope this helps.
Oct 29, 2007 | Toshiba 30HF85 30" TV
Philips Magnavox 20MS233S 20" TV Logo
125 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
