Question about HP Office Equipment & Supplies
In refilling my color cartridge for the 1st time, I got ink on the instructions and I need to know the correct chamber to place CYAN, MAGENTA, & YELLOW JAUNE in the HP 78 cartridge.
  • borgie28 Oct 02, 2008
    Your exceedingly bright remark as to "youspillit kit" surelly indicates your daddy was a batchlor.
  • borgie28 Oct 05, 2008
    Thank you for the english lesson. I am an engineer not a speller. You still never answered my quarry. I picture you as an individual that hesitates to articulate for fear of deviating from the true course of rectitude. IN SHORT--- YOU DON'T KNOW THE ANSWER!
  • HP Expert
  • 141 Answers
That's what you get for investing in a youspillit kit.
Posted on Oct 02, 2008
  • 2 more comments
  • steve shroder Oct 02, 2008
    my apologies, bad attempt at humor, but touche anyway.
  • steve shroder Oct 03, 2008
    even better is the fact that my daddy can spell surely and bachelor, which unfortunately you can't.
  • steve shroder Oct 06, 2008
    A non-believer, when in doubt must always criticize the other participant for their own ineptitude. If you insist upon damaging your machine with a youspillit kit then the chambers are cyan, magenta, and finally, yellow. That is from right to left, printhead end down, facing the copper colored flex contact on the rear. You may be successful with this ploy once, twice, maybe even three times. Mark my words, they will leak and ruin your machine ending up costing you more than what you think you're saving. Ten years in this industry teaches me that. Oh but I forgot that I was conversating with an engineer. That throws my experience out the window doesn't it. You obviously know better. Good Luck!
  • steve shroder Oct 08, 2008
    make that left to right.
Im using hp deskjet 2660 cartridge says INTRODUCTORY HP TRICOLOR PRINT CARTRIDGE (colors) cyan magenta yellow 60 it's not producing yellow images that i printed are in pink or purple i...
This model printer has only two slots for ink cartridges. One is for a black ink cartrigde and the other is for a tri-color cartridge which contains cyan, magenta and yellow inks.
This tri-color cartridge has run out of yellow ink, you need to replace this tri-color cartridge.
Aug 12, 2011 | Office Equipment & Supplies
Dell 926 Printer ink refill instructions
*see the manual and follow the instructions and fill it
* contact manufacturer about details
Jul 02, 2008 | Dell 962 Photo All-In-One InkJet Printer
I need to know how to refill my ink for my nx110 printer
The ink cartridges used in Epson's Stylus line of printers are very similar to the ones used in its other printers. A handful of cartridges--like the S020034, S020047 or S020049--may require a slightly different refilling technique, but they all basically entail opening a fill hole in the top to run down into the ink chamber within. Once the chamber is accessible, you can use a basic refill kit with a syringe bottle to refill the chamber, as with most printer-ink cartridges.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); });
1. Hold the cartridge upside down so the outlet holes to the printer paper are on top. Cover each hole with a piece of tape, then turn the cartridge right-side up.
2. Make a hole in the top of the cartridge above each ink chamber. For most cartridges, simply poke a hole through the label with a toothpick. With cartridges like the Epson Stylus 34 (the casing of which is black), pull back the label to reveal the filling holes and puncture the seal of each home. For the 47 or 49 color cartridge, drill a 1/8-inch hole in the shell between the label and front edge.
3. Determine which color of ink is in which chamber (if you're refilling a color cartridge). The toothpick used to puncture the hole should draw out some ink to show you. If you have a cartridge in which you punctured the label directly, the order of the color chambers is usually cyan, magenta and yellow. If you created the hole in another way (like with the 34, 47 or 49 cartridges), the order is usually magenta, cyan and yellow.
4.Fill the syringe bottle with 5ml of ink. Insert the needle in the filling hole and inject the ink. There may be a sponge inside the chamber, so make sure the needle goes all the way through to the bottom. The 34 cartridge takes up to 12ml of ink.
5. Tape over the fill holes you created. If you drilled the holes, plastic plugs (like the ones included in a refill kit) can work as well. Leave the tape on the outlet holes as you replace the cartridge in the Epson Stylus printer.
6.
