Question about Mitsubishi WT-46807 46" Rear Projection Television
Help me WT-46807
My tv has no picture and i took it a part to see the fuses.There is a control inside the front that has 6 controls one says "focus" cant figure out any others. If i turn them i can get red blue and green waves across the screen. Does this mean that the bulbs are still good? What can i check now ? help please i want this tv to work!!!!!!!!!!
  • juschillin Oct 03, 2008
    I do have this same problem! It turns on,,Black picture,,no sound that i can hear,,but when i turn it off i hear the sound system go off (thump) Is this gonna cost me a lot to get it fixed?
    Sergeant:
    Champion:
  • 227 Answers
Dear friend i have a question for you. do you get sound?
if you do you may have some bad caps or there is a 5volts regulator that goes bad sometimes and you get no picture.
lets start with this...
Posted on Oct 01, 2008
How do I replace the fuses on a WT-46807 that protect the convergence circuit?
There are no fuses going to the convergence board, the converegnce IC needs replaced.
Aug 08, 2011 | Mitsubishi WT-46807 46" Rear Projection...
Volume up then pic gone
You've got a bad solder connection,or broken foil line,s on the pcb (printed circuit board1.gif).Narrow it down by pressing in different places,or use plastic or rubber tip.If not,then you got a shorted load on this fuse and diode.do you have a schematic,whats at the end's of this circuit.D represents a <Diode> not a transistor.
Jan 28, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi model Wt-46807 Power shuts down after turning on. Tried the solution of pressing the menu & input buttons at same time for at least 5 seconds. Power light error code was 2 blinks/pause 2...
hi,
Error code 2-2 indicates "Short Protect Circuit" problem in tv.
Need to check pico fuses in power supply as one or two got blown due to bad convergence chips.
Below is an exploded view of tv chassis, power supply and convergence area has been marked to give you better idea to look for pico fuses.
Unplug tv from wall socket before to repair/check any thing inside tv.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Oct 16, 2010 | Mitsubishi WT-46807 46" Rear Projection...
My Mitsubishi WT-46807 rear projection TV worked fine last night but this morning though it "clicks" and the green light comes on, there is no picture or sound from the television. I have tried to unplug...
I have a 64' samsung tv , It did the same thing and it was the lamp inside it. I bought it online at parts store.com, it works fine now. We fixed it ourselves and didnt know the first thing about tvs. Good luck
Sep 29, 2010 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WT-46807 Bottom of picture cut off
YOU HAVE A VERTICAL DEFLECTION PROBLEM, THE RETURN CAP IS DRYING OUT AND MUST BE REPLACED
Dec 27, 2009 | Mitsubishi WT-46807 46" Rear Projection...
Sony rear projection tv model KP-53V15 turns on, have sound but no picture, after a while, picture comes on, but later goes out again, picture keeps coming and going. Where do I start looking?
Adjust Screen Volts (G2) of all 3 picture tubes and screen volt control knobs are on focus block located under speaker grills at front of TV.
Remove speaker front grille of TV, look for focus block that has 6 control knobs, 3 knobs are for focus and 3 for screen volts, increase volts by turning little bit control knobs of screen volts and this will solve your problem.
Nov 02, 2009 | Sony Televison & Video
Mitsubishi WT-46807 won't stay powered up.
try giving the back cover a thump it may be dry jointed..
Sep 14, 2009 | Mitsubishi WT-46807 46" Rear Projection...
Sounds like you have a jammed / shorted out button on the control panel... Try un-plugging the tv, and then unplug the "button panel" on the front of the tv...see if you can turn the tv on with the remote. Sometimes if one of the buttons gets shorted, it will "lock" the processor from doing ANYTHING else, as it thinks you are holding down the defective button. If this works, simply have the defective switch or control panel replaced, or just leave it unplugged and use the remote only! Hope this helps!
Jan 03, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WT-46807 46" Rear Projection Television Logo
89 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
