Question about Sega Genesis 2 Console
How do I set up a sega genesis?
I think I have all the parts, but I am not sure how to get it on the TV. I have it on channel three but it's not coming in and there is no picture or sound.
  • bailla64 Mar 18, 2009
    what is a sega mega drive?
  • Anonymous Mar 28, 2009
    i dont know how to make it go on the t.v
  • 52 Answers
Here we go
This is a step by step with testing set up for the sega mega drive
first plug the power plug into the mega drive and turn it on (there should be a red LED light)
plug RF lead into the back of the TV and make sure the switch is set at the megadrive side and not the ariel side, if you have a switch. (or you can buy scarts from www.retro-cache.com)
Now turn off mega drive, put a game into the slot and and then turn the console on
Select a channel on your TV and re-tune it into the mega drive. (on some TV's the tuneing is around the C36 area if that is any help)
If you tune into a blank screen than turn the mega drive off, remove the game, clean it and replace the game and try again.
Posted on Oct 29, 2008
On the back there is a little swich. turn it on to channel 3 and it wil work.
if this dosent work put it on channel 4.
Posted on Nov 06, 2008
I have an old sega genesis and got new plugs to plug it into my 42'' HDMI Vizio. all the plugs are in and the light is on but the screen stays blank. I have tried blowing on the game and got the...
Did you say HDMI? I don't think there are HDMI plugs for Sega Genesis. You can plug in your Sega via composite video through RCA cables (yellow, red white) or via RF signal through coaxial cable. Check your TV's specs to make sure it can display standard definition content via composite or via RF.
You can double check to make sure your Sega Genesis is working properly by plugging it into an old-fashioned CRT (fat tube) television set.
Sep 02, 2011 | Sega Genesis Console
Missing the part that plugs from console to television where do i find?
  • Hi, I can help.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Aug 29, 2011 | Sega Genesis Console
How can I hook my sega genesis console to my Direct tv box?
Don't plug your Genesis into your satellite box. Plug your Sega into the back of your TV set. Get a Sega Genesis composite video cable. Run that cable from the mini-DIN connector on the back of your Sega to the RCA (yellow, red white) connectors on the back of your TV set. If you don't have any spare RCA connectors on your TV set, try a composite video switch.
Aug 20, 2011 | Sega Genesis Console
Wont come on
Man I haven't seen an actual Sega Genesis console in years. Anyways...
1) Make sure that everything is plugged into your system properly. 2) Check you make sure your TV is on the right channel 3) Check to make sure the fan is at least powering up when you turn on the Genesis. If it is then the Genesis is working. 4) Plug something else into the TV to make sure it works.
Remember, HDTVs and LCDs and this whole Al Gore's Gone Green thing wasn't around when they made the Sega Genesis, so conventional means to playing a Sega aren't your best option. Don't plug it into the wall either, make sure you are plugging it into a surge protector.
Hope this helps.
Jan 01, 2011 | Sega Genesis Console
When i plug in my sega genesis the light is on but no video do you know whats wrong with it?
Double check to see if your RFU or A/C Adapters are properly connected. Also, if it is an RFU adapter, make sure the Channel on your TV matches the Channel on the adapter.
Jun 19, 2010 | Sega Genesis Console
How to hook sega genesis up to a flat screen tv
You need to hook up the cable coming in from the outside to one end of the Sega RF cable and hook the male end of the RF connector from the Sega into the cable input on the TV.On the back of the game console there is a channel selector switch.It is either CH3 or CH4 which is what your TV needs to be on when you turn on the console.If one looks bad try switching the channel selector on Sega and on the TV.
Good luck and game on!
Jun 09, 2010 | Sega Genesis Console
My sega flashes on screen but wont come on
Video game cartridge terminals and the console connector pin require servicing similar to this service.
Please let me know how I may assist further.
Apr 19, 2010 | Sega Genesis Console
Need step by step directions to hook up a 16 bit Sega Genesis
There should be two plugs on the back of the sega. One for the power cord, and one for the audio/video cord. The audio/video cord is a coax cord with a little box in line. Hook your cable or antenna cable into the jack on the box and hook the end of the cable from the sega into your tv. There will be a switch on the sega or on the box somewhere that designates channel three or four, this is what channel your tv will need to be on to use the sega.
Sep 23, 2009 | Sega Genesis Console
No sound on Sega with lcd tv
If you are using the RCA 8 or 9 pin DIN connection, make sure one of the pins is not bent in or missing. If you are using the RF adapter, be sure that the channel selection switch is completely flipped to either channel 3 or 4.
Sep 13, 2009 | Sega Genesis Console
I have a sega genesis. i hae no look how to hook it up. please help me.
well a sega genesis there are 3 different models all either using RF adaptors or AV cables
if RF adaptor please follow this
plug the RF adaptor into the back of your tv the coaxal cable for your tv service ushally runs through this, and plug it into the the back and you can also plug the service into the RF adaptor for the sega genesis. plug the power in and make sure you are on the correct channel (3or4)
If you are using AV cables please advise and I will post the following for that.
Aug 11, 2008 | Video Game Consoles & Games
Sega Genesis 2 Console Logo
4,030 people viewed this question
Top Sega Video Game Consoles & Games Experts
DROPNDEAL
DROPNDEAL
Josh Whitehead
Josh Whitehead
Reggie brown
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
