  • jelegance34 Oct 02, 2008
    While plugged in. When I press the power to come on you can hear it pop on then it pops back of with no picture. and then the power light flicks on and off continuously.
    L. Green
  • 41 Answers
The problem of your tv is the flyback...the power is fluctuating that makes the power light flicks on and off continuously.change the flyback,the flyback is apart that have a cap and connected to the tube...
Posted on Oct 02, 2008
I have a new smart blue ray player and am trying to set it up using a hdmi cable to my sony KP-46WT510 tv and I have video but no sound?
Two things come to mind. !. are your cables plugged in right? Yellow->yellow, red->red, white->white? 2. Is the sound on the TV itself turned up?
Nov 28, 2013 | Sony KP-46WT510 46" Rear Projection HDTV
CAN ANYONE HELP i'm having a problem keeping the timer from going off and shutting the whole tv off. My kp-46wt510 sony widescreen from 2003 is doing the same thing, picture is bowed in the middle and...
Most likely you have turned on the sleep function. 2nd button from the left on the top of the remote hand unit. Keep pressing until "sleep off" appears on-screen.
Timer in user's menu is activated to turn off TV a specific time. Go to timer menu and adjust timer, then push cancel on the remote, this should reset timer to zero. Same with current time, adjust and select cancel, this should reset current time.
If you do not have the original remote, you are in trouble. Service tech will have remote.
Feb 23, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
My sony KP-46WT510 has double images and the edges are red and green
Try pressing the Flash Focus button on the TV to adjust the convergence of the TV.
Sony TVs has an Optical Block issue. If there is an issue with the optical block, then there will be green, blue patches or tint on the TV display. Try resetting the TV to the factory settings and try Power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then TV may require service. You can contact the Customer relations team and check for the available options. Sony had repaired free of cost for such issues. Hence, contact the customer relations.
Jul 22, 2010 | Sony KP-51HW40 51" Rear Projection...
My sony KP-46WT510 the color in three corners is blured and the picture is bowed.
Hi,it seems you are experimenting a light engine problem.This is how your tv works: So basically the 3 Lcd chips that create the colors and image is going bad and thats why you get that color discoloration.Contact Sony or look for your light engine online.God bless you and your house!
Nov 18, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Lost power to my house when it returned my sony rear projection tv screen is distored and warped with color bands seperated
It sounds convergence out ICs are defective in your Sony TV and need to be replaced.
Let me know exact model number written at back of TV to guide you further if you wish to repair TV by yourself.
Nov 09, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Why my tv on and after 5 minutes will off and cannot on any more
Disconnect all the cables from the TV then reconenct them after a few minutes. Make sure you've connected the power cord from the TV directly to a functional wall outlet.
If the TV still doesn't turn ON then service will be required.
Sep 15, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Sony projection tv convergence problem
You need to replace the convergance IC's and a pico fuse on the power supply
Sep 03, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Sony kp-46wt510 will not turn on
follow the power cord they are usually right in front of it where it connects to the board.
Aug 05, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
When i turn the TV on, a red light on the front of the set just flashes (standby light)
Let me know model and brand of TV if its other then Sony KP-46WT510 and also count red standby light flashes as there would be long pause between blinks.
These info will help me to find out possible solution.
Jul 27, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
6 bliks on sony kp-46wt510
KP46WT510 Shutdown 6 Blinks. 6 Blinks = Low B+ OCP/OVP
SOLUTION: Replaced Flyback transformer. It had no rings on the ringer test.
Comments: Any load on the B+ line can cause 6 Blinks.
Example: If the 200v line is loaded down will cause a drop in B+ due to bright picture current demand.
Click Here! to download the Sony Kp-46wt510 full service manual.
Nov 11, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Televison & Video Logo
Top Televison & Video Experts
