Question about Motorola Mobility RAZR V3
No service everything is fine in the fone but the it always says noservice, whether the reception is good in that particular area but still no reception.
  • 4 Answers
It should be related to your wireless account.
You should contact your service provider and check if there is an issue with your account.
Posted on Oct 03, 2008
Get service at my home?
You must live in a "shadow". Not every area can get cell reception. I have the same problem. No cell reception at my home, but 1/4 mile up the street, it's fine.
Jan 15, 2015 | Cell Phones
My phone sony w960i always on emergency mode unable to access network. but reception is good in my area
your network driver is cruppeted update your phone software using sonyericsson update service
May 20, 2011 | Cell Phones
How do you hook up an antenna to a tv?
Optimum reception of colour requires a good signal and will generally mean that an outdoor aerial must be used. The exact type and positioning of the aerial will depend upon your particular area. Your dealer or service personnel can best advise you on which aerial to use in your area. before connecting the aerial cable be sure to turn off all main power switches. in the media recorder you will see an aerial connector one is the input and the other one is the output. your input is the antena and the output goes directly to your tv aerial input.
Oct 24, 2010 | RCA Televison & Video
How to hook antenna to tv?
optimum reception of colour requires a good signal and will generally mean that an outdoor aerial must be used. the exact type and positioning of the aerial will depend upon your particular area your dealer or service personnel can best advise you on which aerial to use in your area. before connecting the aerial cable,turn off all main power switches. vhf or uhf it must first go to the media box and you will see the input aerial cable connect it there and the output go to the back of your tv that indicates aerial input terminal.
Oct 15, 2010 | Maxent MX-42HPM20 42 in. Plasma HDTV
My fone fell into water. well everything works now except the reception. I have no service and cant seem to get any signal. how do i fix this?
The phone will have to be opened and cleaned. There is probably corrosion due to the liquid damage shorting out some of the pins on the motherboard. You can clean it using an old toothbrush and some denatured alcohol. If this doesn't work, then the RF ic or port has probably gone out. They will have to be replace by your local repair shop.
Dec 08, 2009 | Samsung SCH-u340 Cellular Phone
2007 Sonata AM radio has no sound. Hit search at 100% volume and tuner scrolls non stop. FM is fine. Antenna?
AM is reflective, FM is not. Best reception is always FM because of this reason. Reflective AM bounces off everything - buildings, trucks, houses, power poles, etc and cause 'shadow' RF which confuses the the radio's AM tuner. However, if this condition exists ALL the time (whether you driving or in your garage), then the problem is either in the audio unit itself or in the rear window antenna (or connection to it). Left "C" pillar cover removed, you'll see the physical connections to the window antenna (it's also the rear defroster heating elements).
Oct 19, 2009 | 2007 Hyundai Sonata Limited Sedan
No reception in our house
the reception quality around your house has dropped, probably because of new high rise buildings in the area or trees interfering with the reception. Best option buy a network booster to improve your reception quality.
Sep 28, 2009 | Motorola Mobility i880 Cellular Phone
Just got a Blackberry Pearl and have had many dropped calls after having poor reception. Any idea how to solve this problem?
for dropped call you need first chk weather you are getting proper signal on the handset or not and then chk if you are having this problem i one particular area or multipal area's. Then you need to contact the service provider so that they can help you.
Jul 31, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
No reception on cell phone "No Network Service"
You need to check the RF. The RF is a component that pick up the signal. It is usually placed on the upper portion of the phone where there's a small exhaust so that the RF could pick up the signal better.
Once the RF gets wet, the component might become defective.
You need a phone tech to check or change the RF.
Have a great day!
May 27, 2009 | Sony Ericsson w580i Cellular Phone
Motorola Mobility RAZR V3 Logo
41 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
