Question about Panasonic Microwave Ovens
Our microwave NN-H965WF STOP JUST AFTER 4-5 SECONDS. wHEN WE RESTART THE SAME SITUATION OCCURS. When we open the door the light is on. I don't know if we got to change a fuse or somethin else. What can we do?
    Sergeant:
    Champion:
  • 223 Answers
I think I know what the fault is but in all honesty it would be irresopnsible of me to advise you on how to fix it as not only are the capacitors in microwaves KILLERS because of the high voltages involved you would also need a microwave leak detector to make sure that you are only cooking food and not everybody else who is standing next to it. A badly leaking microwave is leaking radiation after all. Please entrust the work to a competant technician. Good luck.
Posted on Oct 01, 2008
Panasoni microwave NN-H965WF fan stays on when door closed
Because Panasonic use an inverter system to generate microwave energy the machine has to cool itself down at a steady rate and this is generally the reason the fan stays on when the door is closed,hope this helps
Mar 04, 2015 | Microwave Ovens
How do I replace the light in my Panasonic nn797s?
Remove the case and replace the lamp located between the magnetron tube and the control panel. If I remember correctly there is one phillip screw holding the base to the oven.
Oct 12, 2014 | Panasonic Luxury Full-Size 2.2 Cu. Ft....
Why does NN-SN651x Microwave sometimes starts, sometimes not ?
Adj door latch switch assembly. It is not aligned properly preventing the door hooks to engage.
Aug 31, 2014 | Panasonic Microwave Oven NN-SN651B
Why does my microwave turntable turn when I open the door?
We recommend you have the microwave evaluated by an authorized service center.
Authorized service centers can be located in the below link.
www.panasonic.com/repair
May 01, 2014 | Panasonic NN-H965WF - Microwave Oven...
Panasonic NN-H965WF Microwave oven
We recommend the microwave is evaluated by an authorized service center by using www.panasonic.com/repair Welcome to Panasonic Online Repair
Apr 13, 2014 | Panasonic Microwave Ovens
I have a panasonic microwave oven model # nn-h965wf which has a bad inverter board. how do you replace it
if your unit is attached to the kitchen your need to use the screwdrive for to loose and remove the microwave.
2)proceed and open the carcase and see the screw inside of the board
3) caution can be there to due the magnetron (valve electronic), and proceed to unscrew with screwdriver and take out the board.
4) proceed in contrary sense.
5) Proof., remember you must to unpplug the power before to do anything.................. CAREFULLY.
Jul 11, 2012 | Microwave Ovens
Child lock
remove some time mother board battery or" internal bottom flow.
May 27, 2012 | Panasonic NN-H965WF - Microwave Oven...
Panasonic NN-T994SF Microwave Oven quits after 15 seconds
my microwave shuts off after a few seconds. is there a fuse that needs replacing?
Feb 01, 2010 | Panasonic NN-T994SF Microwave Oven
NN-T774 INVERTER STOPPED WORKING AFTER 4 WEEKS
Check to make sure one of the plastic hooks on the door was not broken off. If both door hook latches are functional then the most likely cause of your problem is one of the latch switches located behind the control panel. These switches will fail if the oven user opens the door frequently BEFORE the cook cycle ends. Always push STOP/RESET before opening any microwave oven door.
Dec 30, 2009 | Panasonic Microwave Ovens
Microwave Ovens Logo
81 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
