Question about Toshiba TP61H60 61" Rear Projection Television
Plug it in and it sounds like it turns on but thr power light just blinks
    Scholar:
  • 56 Answers
Chances are that you have a power supply issue. I have found everything from bad solder connections to bad regulators cause it. I have even had a problem with the convergence amplifiers cause the power supply to shut down. If a simple reset (unplugged for fifteen minutes or so) does not fix the problem, I regret to tell you that it will probably require a service technicians help. But as long as he or she is fair with their pricing it will be worth the investment on this set.
Good Luck!
Rob
Posted on Nov 26, 2008
I have a Samsung lns4695dx lcd tv. The blue light on the front power switch blinks and I get no picture or sound. I read in some forums about bad caps on power supply board so I replaced the 12 cap in the...
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Mar 12, 2014 | Samsung Televison & Video
TV power problem
hi
your problem is in the power supply at the power oscillation circuit maybe you have defective parts or lost contact solders!
Oct 21, 2007 | Samsung SPN4235 42 in. Plasma HDTV
I have a sony kdf 50e-2000 the green light goes on then it goes to thr red blinking lamp light. I have no sound or picture. If I replace the lamp light will I get sound and a picture again?
Yes, if you have not replaced the lamp since you purchased this TV.
Lamps usually last about 6000 hours.
I've seen lamps last much longer than 6000Hrs, it all depends on the usage.
Remove the lamp from the TV and do a visual inspection, see if there's a crack on the glass or the bulb.
If the TV is few years old then the Lamp may be bad.
For a new Lamp: 800 638-3328
https://www.encompassparts.com/
DO NOT BUY the lamp from ebay
Good luck to you.
Nour Sabre
www.tvservice.com
May 24, 2012 | Sony KDF-50E2000 50" HDTV
Gateway LX6810-01 wont turn on now
1. how many beep sounds do you here and in what sequence ?
2. please look at the small blinking lit at the back of your pc most of the time thir combination of blinking speeks its problem.
2. check/remove if you install new hard ware on the board
Jun 30, 2010 | Gateway LX6810-01 PC Desktop
Green light blinks but no sound no picture
Power surge will knock out picture and sound if you don't have a power strip. Found out from Best Buys when purchasing another LCD TV. They have a warrenty against such problems.
Jan 18, 2010 | Sanyo DP19648 19 in. LCD TV
The red light in front was blinking.the repair man said it was the power board.We replaced it , now the red light blinks 6 times then quits. There is no picture but when on you can here the sound.
A 6 blink SOS shutdown, you would want to be looking at the SC, SU and the SD boards. One of those boards is causing the malfunction. Possibly, but unlikly(I have to mention it for just in case reasons) the PDP panel could have blown those boards.
Just out of curiosity, what was the original problem that made you call the first repair guy?
Dec 19, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Blinking powerlight on front when i try to turn on tv
This is more likely a power supply failure. Most causes of tv failure are due to bad capacitors on either a system board or the power supply. In this case, it sounds like the power supply. You can test the capacitors with a capacitor tester to determine faulty capacitor. You can also test other components like power supply current with voltmeter or mulit-tester.
Aug 13, 2009 | JVC AV48P777 Television
My e machine is blinking a yellow light.
Sounds to me like the power supply is bad cause its not providing the right voltages which is why the computer can't turn on.
Try a different known good working power supply. If it turns on then your original power supply is bad. If you still get a blinking yellow light then that means the motherboard is bad for sure and would need to be replaced.
Jun 02, 2009 | Computers & Internet
Power light blinks
Try using a different AC power adapter. It sounds like the laptop is not getting the proper power or not getting any at all. Have you taken out the battery and tried to power the computer on while plugged in? Also, take a pen or something similar and see if the DC jack (place on the laptop where the power cord plugs in) moves or appears loose.
Mar 18, 2009 | Toshiba Satellite A215-S4747 Notebook
Toshiba TP61H60 61" Rear Projection Television Logo
201 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
