Kenmore Elite washer
Hello , I have a top load washer (110.2692 ) its about two years old. My leak detector went off . When I pulled washer out i did find water leaking from bottom. More disturbing was I also found a oil / watery mix. Or maybe it was a greasy / watery mix. anyway that is what I found on the floor and touching (what I call the drive shaft) found it there. Being stubborn, I cleaned everything up and threw in a small load.I put paper towels under unit and turned it on. After cycle was done I pulled out paper towels and found a small amount of water. I was just curious. I know it must be something serious , because of the oil / grease thing. Any ideas ?
Thanks , Tom
  • 5,911 Answers
Okay...what you are talking about is a honey colored oil, right? The gearcase (transmission) is filled with this oil. Sometimes the gearcases are prone to leaks. There is a small breatehr hole onthe top of the gearcase housing that oil will sometimes weep out of when it expands. This could be a potentially serious problem, as a leaky gearcase COULD mean it is beginning to fail. But...not always. This is kind of a gray area when it comes to this model washer. As leaking oil is generally considered a bad thing, the gearcase could actually run for quite a long time and experience no failures, or further leaks. I would keep the oil cleaned up and run the washer as you normally would. If the leaking becomes progressively worse, the tub begins to spin slower than usual, requires assistance to spin, clothes aren't spinning dry enough, or if the gearcase starts to exhibit loud noises, stop using the washer and plan on needing a replacement gearcase. They generally run about $150 and can easily be installed by the DIYer. If you wish to pursue that as an option sometime, just let me know and I can provide you with the steps required to do so. At this point, monitor what you have and let me know how much the gearcase is leaking.
As far as the water leaking is concerned...you need to determine WHERE it is coming from. If it is leaking in the center under the wash tub in the location of the gearcase, the tub seal probably needs replaced, or you may have a crack in the tub somewhere. If the washer is leaking near the front, this is generally a sign of a leaking water pump, or associated hoses. Check to make sure the hoses are clamped snug. If the washer is leaking in the back somewhere, I would suspect a leaking water inlet hose, or drain hose. The best way to make the determination is to place a sheet of cardboard under the washer when it is empty. Do a load of wash and pull the cardboard out when done. Note where the leak patterns are and get back to me. I need to know where the water is coming from before I can give you a correct assessment. I hope this helps guide you in the right direction.
Posted on Oct 02, 2008
Water pours in on spin cycle
The first thing i would check is your boot around the door for a rip or tear. Also check the drain line for any types of leaks. You can also remove the bottom panel there will be three torx screws and you can look at your drain pump while in spin and drain cycle to see of the leak located in that area.
Hope this helps _MJ_
Jan 29, 2010 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore Elite Top Load 5 years old which leaks ONLY during the spin cycles. I beleive it may be water coming over the top of the tub. I need to comfirm and get instructions on the removing of the...
it is the water pump probably it only pumps out and has pressure on it when it is spinning easy to remove just pull it away from the wall a couple of feet and tilt it back lay down on the floor and it is the first thing you see next to the front panel two clips and a couple of hose clamps
Jul 01, 2009 | Kenmore 22422 Top Load Washer
Kenmore Washer leaks
When my husband came home he took the washer apart and it was the pump. Small pin hole leak in this glob of gray sealer that seals the two plastic parts together. Just been waiting to fail, I'm sure. Thanks for your help.
May 28, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite top load washer leaking
in the two front corners insert a putty knife and pry upward.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 05, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite 110.2949 water leak from center front of unit
Check your pump. The pump is located on the end of the motor. You can tip the machine back and pull the pump off to check it. After you take the pump off. Check to see if there is a water stain where the shaft of the motor goes through the pump. If so you pump is leaking.
Nov 17, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore elite top load washer
error code with this? f11 or f22 are control board related commucation errors.
Jun 02, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite top load set
fabric softener will leave oily looking stains on certain fabric. oil stains will not wash out.i do not recommend using softener in washers it gums up everything!
Nov 03, 2007 | Kenmore 22422 Top Load Washer
Kenmore elite top load about 3 years old
Check the boot for tears, also remove the lower axcess panel (Three torx screws or 7mm) and see where the water is coming from.
Sep 24, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
264 people viewed this question
Top Washing Machines Experts