Dec 04, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I am having a problem printing with my HP printer
you wasted your time using cleaning program and heaps of ink...
follow this procedure:
1. remove all ink cartridges from the printer
2. check if ink is soluble in water, isopropyl alcohol or methylated spirit (this which do not create lumps or precipitations is correct solvent)
3. put one drop of solvent in th centre of aspiration hole on receptable
4. if solvent is absorbed through input, that meant problem is not with printer but with cartridges.
5. check printer cartridge by stamping them with tissue if they "produce" any ink on the outlet,
6. put one drop of solvent on cartridge outlet and insert them in correct bases
7. print test page, print should be rather weak as solvent will go through the nozzles
8. print test page from computer
9.create "strip page" of each colour used, separate by no colour (white) start with yellow strip, then white, light cyan, white, cyan, white, light magenta, white, magenta, white, black - this strip pattern will force all cartridge to operate on they max delivery.
if there is no result, service by technician will be in place...
all ink based printers need to print at least one page per week... ink will dry pretty fast, especially in dry or hot condition.
Jul 28, 2010 | HP C6250 InkJet Printer
How to refill ink in hp blck cartridge
  • Purchase an ink refill kit at an office supply store. (Staples, Walmart, and Costco all carry this inexpensive kit. It usually costs about half the price of an average printer cartridge.)
  • Gather your kit, a roll of paper towels, and some clear scotch tape together on a large flat working surface, a table or desk.
  • 3Remove the empty cartridge from your printer. (Remember to close your printer lid or door while you are working.)
  • 4Cover your hands with a pair of disposable plastic gloves while you work with the messy ink.
  • 5Take a paper towel and fold it in half twice. Work over the paper towel to catch any leaking ink.
  • 6Place the empty cartridge on it.
  • 7Read the instruction manual included with the refill kit to learn how to refill your particular type of cartridge. (The following instructions are just a general guide).
  • 8Locate the fill holes on the top of the cartridge. The depressions can be felt by rubbing your finger across the label.
  • 9Use a sharp pencil to pierce the refill holes in the top of the ink cartridge. (Correct places can also be found in the kit instructions).
  • 10In addition to black, there are three colors of ink: magenta, cyan, and yellow. Follow the kit instructions on which hole to insert each color OR push a toothpick into the holes to identify the colours as markings on the printer cartridge are sometimes there to fool you into putting the wrong colours into the cartridge ink chambers.
  • 11Insert the long needle on the refill ink bottle into the correct hole.
  • 12Slowly, add the ink. Carefully watch to be sure that you do not over-fill.
  • 13Stop quickly as soon as you see a bit of ink oozing out of the hole. Without letting go of the bottle, slowly release the air, sucking a little ink back out of the ink cartridge, before you remove the needle completely.
  • 14Carefully daub the cartridge contacts on the paper towel, you should see a splotch of the ink leaking out onto the paper towel.
  • 15Cover the hole with a small piece of clear scotch tape. (This works better than the seal dots included in the kit.) Make sure that no ink is leaking out of the top holes. (That's where the clear tape comes in handy.) Be careful not to cross contaminate the colors.
  • 16Repeat steps 11-15 for each ink color.
  • 17After you have refilled all three colors, carefully blot (don't wipe or rub) the cartridge printhead on a folded piece of paper towel. You may need to do this several times. Do this until it stops bleeding and you see an even stripe of three colors showing up on the towel.
  • 18If the blot shows the colors either faded or not at all, blot on wet paper towel and again on dry, to get the ink flowing.
  • 19Replace the ink cartridge into the printer. Never, ever install a leaking print cartridge.
  • 20Immediately print something, anything, just to get the ink flowing. Print several test pages, preferable photos with a lot of different colors.
  • 21Follow the cleaning or priming cycles for your specific printer.
  • May 25, 2010 | Office Equipment & Supplies
    Hello'' can you tell me how to change the ink in the kodak printer?
    1. Open up the cartridge to reach the ink chamber within. For color and photo cartridges, just remove the lid with a sharp knife (insert it where the black and colored plastic meet) to find the three fill holes. On black cartridges, make a hole with a heated pin or drill on top of the cartridge where the letter "K" is.
    2. Step 2 Check the chambers in a color/photo cartridge to determine which color ink is in which chamber. Insert a different toothpick or pin into each chamber to draw out yellow, cyan or magenta ink.
    3. Step 3 Fill a plastic syringe bottle with enough ink in the color you are refilling. A black ink cartridge should need 10 to 15 milliliters. A color/photo cartridge takes 5 milliliters of each color.
