Question about Brother MFC 420CN All-In-One InkJet Printer
My printer tells me that my cartridges are empty. I have replaced ALL the cartridges and installed same as required but it still reads replace cartridges and therefore the printer does not work. What do you suggest and advise
Correction: www.officestoredepot.com. You can purchase a printhead cleaning kit for $8.95. First, make sure the printer is turned on then try opening the printer and removing all the ink cartridges being careful to leave them in an upright position. Place them on a plastic bag because they will leak (be careful not to squeeze them). Close the cover. Wait one minute then open cover and replace all the cartridges making sure they all snap into place properly. Then close the cover. The lcd should then begin asking if you changed the ink. Answer yes. The printer will then begin cleaning and you should be good to go. Good luck.
Posted on Nov 09, 2008
  • 141 Answers
Replace the printhead.
Posted on Oct 02, 2008
How to check what ink cartridge needs replacing
Most printers will tell you which cartridge to replace; however, some may require all cartridges be replaced at once even if all are not empty.
Sep 24, 2017 | Office Equipment & Supplies
Print result in black and white appeared with lines
Most inkjet printer problems result from clogged or empty cartriges. Try inkjet cleaning program on printer, then run test. If that doesn't solve problem, May need to replace cartridge(s).
But the way, HP requires replacement with new HP cartridges. Has software that can tell.
Apr 25, 2016 | HP OfficeJet Pro 1150c All-In-One InkJet...
Printer keeps telling me that the yellow cart is empty and I have put a new one in
Are you positive it says the yellow cart is empty? Because that brother printer is designed to say that a cartridge is empty whenever ANY of the color cartridges are empty. Usually it doesn't tell you which one is really empty either. So even if you replaced the yellow cartridge and say, the black cartridge is empty, it still won't let you print until you replace that empty black cartridge, nor will you know which of the cartridges is empty unless you pull them out of the printer and manually check the ink levels.
Its pretty much a guessing game with those old brother ink printers.
Hope this helps :)
May 03, 2010 | Brother MFC-5440CN All-In-One InkJet...
Refilled ink cartridge and printer tells me to replace cartridge
its impossible trust me,there is some kind of microswitch in the cartridge that tells the printer its empty-now then listen up-refill it before its empty and it will not know,hows that for a work around
Feb 25, 2010 | Lexmark X9350 All-In-One InkJet Printer
Trying to replace the empty black toner cartridge. I go through the steps to do this as outlined in the manaul. I get the screen that tells me "Please Wait." And I wait and wait and wait, and nothing...
Instead of following the directions as outlined in the manual, to have the printer turn the drum so I could extract the empty cartridge, I cut out a couple steps, by just reading the printers status display window. Followed the links that took me to where it said Replace Empty Toner Black, pressed the Menu Select button, and was given the OK to open the lid and door and replace the empty cartridge.
Sep 20, 2009 | Konica Minolta Magicolor 2530 DL Laser...
Cant scan to computer
Unfortunately many of the All-In-One devices are like this. If the Cartridges are installed but empty the system is reading that fault code as the Cartridges not being installed. Even though you are not using the ink the printer is most likely doing a light head cleaning when it cycles. Replace teh cartridges and it should clear up.
Aug 27, 2009 | Canon PIXMA MP470 All-in-One Printer
Installed new Cartridge World Black cartridge in
You need the chip on the cartridge replaced or reset. The little circuit board on the front of the cartridge is what tells your printer that it is full or empty. You can either buy a new chip, or a resetter for around $20.00 and reset these chips in the future.
Jul 02, 2009 | Canon Pixma iP6600D InkJet Photo Printer
Replaced Toner, Does not register
replace toner cartridge with a bother brand
Jun 10, 2009 | Canon imageCLASS D760 All-In-One Laser...
Not recognize ink cartrdige Canon 6700D
Best thing to do is just replace the the indicated ink cartridge. Reason being is that even though the cartridge still has ink in it, it is the metal contacts on the cartridge that have to communicate with the printers on-board memory. If the contacts on the cartridge are fouled and are not communicating with the printer, the cartridge is telling the printer that "I am empty and I need to be replaced", even if it is full of ink. This would apply to all six cartridges.
Mar 07, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
Replacing empty cartridges
Make sure that the cartridges you installed are compatible for your printer.
Refilling the ink could actually damage the head that is why it is not advisable to refill, this will cost you more money for printer replacement.
Reseating the ink cartridges and rebooting the whole system could do the trick.
But if not, check if ink cartridges are really defective or has dried out so you can fix a return for those lemon.
This way we can identify if you really need to replace the printer instead of jumping into conclusions right away.
Thanks.
Jan 06, 2009 | Lexmark X6100 Flatbed Scanner
Brother MFC 420CN All-In-One InkJet Printer Logo
51 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
