Question about Viking Kitchen Ranges
I have 2 problems. The first is that the oven, every minute and 10 seconds or so, has to reignite itself. This goes on constantly for the duration of the cook time. Now a new problem has just occured. The rear right igniter on the stove just started constantly firing about 10 minutes ago and hasn't stopped.
  • 116 Answers
The first problem - I am not sure this is a problem - it is normal for ovens during cooking to cycling on or off several times. Is this something you notice recently or this is the first time you have ever noticed this.
The second - this may be happenning because the microswitch at the knob may be deffective (constantly on) check this and the wiring harness to make sure nothing is shorting out
Regards
Posted on Oct 01, 2008
I have a Maytag Model PGR5710BDW gas range. The bake igniter lights up and the gas ignites after 2 minutes or so. Then the flame goes out after a few seconds and then reignites and this cycle repeats ...
Yes it is the igniter its weak and can not stay within normal range to stay on allowing the flame to stay on.
The part number for that igniter is 74007498 it can be purchased at your local appliance parts store on online at
searspartsdirect.com
repairclinic.com
apwagner.com
apdepot.com
partselect.com
GENE
Aug 27, 2011 | Maytag PGR5710 Performa Gas Kitchen Range
My oven door is locked closed. Also, it reads F8 and beeps. In order to stop the beeping, the cancel/off button must be hit. When I do that, the fan turns on for about a minute and then stops and goes back...
The control board runs self checks about every 10 seconds to check the oven codition,and what the F8 error code means is it has detected a problem with the control board itself and it needs to be repalced
Gene
Aug 04, 2011 | Jenn-Air JJW8430D Electric Double Oven
My 36 " thermador oven,
The sensor on the burner is not sensing the flame. It could be the sensor itself or its' controller. You need to call for service.
Oven repair in Santa Ana, CA
Appliance repair in Santa Ana, CA
Jan 24, 2011 | Thermador Professional Series PO301...
Microwave clock and duration won't set
Good Morning,
Unplug the oven and wait 3 minutes then plugit back in and check to see that it operates normally. Do not run the oven empty - place a cup of water in it. Let me know if this helps and thank you for using FixYa!
Mar 30, 2009 | LG Microwave Ovens
My oven - St George UGM-4 model - won't light. I don't know how old the oven is. There have been problems for a while, with the flame going out after about 5 minutes when it's first lit (it makes a...
this one is hands on fix,many times the spark ignition the one that makes the clicking noise is clicking on a different position,so you most look inside the oven to see the spark, you can see it better at night or when is dark to see the spark, that spark is right at the tip of the oven pilot, make sure you see the spark lighting the pilot.as long as the pilot does not ignite.the clicking sounds continues making the noise. if the pilot lights the noise will stop, if the oven burner does not light after pilot is being for about 1 minute and a half the safety valve needs replacing
Dec 06, 2008 | Kitchen Ranges
When the gas boiler comes on the pilot light goes out after about 60 seconds then reignites itself a few minutes later.
This is caused by a weak flame sensing device. As main burner ignitin occurs this creates a roll out condition , when this condition occurs it derives oxygen from the pilot light thus reducing flame signal and causing the pilot to drop off momentarily.
Nov 09, 2008 | Heating & Cooling
Hiya, I've got a samsung u900 and when the phone has been idle (slider down and keys locked) even for just a minute when some one rings me the keys light up but the screen remains blank no light or...
Adjusting the duration of the backlight
To adjust the duration, perform the following steps:
1. At the main screen, select Menu.
2. Scroll to and select Settings.
3. Scroll to and select Display settings.
4. Scroll to and select Light settings.
5. Scroll to and select Backlight time.
6. At On, press the OK key.
7. Scroll to one of the following options, and then select OK:
  • 10 seconds
  • 30 seconds
  • 1 minute
  • 3 minutes
  • 10 minutes
8. Scroll to Dim and press the OK key.
9. Scroll to one of the following options, and then select OK:
  • Off
  • 5 seconds
  • 30 seconds
  • 1 minute
  • 3 minutes
10. Select Save.
Aug 07, 2008 | Samsung Cell Phones
Kitchen Ranges Logo
160 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
