Question about Marvel (6SBARBSG) Wine Cooler
Relay My cooler has bad relay, where I can get it? The # 41006036 REV.J 000309159 [4406]
  • 2 more comments
  • gand77 Dec 18, 2008
    i have same problem with a beer cooler
  • fxlong Feb 15, 2009
    My Marvel beverage cooler runs constantly and everything freezes even at the minimum setting. I assume it's the cold control thermostat/relay, P/N 41006036, but I don't know where I can find the replacement part.
  • Jon Roddick Mar 22, 2009
    Viking VUAR141 (built by Marvel) relay isn't the problem, its probably the thermistor (temp sensor) did you get your problem solved?
  • James Burgess Nov 17, 2011
    I have the same problem on the same fridge. Without thinking to look here I asked a local repair guy who said I needed to replace the whole thing so I got the kit.. Now that it's here it strikes me as a little odd that the controller (the "relay" as you call it) would go out. Did you replace it or just the thermistor?
    Novelist:
  • 101 Answers
I truly doubt the control is the faulty component. It has two inputs it uses to decide when to cycle the compressor.
1) the potentiometer with the control dial is connected to terminals # 6 and 7.
2) the thermsitor is connected to terminals # 4 and 5.
Most of the time it is the thermistor that has failed. Marvel Part number 42244531.
You can order it directly from the factory by calling 800-428-6644
Posted on Sep 15, 2009
  • JohnnyRecon Dec 01, 2010
    My Viking VUARI40 was also freezing up the contents inside the fridge causing bottles to explode. I initially thought that it was going to be the Thermostat Cold Control, however as subdriver pointed out that it most likely is the thermistor.
    By the way, the Cold Control Thermostat part number 41006036 has been replaced by part number 42243506 and can be purchased at the link below for $112.99
    http://www.searspartsdirect.com/partsdir...
  • Chris Underwood
    Chris Underwood Dec 16, 2013
    I need a replacement Thermistor for my DUARI40 beverage fridge. The Thermocouple has a label saying P/N 41006038. Having a hard time finding a current part equivalent. Any suggestions? Is the one named above (42243506) the same??
Why does my wine cooler run too cold?
If after adjusting your thermostat to desired temp and is still cooling. The thermostat is bad or your relay is bad
If you disconnect the thermostat and the compressor stops it most likely a bad thermostat
If you disconnect the relay from
The thermostat and it stay running it is the relay. It is sticking
If possible store you wine somewhere else and shut the unit down and unplug for 10 to 20 minutes this may cause some melt of condensation some water may be on the floor if is to cold
This may also reset the system.
Jul 26, 2015 | Marvel 61WC Wine Cooler
My wine cooler will not run at all. The compressor is Ok. The cooler uses relay 41006036 rev E. I do get continuity on both the pot and the thermistor. What is the correct resistance for the thermistor...
Hi
Please check this link to read detailed information related to wine cooler as per your query:-
http://www.winecoolerexpert.com/wine-cooler-faq.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 05, 2011 | Marvel (6SBARBSG) Wine Cooler
Wine cooler clicking, not cooling, light still works
pull the relay off and see if it rattles...if so, its bad, i have seen these be bad and not rattle...its either relay, or compressor...
Jan 23, 2011 | Magic Chef MCWC30MCG Compact Wine Cooler
Clicking sound and not cooling
compressor grounded. replace relay or compressor
Jan 02, 2010 | Haier HVFM20ABB Wine Cooler
Temperature control does not work. Unit freezes everything no matter where the temperature control is set (Marvel Wine Refrigerator)
Either the thermostat itself is bad, or the relay is sticking. If you break the connection between the T-stat and the relay, and it keeps runnning, the problem is the relay.
If the compressor stops running when you break the connection or disconnect the T-stat, then the T-stat needs to be replaced.
Oct 12, 2009 | Marvel (6SBARBSG) Wine Cooler
Compressor locked on Franklin FWC36 wine cooler. won't start. current relays bad. is it possible to get spare parts or nhot?
you might be able to get one at the junk yaqrd or dump
its a relay overload on the compressor
look back at the compressor
there should be a block on one side that the relay and overlaod
go to repair clinic they sdhould have what you need
Oct 07, 2009 | Franklin FWC36 Wine Cooler
Making clicking sound motor gets hot but not cooling
Your PTC relay on the compressor is bad needs to be replaced.
First be sure to unplug cooler. Remove the cardboard cover that covers most backs of the units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
May 03, 2009 | Haier HVFM20ABB Wine Cooler
Can a cooler fan relay be located and replaced by a non mechanic
Dont know where your relay is but generally relays are grouped together in a box under the hood or on a rail on the firewall. They are "plug in" units that can be easily repalced.The ones housed in a box are usually easier to service because there is a description usually inside the cover. Many times the relays are the same# serving different purposes. If thats the case, use a good one and plug it into different slots 'till the fan comes on (make sure engine is hot enough for this to happen) Be aware that a bad sensor will give you a similar problem (it won't tell the relay to go on)
Feb 20, 2009 | 2006 Chrysler Pacifica
Magic chef compact fridgerator model mcbr445b1
you may just have a bad relay. with the power removed ..(unpluged)
remove the relay cover ( on the side of the compressor)
remove overload and relay
check relay for 4-5 ohms
check overload (if open it is bad)
let me know
Dec 21, 2008 | Refrigerators
Water is hot on both cold and hot side of my water cooler. water bottle on cooler is extreamly hot.
are you talking about a water cooler dispenser with hot and cold valve?
if you do, the cooling side is not functioning well.
is the compressor running? if not, check the thermostat.
if the compressor tries to start but can not. check the relay of the compressor, it may be bad.
if the relay is ok then the compressor is bad.
another thing to look at is the hot water thermostat. it may no longer functioning as to the cause of the bottle to be extremely hot.
tnx 4 using fixya,
drcool
Oct 06, 2008 | Whirlpool Refrigerators
Marvel (6SBARBSG) Wine Cooler Logo
1,526 people viewed this question
Top Marvel Furniture Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Joseph Hoffmann
Are you a Marvel Furniture Expert? Answer questions, earn points and help others