    4. Step 4 Insert the syringe needle into the cartridge, sending the tip down to the bottom. The chamber contains a sponge, so you will need a small bit of force to push it in.
    5. Step 5 Inject the ink into the cartridge. Unlike other brands of cartridges, you want to saturate the sponge with ink in a Kodak cartridge. Depress the syringe plunger slowly until you can see the ink begin to surface on top of the sponge.
    6. Step 6 Wash all ink residue out of the syringe after you've refilled one shade of ink. If you intend to refill another color immediately, dry the syringe out first.
    7. Step 7 Replace the lid on a color/photo cartridge. Apply a strip of tape to the spot where you first removed the lid to secure it. You don't need to seal a hole you drilled in a black cartridge.
    8. Step 8 Leave the cartridge standing in a secure spot overnight. This helps the ink settle within the cartridge for even printing once the cartridge is back in the printer.
    Apr 30, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
    Need the diagram and instructions for manually refilling the ink for the HPCD971AN black ink cartridge....This cartridge goes with the HP Officejet 6500 printer....This printer has individual color...
    Hi
    All printer are the same ways to refill the inks up go to this website it will show you how it done there is a few Videos there for you to see how it done
    http://www.youtube.com/watch?v=pnCPB9Clk5c
    Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
    All The Best: Pineworks
    Feb 03, 2010 | Office Equipment & Supplies
    Photosmart C5280. Instructions on photo cartridge 348 say remove both black and colour cartridges, then install photo cartridge in right hand cartridge holder. Printer screen then tells me to install...
    Your printer uses the following cartridges:
    HP 74 - Black ink
    HP 75 - Cyan, Magenta, and Yellow ink
    HP 99 - Photo Black, Light Cyan, and Light Magenta
    You need Photo Black, Cyan, Magenta, Yellow, Light Cyan, and Light Magenta to print photos. To accomplish this you install the HP 99 photo cartridge where your HP 74 black cartridge usually goes and you keep the HP 75 color cartridge where it's at. I don't know why your printer told you to remove both cartridges, then reinstall the HP 75 color cartridge.
    Oct 10, 2009 | HP Photosmart C5280 InkJet Printer
    Lexmark 2300 series
    yes you can refill the cartridge.
    Each kit includes 3 bottles of photo ink (1 bottle each of photo black-photo cyan-photo magenta) plus all refill-tools and instructions needed to successfully refill your Lexmark 18C0031 cartridge.
    The trick to extending it's life is to know how to add Ink, and to only use Ink which matches the ink which originally came with your cartridge. Each cartridge is manufactured to work with a specific type of Ink, and will not work correctly with anything different.
    Apr 10, 2009 | Office Equipment & Supplies
    I don't have a Dell but we have Lexmarks which use similar cartridges. I'm guessing your color and black has a flat top. Your printer should be using a 2 cartridge system and most likely w/ 4 colors. Black, Cyan, Magenta and Yellow. The Black cartridge is a single color cartridge. The CMY (short for Cyan,Magenta,Yellow) is in another cartridge. If you don't know which one, get a paper tower and dab the bottom of the cartridge near the nozzles which are usual silver in color. If you have the color you now need a very thin needle to fit those very small holes. If your needle wont fit then you will have to enlarge the holes. To refill,you really will enlarge it anyway to inject the syringe needles in. Stick the needle into the hole as deep as you can and stop just before you hit bottom. Just approximate the height of the cartridge to the needle. When you take the needle out, use a paper towel or toilet paper to wipe off the ink. What you wipe off will be the color of that chamber. You just need to do one more on any of the 2 remaining holes. Label as you go so you know what color it is. Don't do mental gymnastics. One mistake means you either print w/wrong colors or buy a new cartridge. I'm not familiar w/ the cartridge so I'm guessing on the color you should put between 1-2ml of ink per color. On the black maybe 5-8ml. This is to be on the safe side. Don't overfill it. There's no guarantee your cartridge will print, cuz manual refills are not as good as those done on a machine. If it works you may be able to refill another 2-3 times. Manual refilling is a gamble. Just ink the ink in very slowly and be patient. take about 15-20 seconds to inject 1 ml. Hope this helps.
    Nov 13, 2008 | Dell 926 All-In-One InkJet Printer
    43 people viewed this question
    Ben Johnson
